[GRASS-dev] [GRASS GIS] #807: r.watershed doesnt consider longer distance to diagonal neighbouring pixels
Reporter: aread | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: critical | Milestone: 6.4.0
Component: Raster | Version: 6.4.0 RCs
Keywords: | Platform: All
      Cpu: All |
When using r.watershed on a low relief smooth dem I realised that the flow
direction surface was almost 20 times more likely to go to one of the
diagonal pixels rather then the edge pixels. I’m sure this is not right as
I interpret the description in Ehlschlaeger (1989) this shouldn’t happen.
The defect is that r.watershed isn’t correcting for the larger distance
between cells that share a corner then cells that share an edge. The
result is that r.watershed is directing flow to the lowest cell not the
steepest cell.
Ehlschlaeger (1989) in the last paragraph of section 4 describes how the
search algorithm should be adjusted to account for diagonal cells being
further away so that flow follows the steepest path. see
[http://chuck.ehlschlaeger.info/older/IGIS/paper.html\]
In
[http://trac.osgeo.org/grass/browser/grass/trunk/raster/r.watershed/ram/do_astar.c#L232]
there is code in get_slope that accounts for the diagonal but it doesn’t
seem to be called.
Ticket URL: <http://trac.osgeo.org/grass/ticket/807&gt;
Resolution: | Keywords:
  Platform: All | Cpu: All
Comment (by mmetz):
Fixed in trunk r39722 and r39724 and in devbr6 r39726 and r39727.
I followed the description in Ehlschlaeger (1989) to the letter and the
results seem to be correct now. I want to wait for independent
confirmation before backporting to relbr6. Using elev_lid792_1m in the
North Carolina dataset, the SFD results of 64 and 65 are strikingly
different and IMHO the 64 results look wrong compared to the 65 results.
Diagonal bias in flow direction is gone, now it's close to 50-50.
I noticed that a correction for diagonal bias was implemented in the
original version as in grass3.2 of 1990. Does anybody know why it was
removed? SVN history doesn't go back far enough.
MFD mode in grass65 and grass7 was only slightly affected, getting out of
sinks should be improved by now.
Markus M
Ticket URL: <https://trac.osgeo.org/grass/ticket/807#comment:1&gt;
  Priority: major | Milestone: 6.4.0
Resolution: | Keywords: r.watershed
Changes (by hamish):
  * keywords: => r.watershed
  * priority: critical => major
Comment:
triaging priority.
how does the patch (or r.watershed for that matter) work with lat/lon
locations? maybe that had something to do with the removal (???)
FWIW svn (cvs) history back to 1999 (~r1 to r3) can be found in the
grass54 branch even if the history has been broken in trunk. Also the old
ViewCVS is AFAIK still up & running (link on trac wiki page).
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/807#comment:2&gt;
Comment (by helena):
I finally had chance to look at it and it does make a significant
difference (much more than I would have ever guessed)
and I think that after some more testing
the fix should go to the GRASS64 release as a bugfix.
Some examples from the nc_spm_08 data set
1m resolution
old
http://skagit.meas.ncsu.edu/~helena/wrriwork/lakewh/flowD8dem.jpg
new
http://skagit.meas.ncsu.edu/~helena/grasswork/accum_5Kdiagfix.png
red is the stream from high res ortho
http://skagit.meas.ncsu.edu/~helena/grasswork/accum_5Kdiagfix2.png.png
I haven't done any serious testing but brief visual comparison indicates
that the fix may improve the accuracy of stream extraction beyond
just looking more realistic)
red-sreams from ortho, blue-old, black-new
http://skagit.meas.ncsu.edu/~helena/grasswork/accum_diagfix_streams.png
example with the 30m ned shows quite a few differences -
see the first stream from the west on these two images with the fix
apparently better although still with some error:
http://skagit.meas.ncsu.edu/~helena/grasswork/accum_10Korig.png
http://skagit.meas.ncsu.edu/~helena/grasswork/accum_10kfix.png
It would be very useful if anybody who has some other data than nc_spm and
some orthos to compare the results with runs another test and confirms
that
the change can go into 64, Markus, thanks for fixing it so quickly,
Helena
Ticket URL: <https://trac.osgeo.org/grass/ticket/807#comment:3&gt;
Comment (by mmetz):
Replying to [comment:2 hamish]:
locations?
Tested only in real projections, should most probably use geodesic
distance for lat/lon locations?
I'm busy investigating the new patch for its behaviour in depressions,
just to make sure I do not introduce another bug. Outside depressions it
looks ok, flow directions are set as expected.
The change happened between 1990 (grass32) and 1998 (grass40), I did not
manage to find that commit :frowning:
Markus M
Ticket URL: <https://trac.osgeo.org/grass/ticket/807#comment:4&gt;
Comment (by hamish):
Recommendation: wait to backport this to the 6.4.x line until after 6.4.0
has shipped,
and have it go out in the 6.4.1 release instead. otherwise we only have
time for
cursory checks. Waiting for 6.4.1 buys us some time.
We could add a BUGS section to the 6.4.0 help page if needed.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/807#comment:5&gt;
Comment (by mmetz):
Replying to [comment:5 hamish]:
6.4.0 has shipped,
time for
Hmm, about time, nobody checked in the last 17 years or so? grass40 was
released in 1992 I learned, and there the correction for diagonal flow
bias was already disabled. It was probably not related to lat/lon
projections because 1) I'm not sure if grass supported lat/lon back then,
2) there is a lot of slope calculation for the RUSLE factors that doesn't
care about lat/lon locations and is still active. Making r.watershed
lat/lon aware is (another) major rewrite... It was more probably related
to a severe speed penalty imposed by the original implementation, avoided
in the new implementation (which is also more in line with A* Search
logic). It is really a pity that the commit comments from grass32 to
grass40 are no longer available. I also did not find anything in the
mailing list archives, although r.watershed was apparently regularly used.
Hydrologists at CSIRO in Australia are currently looking at r.watershed in
depth and tear the algorithm apart, looking at all sorts of special cases.
So far the corrected version produces pretty much optimal results.
BTW, there is another bug in SECTION 4: Watershed determination, I'm busy
fixing it.
Markus M
Ticket URL: <https://trac.osgeo.org/grass/ticket/807#comment:6&gt;
Comment (by mmetz):
Replying to [comment:3 helena]:
> 1m resolution
> old
> new
Hmm, that looks very much like the old results before the fix, the
differences are probably due to floating point DEM support in grass65 and
grass7, all versions of r.watershed before grass65 read DEMs as CELL,
discarding any decimal places.
The new SFD results for elev_lid792_1m in nc_spm_08 with grass7 are very
similar to r.terraflow's SFD accumulation. I am pretty sure that all
algorithms used in r.terraflow are properly implemented (although I
disapprove of sink filling, I think it's done the right way). IIUC,
r.terraflow sorts all cells descending by elevation (sort stream) and then
distributes flow along the steepest slope (sweep stream), taking into
account the longer distance to diagonal cells. Thus, the results for non-
sinks should be mostly identical between the two modules.
Here are some numbers on SFD flow direction for r.watershed in grass7:
before the fix:
edge direction no sink: 8302 (1.59%)[[BR]]
diag direction no sink: 513291 (98.41%)[[BR]]
edge out of sink: 233 (45.60%)[[BR]]
diag out of sink: 278 (54.40%)
after the fix:
edge direction no sink: 241894 (46.38%)[[BR]]
diag direction no sink: 279699 (53.62%)[[BR]]
Similar for other DEMs, each percentage is somewhere in the range of >40%
to <60%. Although the new result doesn't look as smooth as the old result
for elev_lid792_1m, it now corrects for diagonal flow bias. Note that sink
traversal is unaffected; that is IMHO the big strength of r.watershed.
The fix not only affects the location of streams, the changes are also
very prominent in areas with low flow accumulation, interesting for
erosion modeling.
MFD is not affected, i.e. this fix would be mostly needed by 64 because it
doesn't have MFD. OTOH, these are drastically different results and before
submitting to 64 I would like to do more testing to 1) make sure I have
properly understood and implemented Chuck Ehlschlaeger's description and
2) figure out why the correction present in grass32 was removed for
grass4, there must have been a reason (maybe because the code did not
exactly match the description and caused problems in special cases).
Markus M
Ticket URL: <https://trac.osgeo.org/grass/ticket/807#comment:7&gt;
Replying to [comment:7 mmetz]:
> by 64 because it doesn't have MFD. OTOH, these are drastically
> different results and before submitting to 64 I would like to do
> more testing to 1) make sure I have properly understood and
> implemented Chuck Ehlschlaeger's description and 2) figure out
> why the correction present in grass32 was removed for grass4,
> cases).
maybe a silly question, but have you tried emailing Chuck to ask? He is
still contactable AFAIK & has been quite responsive to questions in the
past. I'm not even sure if he knows about all the wonderful updates you've
done and what r.watershed is now capable of.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/807#comment:8&gt;
Markus was right - the difference was due to handling elevations as int
versus fp,
so now I got the version with the diagonal fix
and here is the comparison of spatial patterns
grass64RC05 - SFD with integer elevation
range ~ -200000 - +200000
note zig-zag main streams, missing flow accumulation along the road on the
west ridge
http://skagit.meas.ncsu.edu/~helena/grasswork/accum5K_gr64rc5_3d.jpg
http://skagit.meas.ncsu.edu/~helena/grasswork/accum5K_gr64rc5.png
grass65 compiled in Sep 2009, SFD with FP before diagonal fix
range ~ -200000 - +55000 (why so much lower than grass64?)
no zig-zag on main streams, more realistic pattern on streams, lots of
diagonals on hillslopes
http://skagit.meas.ncsu.edu/~helena/grasswork/accum5K_gr65_sep09.jpg
http://skagit.meas.ncsu.edu/~helena/grasswork/accum_5Ksep09.jpg
grass65 compiled Feb 2010, SFD with fp after diagonal fix
range only slightly different, quite different pattern on hillslopes -
note particularly NW section of the watershed where the previously
diagonal flow changed to horizontal
http://skagit.meas.ncsu.edu/~helena/grasswork/accum5K_gr65_feb10c_i.jpg
http://skagit.meas.ncsu.edu/~helena/grasswork/accum_5Kdiag2010.jpg
I can see that somebody might have liked the diagonal biased version
better than the correct one.
grass65 MFD - no difference between sep 2009 and feb 2010
range ~ -200000 - +16000 (lower than SFD as it should be, but still why
such a diff between 64 and 65?)
most realistic overall
http://skagit.meas.ncsu.edu/~helena/grasswork/accum5K_gr65_mfd.jpg
http://skagit.meas.ncsu.edu/~helena/grasswork/accum_5Kmfdi.jpg
Compared to r.watershed in GRASS65, the GRASS64 results look really bad
for this
high resolution data - I assume for lower resolution data the difference
won't be
as stark but still grass64 will be much worse than the grass65 version.
Should grass65 version of r.watershed be backported to grass64?
although the difference in values needs to be explained (it may be mistake
on my side)
and Markus M may have some additional issues that need to be addressed,
what do others think? who makes the decision?
Helena
Ticket URL: <https://trac.osgeo.org/grass/ticket/807#comment:9&gt;
trac doesn't send the new comment to the ml???
see
https://trac.osgeo.org/grass/ticket/807#comment:10
      Type: defect | Status: new Priority: major | Milestone: 6.4.0 Component: Raster | Version: 6.4.0 RCs Resolution: | Keywords: r.watershed Platform: All | Cpu: All ---------------------+------------------------------------------------------
versus fp,
west ridge
for this
won't be
on my side)
Helena
yeah it does, you just have to wait a bit for it to show up.
the osgeo servers have become a bit of a victim of their own success and
are straining to keep up with the load. IIUC new bigger better faster ones
are on order and should be starting to come online by March.
Hamish
further comments on GRASS65 version,
I looked again at the negative values and according to the manual:Negative
numbers indicate that those cells possibly
have surface runoff from outside of the current geographic region.
However, when running r.watershed with elev_lid792_1m in the nc_spm_08
data set I get this as the result for mfd (which looks great):
http://skagit.meas.ncsu.edu/~helena/grasswork/accum_mfd.png
[[BR]]
but this is where the negative values are:
http://skagit.meas.ncsu.edu/~helena/grasswork/accum_mfd_neg.png
[[BR]]
why does it switch from positive to negative in the middle
of the slope even for the flow accumulation that apparently originates
on the top of the hill well inside the area?
Am I somehow misinterpreting the results?
I can imagine the high accumulation values starting from outside,
but the low negative accumulation values (in tens of cells) close to the
center
of the region have no way of starting outside.
[[BR]]
Helena
[[BR]]
Just a note that the man page has description and option twice,
this should be an easy fix.
Ticket URL: <http://trac.osgeo.org/grass/ticket/807#comment:11&gt;
Replying to [comment:11 helena]:
> [[BR]]
> [[BR]]
I suspect that it hasn't switched to negative, just that the color map is
stale and needs to be recalculated. (the slopes steeper than the last time
r.colors was run go beyond the current color rules and so get mapped to
the default color (white))
try re-running r.colors on it & d.redraw. and d.what.rast (or gui equiv)
to query actual values.
check the .tmp.html file in the module build dir. There's a chance that it
didn't get cleaned and every time you rebuild another copy of the auto-
generated help text gets appended. (I haven't seen that in a while, but
maybe it's back)
the actual second OPTIONs section in it gives a paragraph explaining each
option, which is too much for the command line quick help but useful to
have. shrug.
regards,
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/807#comment:12&gt;
Replying to [comment:12 hamish]:
> > [[BR]]
> > [[BR]]
is stale and needs to be recalculated. (the slopes steeper than the last
time r.colors was run go beyond the current color rules and so get mapped
to the default color (white))
Sorry that my image was misunderstood - the image with white spaces is the
exact same data as the image with full color except displayed as d.rast
myaccum val=-250000-0 (or something like that) and then just to make sure
I also extracted the negative values using r.mapcalc myaccum<0. And I did
use d.what.rast to check the actual values - I was trying to find out
whether they switch to negative along particular elevation contour, but
they don't. So if you query downslope you get for example 25, 33, 56,
-78,-90, ...
it didn't get cleaned and every time you rebuild another copy of the auto-
maybe it's back)
this is for the on-line man page
http://grass.osgeo.org/grass65/manuals/html65_user/r.watershed.html
as you have noticed it does not really repeat itself rather the OPTIONS
section should have been a subsection of DESCRIPTION, maybe just removing
the OPTION title and replacing it with sentence "Detailed explanation of
flags and parameters:" would minimize the confusion.
each option, which is too much for the command line quick help but useful
to have. shrug.
just randomly checking r.surf.contour has section "Parameters" twice.
There is probably more of it (nobody is apparently reading the manual
pages anyway).
Helena
> regards,
> Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/807#comment:13&gt;
Comment (by mmetz):
> [[BR]]
The main fow originates from the top of the hill, but cells on the slope
also receive flow from other neighbouring cells with higher elevation.
Tracing this back, particularly for MFD flow dispersion, can lead to the
edge of the region
center
Yes, they have, although the absolute amount of surface flow making it
from the edge of the region to there is minimal, <<< 1. If the edge of the
region has higher elevation than the center of the region, and if there is
an ever so slight downhill slope leading from the edge to the center, some
edge flow will reach the center.
Long explanation:
As the manual says, "Negative numbers indicate that those cells possibly
have surface runoff from outside of the current geographic region." or
from cells with unknown elevation (MASKed or NULL), and this is what the
results should show, if not, it's a bug.
The general slope direction in elev_lid792_1m is from about Northwest to
Southeast and the terrain is quite flat. Many hillslopes seem to be
neither strongly convex nor concave in tangential direction, and in MFD
mode, flow is distributed to many neighbours. Therefore it can be expected
that the sign of flow accumulation will also be spread considerably.
Still, is it true that so many cells receive offmap flow or is it a bug?
only negative accumulation values are displayed, overlayed by
elev_lid792_cont1m (1m contour lines). The negative sign is not propagated
uphill (except for egressing depressions), but, starting from the borders
of the region, slowly descends downhill (edge between coloured and white
cells).
Looking at negative sfd accumulation values, displayed in
http://sites.google.com/site/markusmetzgiswork/elev_lid.acc.sfd.highlight.png
one of the crucial differences is where the red ellipse is located in the
Northwest. Here, the hillslope seems to be rather flat in the tangential
direction, if not convex, and surface flow including the negative sign is
spread quite far.
http://sites.google.com/site/markusmetzgiswork/elev_lid.acc.sfd.zoom.png
http://sites.google.com/site/markusmetzgiswork/elev_lid.acc.mfd.zoom.png
both show only negative flow, it is apparent that SFD struggles to find a
reasonable flow direction on this hill and shows a straight line where the
negative sign is propagated from the region's edge downhill into the main
basin. MFD on the contrary spreads out the surface flow, typical for
convex hills and similar to flat areas. The negative sign is spread
together with the flow, and because this is at the top of the main basin
in the current region, the negative sign is propagated wide and far
downhill.
Negative flow also appears within the region midway down the large hill in
the Northwestern quarter, keeping in mind that this is not really a hill.
Elevation difference from the top of the hill to the first occurence of
negative flow is about 60cm and from that point the elevation difference
slowly increases. AFAICT, the negative sign is only propagated downhill.
If you are confident that there are indeed negative flow accumulation
values where there should be positive flow accumulation values, please
post the exact coordinates, so I can look in more detail what is going
there.
Markus M
Ticket URL: <https://trac.osgeo.org/grass/ticket/807#comment:14&gt;
Reporter: aread | Owner: grass-dev@…
Priority: major | Milestone: 6.4.4
Keywords: r.watershed | Platform: All
      Cpu: All |
Changes (by neteler):
  * milestone: 6.4.0 => 6.4.4
Comment:
For the record: devbr6 r39726 and r39727 have been backported some time
ago
to GRASS 6.4.svn.
Ticket URL: <http://trac.osgeo.org/grass/ticket/807#comment:15&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: r.watershed
Changes (by mmetz):
  * status: new => closed
  * resolution: => fixed
Comment:
Closing ticket as fixed in all branches.
Markus M
Ticket URL: <http://trac.osgeo.org/grass/ticket/807#comment:16&gt;
