#775: r.terraflow: file=/home/mlennert/STREAM/STREAM_tQhXkQ:cannot read!: Bad
address
Reporter: mlennert | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: Raster | Version: svn-develbranch6
Keywords: terraflow bad address | Platform: Linux
Cpu: Unspecified |
In all three version (6.4, 6devel and 7), I get the following error
running r.terraflow in the North Carolina demo data set:
GRASS 6.5.svn (nc_spm_06):~ > g.region rast=elevation
GRASS 6.5.svn (nc_spm_06):~ > r.terraflow elevation=elevation@PERMANENT
filled=fill direction=flow swatershed=waters accumulation=accum tci=tci
STREAM_DIR=/home/mlennert/STREAM
STREAM temporary files in /home/mlennert/STREAM (THESE INTERMEDIATE
STREAMS WILL NOT BE DELETED IN CASE OF ABNORMAL TERMINATION OF THE
PROGRAM. TO SAVE SPACE PLEASE DELETE THESE FILES MANUALLY!)
file stats.out exists - renaming.
MFD flow direction
D8CUT=999999986991104.000000
Memory size: 300.00M (314572800) bytes
Memory manager registering memory in MM_IGNORE_MEMORY_EXCEEDED mode.
total elements=2025000, nodata elements=0
largest temporary files:
FILL: 108.15M (113400000) [2025000 elements, 56B each]
FLOW: 154.50M (162000000) [2025000 elements, 80B each]
Will need at least 308.99M (324000000) space available in
COMPUTING FLOW DIRECTIONS
classifying nodata (inner & boundary)
assigning preliminary directions
finding flat areas (plateaus and depressions)
file=/home/mlennert/STREAM/STREAM_lRe0NI:cannot read!: Bad address
r.terraflow: /home/mlennert/SRC/GRASS/grass6_devel/dist.i486-pc-linux-
gnu/include/grass/iostream/ami_sort_impl.h:91: size_t
makeRun_Block(AMI_STREAM<T>*, T*, unsigned int, Compare*) [with T =
plateauType, Compare = ijCmpPlateauType]: Assertion `err ==
AMI_ERROR_NO_ERROR || err == AMI_ERROR_END_OF_STREAM' failed.
Aborted
I have over 60GB of disk space in /home (and I get the same error running
it with the default /var/tmp). This is using Debian Lenny. The same error
has been reported by a student running Ubuntu Intrepid.
Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/775>
