[GRASS-dev] [GRASS GIS] #805: i.spectral in GRASS6.4
Reporter: arocha | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: wxGUI | Version: 6.4.0 RCs
Keywords: i.spectral; wxGUI | Platform: MSWindows XP
      Cpu: x86-32 |
I'm using GRASS 6.4.0svn (2009) with wxpython and when I select
Imagery/Spectral Response (i.spectral) I get this error.
File "C:/GRASS6/etc/wxpython/wxgui.py", line 521, in
OnMenuCmd
menuform.GUI().ParseCommand(cmd, parentframe=self)
File "C:\GRASS6\etc\wxpython\gui_modules\menuform.py",
line 1809, in ParseCommand
xml.sax.parseString(getInterfaceDescription(cmd[0]).decode(e
nc).encode("utf-8"),
line 1748, in getInterfaceDescription
raise IOError, _("Unable to fetch interface description for
command '%s'.") % cmd
IOError
Unable to fetch interface description for command
'i.spectral'.
Is this something that was expected in this version or anyone has a an
idea
of how to fix this?
Ticket URL: <http://trac.osgeo.org/grass/ticket/805&gt;
Resolution: | Keywords: i.spectral; wxGUI
  Platform: MSWindows XP | Cpu: x86-32
Comment (by neteler):
I see this bug in several bug reports: #639, #581, #553, #234
It is not systematic but perhaps there is a chance to reproduce it.
Ticket URL: <http://trac.osgeo.org/grass/ticket/805#comment:1&gt;
Comment (by cmbarton):
Reading the error message, I'm completely convinced that this is even a
wxGUI problem. The error message suggests that "<command> --interface-
description" is not returning anything.
I do not have any problem launching either i.spectral or v.in.ogr (trac
#581) in the current svn version of GRASS 6.4 (or other versions) on Mac
OS X.
I see that this may be intermittent, but perhaps it is fixed now. Does
this still happen to anyone?
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/805#comment:2&gt;
Replying to [comment:2 cmbarton]:
wxGUI
This *should* read, I'm NOT completely convinced...
OS X.
> Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/805#comment:3&gt;
Resolution: | Keywords: i.spectral, wingrass
Changes (by hamish):
  * keywords: i.spectral; wxGUI => i.spectral, wingrass
Comment:
(use the "wingrass" keyword so it makes it onto the WinGrass errata list
and so gets more visibility)
Ticket URL: <https://trac.osgeo.org/grass/ticket/805#comment:4&gt;
Is this a Windows-only problem?
Michael
Ticket URL: <https://trac.osgeo.org/grass/ticket/805#comment:5&gt;
Comment (by hamish):
as per comments in #581,
* ''Can you try again with a nightly wingrass build >rev41308? I suspect
that Martin may have just fixed this (or something rather similar) in SVN
with r41308.''
Ticket URL: <https://trac.osgeo.org/grass/ticket/805#comment:6&gt;
Comment (by hellik):
Replying to [comment:6 hamish]:
with r41308.''
i've just looked at
http://grass.osgeo.org/grass64/manuals/html64_user/i.spectral.html
is there a example with the nc-sample-dataset for testing?
in the manuals there is
NOTES
This script needs gnuplot to be installed.
is there a gnuplot-version in osgeo4w or in osgeo4w-based wingrass-
version?
Helmut
Ticket URL: <https://trac.osgeo.org/grass/ticket/805#comment:7&gt;
> (trac #581) in the current svn version of GRASS 6.4 (or other
> versions) on Mac OS X.
yeah, but what if you change language settings to something that uses
chars outside the common western european language set?
Ticket URL: <https://trac.osgeo.org/grass/ticket/805#comment:8&gt;
I don't know. Maybe someone using another character set can check. But I'm
not sure how an alternate character set would affect the launching of
these 2 modules and not affect the launching of all modules.
Michael
Ticket URL: <https://trac.osgeo.org/grass/ticket/805#comment:9&gt;
Reporter: arocha | Owner: grass-dev@…
Keywords: i.spectral, wingrass | Platform: MSWindows XP
      Cpu: x86-32 |
Comment(by hamish):
and someone using a non-western European language set give it a try? is
i.spectral still broken from the wxgui menu?
worksforme,
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/805#comment:10&gt;
Priority: normal | Milestone: 6.4.2
      Cpu: x86-32 |
Changes (by martinl):
* cc: martinl (added)
  * milestone: 6.4.0 => 6.4.2
Comment:
Replying to [comment:10 hamish]:
no problem here
Ticket URL: <https://trac.osgeo.org/grass/ticket/805#comment:11&gt;
Priority: normal | Milestone: 6.4.3
Keywords: i.spectral, wingrass | Platform: All
      Cpu: x86-32 |
Changes (by neteler):
  * platform: MSWindows XP => All
  * milestone: 6.4.2 => 6.4.3
Comment:
Still failing in wxGUI (tested on Linux):
North Carolina example:
  * display "lsat7_2002_20"
  * start i.spectral from command line with -i -m
--> d.where and r.what zombie processes occur
CLI example:
g.region rast=lsat7_2002_10 -p
d.mon x0
d.rast lsat7_2002_40
i.spectral -i -m
rast=lsat7_2002_10,lsat7_2002_20,lsat7_2002_30,lsat7_2002_40,lsat7_2002_50,lsat7_2002_70
Ticket URL: <http://trac.osgeo.org/grass/ticket/805#comment:12&gt;
      Cpu: x86-32 |
Comment(by hamish):
The original --interface-description problem on wingrass seems fixed now.
Xmons are not available in Wingrass, so picking interactively won't work
there anyway even if gnuplot was installed. I've now added a test in
devbr6 (r56946) to bail out early if no Xmon is open.
Gnuplot is not shipped with our Wingrass package, so the module won't work
there.
If you try to run it you hit that error message first, asking you to
install.
BUT:
  'd.mon -L' as a command layer in the wxGUI shows all monitors as
running?!
same for "grass.run_command('d.mon', flags = 'L')" from the Python shell
tab.
I don't know of a good way for the script to test if it was called from
the wxGUI or not (especially after laundering through g.parser), so the
solution probably needs to be in menudata.xml.
trying MarkusN's example from comment:12 works fine for me in Linux from
the command line. it also doesn't lock up from the wxGUI _without_ the -m
flag, even without an Xmon open. trying from the wxGUI on linux (with an
Xmon open) with the -m flag causes the zombie mayhem. Perhaps in
menudata.xml the handler for i.spectral needs to be changed to `OnXTerm`
instead of `OnMenuCmd`? Another idea is to write a wrapper --script for
the wxGUI menu entry which forces non-interactive mode.
In addition to a number of other cleanups, I've also just added a new
east_north= option in devbr6 to allow non-interactive operation (so no
Xmonitor needed), and a couple new output graphics formats. I'll sync
those with trunk asap.
I'm not sure how much to backport to 6.4.3, at least the group= input
option is totally broken there since the i.group output text changed (but
luckily the new i.group -g flag makes the parsing much easier).
Hamish
ps- interestingly enough, while reading through the Gnuplot manual I
noticed that a "grass" graphics terminal exists for gnuplot which will
render your plots directly to a GRASS Xmonitor. It wasn't built into my
copy though so I couldn't test it.
Ticket URL: <https://trac.osgeo.org/grass/ticket/805#comment:13&gt;
      Cpu: x86-32 |
Comment(by cmbarton):
i.spectral is a very good candidate to be implemented in a wxPlot
interface like profiling and image scatterplots.
Michael
Ticket URL: <https://trac.osgeo.org/grass/ticket/805#comment:14&gt;
