[GRASS-dev] [GRASS GIS] #771: use longer ints for counting raster cells
Reporter: hamish | Owner: grass-dev@lists.osgeo.org
     Type: task | Status: new
Priority: normal | Milestone: 6.4.0
Component: Raster | Version: svn-develbranch6
Keywords: overflow | Platform: All
      Cpu: Unspecified |
when region sizes exceed a bit more than 45000x45000 plain int no longer
has the bitspace to keep track of the number of cells and overflows.
'unsigned int' only buys us a little time until region size exceeds
65536x65536.
in these cases 'unsigned long long' could be used to make the size bigger.
not all compilers know about long long though so ./configure does a check
for it and sets a macro.
  * r.stats and r.univar are a priority here.
r.info and g.region seem to have working implimentations,
example code from 6.5's g.region:
#ifdef HAVE_LONG_LONG_INT
             fprintf(stdout, "%-*s %lld\n", width, "cells:",
                     (long long)window->rows * window->cols);
             if (print_flag & PRINT_3D)
                 fprintf(stdout, "%-*s %lld\n", width, "3dcells:",
                         (long long)window->rows3 * window->cols3 *
                         window->depths);
#else
             fprintf(stdout, "%-*s %ld\n", width, "cells:",
                     (long)window->rows * window->cols);
                 fprintf(stdout, "%-*s %ld\n", width, "3dcells:",
                         (long)window->rows3 * window->cols3 *
window->depths);
#endif
r.info:
             compose_line(out, " Total Cells: %llu",
                          (unsigned long long)cellhd.rows * cellhd.cols);
#else
             compose_line(out,
                          " Total Cells: %lu (accuracy - see r.info
manual)",
                          (unsigned long)cellhd.rows * cellhd.cols);
#endif
r.info man page:
Some standards (ISO-C90) and compilers do not support the 'long long' type
as a 64-bit type. In the case that GRASS was built with such a compiler,
an accuracy message may be displayed in the output of <em>r.info</em>
after Total Cells:
we should standardize on something. any reason not to make it unsigned?
comments?
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/771&gt;
Resolution: | Keywords: overflow
  Platform: All | Cpu: Unspecified
Comment (by glynn):
Replying to [ticket:771 hamish]:
> r.info man page:
as a 64-bit type.
Just to clarify: C89 doesn't support it at all; the compiler will report a
syntax error if the code contains "long long".
For counts, using an unsigned type makes sense. Using "unsigned long" will
at least give you 64-bit values on 64-bit systems.
One caveat is that comparing signed and unsigned values will cast the
signed value to an unsigned value, which results in undefined behaviour if
the signed value is negative. So you need to use e.g.:
         if (sval < 0 || (unsigned) sval < uval) ...
         if (sval < 0 || (unsigned) sval <= uval) ...
         if (sval >= 0 && (unsigned) sval == uval) ...
         if (sval >= 0 && (unsigned) sval >= uval) ...
         if (sval >= 0 && (unsigned) sval > uval) ...
to ensure that the signed-unsigned comparison is only performed when the
signed value is non-negative.
Another caveat is the difference between two arbitrary unsigned values
cannot be represented by the equivalent signed type.
Ticket URL: <https://trac.osgeo.org/grass/ticket/771#comment:1&gt;
