[GRASS-dev] [GRASS GIS] #793: Provide breakline (fault line) support for surface interpolation modules
Reporter: marisn | Owner: grass-dev@lists.osgeo.org
Component: Vector | Version: unspecified
Keywords: | Platform: Unspecified
      Cpu: Unspecified |
Current v.surf.* modules do not support breaklines (fault lines). It's
common in geology and other fields to have line/surface that limits
interpolated value expansion - interrupts spatial correlation
(neighborhood influence).
IMHO breaklines should be taken into account at two times - first when
choosing data input points for calculation (only points at one side of
line) and second time - when assigning values for cells - only cells at
one side of line should receive values.
I understand that this is longterm goal and it requires lot of discussions
how it should be implemented. Still it's a wanted feature.
Ticket URL: <http://trac.osgeo.org/grass/ticket/793&gt;
Resolution: | Keywords:
  Platform: Unspecified | Cpu: Unspecified
Comment (by hamish):
try v.surf.icw from addons.
http://grass.osgeo.org/wiki/GRASS_AddOns#v.surf.icw
http://grass.osgeo.org/wiki/Image:Inlets_03_SurfSal_icw_big.png
it is ''very'' computationally expensive so number of starting points
should be kept low.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/793#comment:1&gt;
Reporter: marisn | Owner: grass-dev@…
      Cpu: Unspecified |
Changes (by jdenisgiguere):
* cc: jdenisgiguere (added)
Ticket URL: <http://trac.osgeo.org/grass/ticket/793#comment:2&gt;
Component: Vector | Version: svn-trunk
Keywords: breaklines | Platform: All
      Cpu: All |
Changes (by hamish):
  * keywords: => breaklines
  * platform: Unspecified => All
  * version: unspecified => svn-trunk
  * cpu: Unspecified => All
Comment:
see also Alexander Muriy's v.triangle addon module,
   http://grasswiki.osgeo.org/wiki/TIN_with_breaklines
Hamish wrote:
> try v.surf.icw from addons. [...] it is very computationally expensive
> so number of starting points should be kept low.
note the new version isn't quite as expensive as the old, and now supports
multi-processing. Probably should still be limited to less than a few
hundred input points though.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/793#comment:3&gt;
