[GRASS-dev] [GRASS GIS] #773: r.in.gdal unclean import of southern UTM zone
Reporter: hamish | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: Projections/Datums | Version: svn-develbranch6
Keywords: r.in.gdal, utm | Platform: Unspecified
      Cpu: Unspecified |
after bringing in a GeoTiff georef'd to UTM 48S with r.in.gdal I get a
errors when trying to open the map:
WARNING: Raster map <Multichrom.red@user1> is in different zone
          (-48) than current region (48)
WARNING: Unable to open raster map <Multichrom.red@user1>
ERROR: Unable to open raster map <Multichrom.red>
location was created manually using the text based g.setproj.
r.in.gdal gave the "projection parameters appear to match" message.
G65> g.region -p
projection: 1 (UTM)
zone: 48
G65> g.proj -p
-PROJ_INFO-------------------------------------------------
datum : wgs84
towgs84 : 0.000,0.000,0.000
proj : utm
ellps : wgs84
a : 6378137.0000000000
es : 0.0066943800
f : 298.2572235630
south : defined
zone : 48
GRASS 6.5svn,
GDAL 1.5.2-3~bpo40+1 on Debian/etch.
gdalinfo:
Coordinate System is:
PROJCS["WGS 84 / UTM zone 48S",
     GEOGCS["WGS 84",
         DATUM["WGS_1984",
manually editing the $MAPSET/cellhd/ files to make the zone: line positive
"fixes" it.
should the lib fn's automatically translate a cellhd negative zone number
into PROJ_INFO's zone:+south: keys? cellhd can not use "south:" for utm
zone as that's already used for the raster's southern bound. Should those
two be allowed to get out of sync or is it less bad to just ignore the
sign of the zone number in the raster's cellhd? If lib/gis/rd_cellhd.c is
modified to allow negative zone numbers note that the uninit'd value of -1
would have to be adjusted to -255 or something outside the legal range.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/773&gt;
Resolution: | Keywords: r.in.gdal, utm
  Platform: Unspecified | Cpu: Unspecified
Comment (by pkelly):
Hi Hamish,
How long ago was the location created? g.setproj had a bugfix on 7 October
2003 to create a negative zone number for southern hemisphere UTM
locations (<http://freegis.org/cgi-
bin/viewcvs.cgi/grass6/general/g.setproj/main.c.diff?r1=1.15&r2=1.16>).
Are you saying that that doesn't work (i.e. the negative zone doesn't go
into the WINDOW file) because libgis doesn't handle negative zone numbers?
If so that would make this an incredibly long-running bug...
Ticket URL: <https://trac.osgeo.org/grass/ticket/773#comment:1&gt;
Comment (by hamish):
Replying to [comment:1 pkelly]:
> 7 October 2003 to create a negative zone number for southern
> hemisphere UTM locations
It was created a few days ago with "grass65 -text" and a new location
name, then defined by following the prompts.
> doesn't go into the WINDOW file)
negative zone number doesn't make it into WIND, DEFAULT_WIND, or
PROJ_INFO.
> because libgis doesn't handle negative zone numbers? If so that
I've used southern hemisphere UTMs for ages without problems. I guess the
"new" thing here is r.in.gdal imported data actually gets it right?
the PROJ_INFO file has
zone: (some positive number)
south: defined
so to me putting a negative zone in PROJ_INFO is just confusing+redundant,
and so that part seems ok. (PROJ.4 uses +south to define a southern UTM
btw)
The WIND and cellhd files can not have a "south: defined" tag as south: is
used for the bound, so it should get a negative zone number there.
r.in.gdal is doing that for cellhd files (but eg r.mapcalc does not for
new maps), and WIND files are not getting it.
Part of the solution I think is to have G!__.window.zone report a negative
int for southern UTMs. That would mean that anything which writes a new
raster or WIND file should do that too.
(should opencell.c be using G_zone() instead?)
To avoid massive breakage from that we'd also have to improve the logic of
G!__open_cell_old() to test the abs() of the zone number and the south-
ness of the projection (but how?).
Everything seems to run through the WIND file and not the PROJ_INFO file,
so setting it in DEFAULT_WIND correctly seems to be the first step at
fixing this properly.
which brings us back to g.setproj/main.c which is currently asking the
'South Hemisphere? [n]' question BEFORE the 'Enter Zone:' prompt, so when
you enter the zone number it clobbers the cellhd.zone variable. The South
question has to come after, somehow.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/773#comment:2&gt;
the following patch fixes the order of questions, and sets the WIND files
correctly (and so new maps' cellhd too):
Index: general/g.setproj/proj-parms.table
--- general/g.setproj/proj-parms.table (revision 39463)
+++ general/g.setproj/proj-parms.table (working copy)
@@ -105,7 +105,7 @@
  UPS:Universal Polar Stereographic:SOUTH=ask,nodfl
  URM5:Urmaev
V:ALPHA=ask,0.0;LAT0=ask,0.0;LON0=ask,20.0;NFACT=ask,1.0;QFACT=ask,1.0
  URMFPS:Urmaev Flat-Polar
Sinusoidal:LAT0=ask,0.0;LON0=ask,20.0;NFACT=ask,1.0
-UTM:Universal Transverse Mercator (UTM):SOUTH=ask,nodfl;ZONE=ask,nodfl
+UTM:Universal Transverse Mercator (UTM):ZONE=ask,nodfl;SOUTH=ask,nodfl
  VANDG2:van der Grinten II:LAT0=ask,0.0;LON0=ask,20.0
  VANDG3:van der Grinten III:LAT0=ask,0.0;LON0=ask,20.0
  VANDG4:van der Grinten IV:LAT0=ask,0.0;LON0=ask,20.0
existing maps should be in existing mapsets/loc'ns so no bothered by this
change.
ok to commit for trunk & 6.5?
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/773#comment:3&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: r.in.gdal, utm
Changes (by hamish):
  * status: new => closed
  * resolution: => fixed
Comment:
committed proj-parms.table re-order in all branches; it doesn't seem to
have broken anything.
closing ticket.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/773#comment:4&gt;
