[GRASS-dev] [GRASS GIS] #779: v.digit doesn't work after moving to Ubuntu karmic
Reporter: lucacasagrande | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: wxGUI | Version: 6.4.0 RCs
Keywords: digit,wxgui | Platform: Linux
      Cpu: x86-64 |
Hello folks,
I use 6.4 trunk built everyday but, after moving to Karmic, I have strange
issues with v.digit and
wx interface:
- I can't edit existing layer because the menu is empty and there is just
New vector map;
- When moving vertex the feature dissapear untill I stop editing;
Another big problem is that setting the debug to level 3, freeze the GUI
when open a new vector layer.
Using
Python 2.6.3
wx-config 2.8.10.1
SWIG 1.3.36
Thanks
Luca
Ticket URL: <http://trac.osgeo.org/grass/ticket/779&gt;
Resolution: | Keywords: digit,wxgui
  Platform: Linux | Cpu: x86-64
Changes (by martinl):
* cc: martinl (added)
Ticket URL: <http://trac.osgeo.org/grass/ticket/779#comment:1&gt;
Comment (by hamish):
Replying to [ticket:779 lucacasagrande]:
> I have strange issues with v.digit and wx interface:
I'm testing now on karmic with UbuntuGIS's 6.4.0rc5-3 package.
> there is just New vector map;
I can't reproduce this. Are you sure the vector map is in the current
mapset, and not via v.external. ie that it is not read-only?
I see the same thing, clicking on the eyeball brings it back though.
Weird.
> freeze the GUI when open a new vector layer.
that's a known problem. stderr buffer can't cope.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/779#comment:2&gt;
Reporter: lucacasagrande | Owner: grass-dev@…
      Cpu: x86-64 |
Comment(by neteler):
Can we close this since it cannot be reproduced?
Ticket URL: <http://trac.osgeo.org/grass/ticket/779#comment:3&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: digit,wxgui
Changes (by annakrat):
  * status: new => closed
  * resolution: => fixed
Comment:
Since there is no response, I am closing the ticket. Please reopen if
needed.
Ticket URL: <http://trac.osgeo.org/grass/ticket/779#comment:4&gt;
Comment(by hamish):
Weird.
that part was reproducible. Is it still the case?
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/779#comment:5&gt;
