[GRASS-dev] [GRASS GIS] #790: update files
#790: update files
Reporter: martinl | Owner: grass-dev@lists.osgeo.org
     Type: task | Status: new
Component: default | Version: svn-trunk
Keywords: update files/maps | Platform: Unspecified
      Cpu: Unspecified |
see http://lists.osgeo.org/pipermail/grass-dev/2009-October/046747.html
I am thinking how to implement direct write access to OGR datasources
from the user point of view. One approach would be to implement global
flag '--u' for updating existing vector map (i.e. OGR datasource).
E.g.
v.out.ogr input=test dsn=. type=point -n
v.external dsn=. layer=test output=test
v.random out=test n=1000 --u
this could work also for native format
v.edit map=test tool=create
v.info test -t | grep points
points=1000
points=2000
Or to add new parameters 'dns/format' which would be used only for OGR
format, not for the native one.
v.random out=test n=1000 format=ESRI_Shapefile dns=.
Any ideas?
Martin
PS: Patch which implements '--u' flag (currently works only for vector
maps: Vect_open_new() -> Vect_open_update()) available for testing.
Ticket URL: <http://trac.osgeo.org/grass/ticket/790&gt;
#790: update files
  Reporter: martinl | Owner: grass-dev@…
  Priority: normal | Milestone: 7.1.0
Component: Default | Version: svn-trunk
Resolution: | Keywords: update files/maps
Changes (by martinl):
* milestone: 7.0.0 => 7.1.0
Ticket URL: <http://trac.osgeo.org/grass/ticket/790#comment:1&gt;
