#809: v.db.addtable consistently fails in winGrass
Reporter: JonBall | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: new
Priority: blocker | Milestone: 6.4.0
Component: Vector | Version: svn-trunk
Keywords: addtable | Platform: MSWindows Vista
Cpu: x86-64 |
Platform: Vista
grass obtained from: Trento Italy site
grass binary for platform: as Downloaded
GRASS Version: 6.4.0SVN (r39626) 2009-10-27
v.db.addtable consistently fails but returns no error message. When I try
to use this command at the Windows Grass Command Line (Windows shell), I
always get an empty shell prompt:
GRASS 6.4.0svn (spearfish60)> v.db.addtable map=mysoils layer=2 col="left
intege
r,right integer"
"C:/GRASS-6-SVN/msys/bin/sh.exe"-2.04$
The only apparent way to proceed it to type 'exit' at the shell prompt and
the command will terminate without creating a table. I am trying to
reproduce the script in the documentation for v.to.db
(http://grass.itc.it/grass64/manuals/html64_user/v.to.db.html - "Upload
category numbers of left and right area, to an attribute table of
boundaries common for the areas").
This error is consistent whatever data I try and use, whether it is the
demo Spearfish60, North-Carolina or some other data.
I have reproduced the same error on two independent installations of
winGrass on two different machines (both using the same pre-compiled
binaries).
I have tried switching to sqlite (same error). I have tried re-installing
winGrass.
Ticket URL: <http://trac.osgeo.org/grass/ticket/809>
