#772: Error compiling nviz in grass7 trunk
Reporter: huhabla | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 7.0.0
Component: NVIZ | Version: svn-trunk
Keywords: nviz compile error | Platform: Linux
Cpu: x86-32 |
An error occurred in the latest grass7 svn trunk while compiling nviz.
grass_trunk was compiled via:
export CFLAGS="-Wall -Werror-implicit-function-declaration -fno-common" &&
./configure --without-freetype && make -j4
Error message see below:
soeren@Linux-T61:~/src/grass7.0/grass_trunk/visualization/nviz> make
make -C src
make[1]: Entering directory
`/home/soeren/src/grass7.0/grass_trunk/visualization/nviz/src'
gcc -I/home/soeren/src/grass7.0/grass_trunk/dist.i686-pc-linux-gnu/include
-I/usr/include/gdal/ -DPACKAGE=\"\"
-I/home/soeren/src/grass7.0/grass_trunk/dist.i686-pc-linux-gnu/include -o
OBJ.i686-pc-linux-gnu/map_obj.o -c map_obj.c
map_obj.c: In function ‘Nnew_map_obj_cmd’:
map_obj.c:515: error: implicit declaration of function ‘GP_set_sitemode’
map_obj.c:515: error: ‘ST_ATT_NONE’ undeclared (first use in this
function)
map_obj.c:515: error: (Each undeclared identifier is reported only once
map_obj.c:515: error: for each function it appears in.)
map_obj.c: In function ‘get_drawmode’:
map_obj.c:908: warning: passing argument 2 of ‘Tcl_Merge’ from
incompatible pointer type
map_obj.c: In function ‘get_res’:
map_obj.c:1030: warning: passing argument 2 of ‘Tcl_Merge’ from
map_obj.c: In function ‘get_wirecolor’:
map_obj.c:1148: warning: call to function ‘int_to_tcl_color’ without a
real prototype
map_obj.c:17: note: ‘int_to_tcl_color’ was declared here
map_obj.c: In function ‘get_trans’:
map_obj.c:1194: warning: passing argument 2 of ‘Tcl_Merge’ from
map_obj.c: In function ‘get_att’:
map_obj.c:1589: warning: call to function ‘int_to_tcl_color’ without a
real prototype
map_obj.c:1612: error: implicit declaration of function ‘GP_get_sitemode’
map_obj.c:1616: warning: call to function ‘int_to_tcl_color’ without a
real prototype
map_obj.c: In function ‘set_att’:
map_obj.c:1900: error: ‘ST_ATT_SIZE’ undeclared (first use in this
function)
map_obj.c:1903: error: ‘ST_ATT_COLOR’ undeclared (first use in this
function)
map_obj.c:1906: error: ‘ST_ATT_MARKER’ undeclared (first use in this
function)
map_obj.c: In function ‘unset_att’:
map_obj.c:1987: error: ‘ST_ATT_SIZE’ undeclared (first use in this
function)
map_obj.c:1990: error: ‘ST_ATT_COLOR’ undeclared (first use in this
function)
map_obj.c:1993: error: ‘ST_ATT_MARKER’ undeclared (first use in this
function)
map_obj.c: In function ‘get_char_marker’:
map_obj.c:2197: warning: zero-length printf format string
make[1]: *** [OBJ.i686-pc-linux-gnu/map_obj.o] Fehler 1
make[1]: Leaving directory
make: *** [default] Fehler 2
Build config see below:
GRASS is now configured for: i686-pc-linux-gnu
Source directory: /home/soeren/src/grass7.0/grass_trunk
Build directory: /home/soeren/src/grass7.0/grass_trunk
Installation directory: ${prefix}/grass-7.0.svn
Startup script in directory: ${exec_prefix}/bin
C compiler: gcc -Wall -Werror-implicit-function-
C++ compiler:
Building shared libraries: yes
64bit support: no
OpenGL platform: X11
MacOSX application: no
MacOSX architectures:
MacOSX SDK:
NVIZ: yes
BLAS support: no
C++ support: no
Cairo support: yes
DWG support: no
FFMPEG support: no
FFTW support: yes
FreeType support: no
GDAL support: yes
GEOS support: no
JPEG support: yes
LAPACK support: no
Large File support (LFS): no
MySQL support: no
NLS support: no
ODBC support: no
OGR support: yes
OpenGL support: yes
PNG support: yes
PostgreSQL support: no
Python support: no
Readline support: no
SQLite support: no
Tcl/Tk support: yes
wxWidgets support: no
TIFF support: yes
X11 support: yes
Regex support: yes
POSIX thread support: no
Ticket URL: <http://trac.osgeo.org/grass/ticket/772>
