[GRASS-dev] [GRASS GIS] #806: WinGRASS: Problem with special characters (wxpython GUI)
Reporter: marmai | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: default | Version: 6.4.0 RCs
Keywords: umlaut charcter german | Platform: MSWindows XP
      Cpu: Unspecified |
In the latest winGRASS binary (standalone version: WinGRASS-6.4.0SVN-
r39626-1-Setup.exe) there is a problem with the special characters in the
German language ('Umlaute', e.g. ö,ä,ü):
In the GUI windows that open at startup ('GRASS GIS Ebenen-Manager')
everything is correct, but all GUIs for modules (started from within the
wxpython GUI) have broken characters (all umlauts are broken; see attached
file). This occured on W2k and XP, and can be reproduced.
Ticket URL: <http://trac.osgeo.org/grass/ticket/806&gt;
Component: wxGUI | Version: 6.4.0 RCs
Resolution: | Keywords: umlaut charcter german
  Platform: MSWindows XP | Cpu: Unspecified
Changes (by marmai):
  * component: default => wxGUI
Ticket URL: <http://trac.osgeo.org/grass/ticket/806#comment:1&gt;
  Priority: major | Milestone: 6.4.0
Resolution: | Keywords: wingrass,umlaut charcter,german
Changes (by cnielsen):
  * keywords: umlaut charcter german => wingrass,umlaut charcter,german
  * priority: normal => major
Comment:
A french colleague of mine complained about the same issue. I'm not sure
how to fix it although I may have missed a library when assembling the
package.
It might help if you could tell me if this is the first version of
wingrass you have had a problem with?
Ticket URL: <http://trac.osgeo.org/grass/ticket/806#comment:2&gt;
Comment (by marmai):
Replying to [comment:2 cnielsen]:
I am not sure. I used the former wingrass versions, but I realized this
problem the first time in this version. But I am not sure that this
problem was not there in the older versions. Is it possible to get
somewhere the old binary installer (for the old versions), then I will
install a older version to check for this problem.
Ticket URL: <http://trac.osgeo.org/grass/ticket/806#comment:3&gt;
I found an old binary in my downloads (WinGRASS-6.4.0SVN-
r39271-1-Setup.exe downloaded 13th October 2009). I re-installed that
version, and here is the same problem with the characters.
Ticket URL: <http://trac.osgeo.org/grass/ticket/806#comment:4&gt;
Comment (by neteler):
We have done some modifications. Please check if the problem persists in
the latest available winGRASS version.
Ticket URL: <http://trac.osgeo.org/grass/ticket/806#comment:5&gt;
      Type: defect | Status: closed
Resolution: duplicate | Keywords: wingrass,umlaut charcter,german
Changes (by neteler):
  * status: new => closed
  * resolution: => duplicate
Comment:
duplicate of #806
Ticket URL: <http://trac.osgeo.org/grass/ticket/806#comment:6&gt;
      Type: defect | Status: reopened
  * status: closed => reopened
  * resolution: duplicate =>
Comment:
oops closed wrong report, sorry
Ticket URL: <http://trac.osgeo.org/grass/ticket/806#comment:7&gt;
Comment (by hamish):
fwiw I see a "ü" in the $Date$ stamp of the AUTHORS file from the
Help->About tab in the latest wingrass 6.4.0svn binary (r40456) on XP.
(Presumably because this is due to the packager's locale.)
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/806#comment:8&gt;
Replying to [comment:5 neteler]:
Sorry, but there is still the problem with the German 'Umlaute' in the
latest wingrass 6.4.0svn binary (r40456) on my machine (XP).
Ticket URL: <http://trac.osgeo.org/grass/ticket/806#comment:9&gt;
Comment (by hellik):
Replying to [comment:9 marmai]:
in the latest available winGRASS version.
I can confirm on Grass64svn, but on Grass65svn all german 'Umlaute' are
correctly displayed in the GUI
Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/806#comment:10&gt;
The file encoding is indentical:
file grass64/locale/po/*de.po grass65/locale/po/*de.po
grass64/locale/po/grasslibs_de.po: ISO-8859 English text
grass64/locale/po/grassmods_de.po: Lisp/Scheme program text
grass64/locale/po/grasstcl_de.po: ISO-8859 English text
grass64/locale/po/grasswxpy_de.po: ISO-8859 English text
grass65/locale/po/grasslibs_de.po: ISO-8859 English text
grass65/locale/po/grassmods_de.po: Lisp/Scheme program text
grass65/locale/po/grasstcl_de.po: ISO-8859 English text
grass65/locale/po/grasswxpy_de.po: ISO-8859 English text
Comparing gui/wxpython/gui_modules/menuform.py I see some SAX differences
and p.get() and __getNodeText() (which isn't used in 6.4) and in "class
GUI"
(SAX parsing no longer used). No idea if that's relevant.
Ticket URL: <http://trac.osgeo.org/grass/ticket/806#comment:11&gt;
Replying to [comment:10 hellik]:
persists in the latest available winGRASS version.
> Helmut
tested on a fresh grass64svn-checkout, all german 'Umlaute' are correctly
displayed in the GUI.
Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/806#comment:12&gt;
Resolution: fixed | Keywords: wingrass,umlaut charcter,german
  * status: reopened => closed
  * resolution: => fixed
Comment:
Martin has fixed it in r40553. Closing.
Ticket URL: <http://trac.osgeo.org/grass/ticket/806#comment:13&gt;
