[GRASS-dev] [GRASS GIS] #811: MYSYS shortcut starts an infinite number of windows
Reporter: JonBall | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: critical | Milestone: 6.4.0
Component: Display | Version: svn-trunk
Keywords: MYSYS | Platform: MSWindows Vista
      Cpu: x86-64 |
Platform: Vista
grass obtained from: Trento Italy site
grass binary for platform: as Downloaded
GRASS Version: 6.4.0SVN (r39626) 2009-10-27
Clicking on either of the MYSYS shortcuts created during a winGrass
installation opens an infinite series of empty windows that cascade across
the screen.
When I finally manage to crass out of the infinite loop I sometime manage
to see a Windows error message that says 'rxvt not responding'.
Ticket URL: <http://trac.osgeo.org/grass/ticket/811&gt;
  Priority: major | Milestone: 6.4.0
Component: default | Version: svn-releasebranch64
Resolution: | Keywords: MYSYS
  Platform: MSWindows Vista | Cpu: x86-64
Changes (by martinl):
  * priority: critical => major
  * version: svn-trunk => svn-releasebranch64
  * component: Display => default
Ticket URL: <http://trac.osgeo.org/grass/ticket/811#comment:1&gt;
Resolution: | Keywords: MSYS, wingrass
Changes (by cnielsen):
  * keywords: MYSYS => MSYS, wingrass
Comment:
I've looked at the msys.bat file but I can't see anything that would cause
a loop. rxvt.exe won't work on an x64 system but it should jump to an exit
on fail...
Can you open a cmd.exe window and tell us what the value of
%PROCESSOR_ARCHITECTURE% is?
ie.
echo %PROCESSOR_ARCHITECTURE%
-Colin
Ticket URL: <http://trac.osgeo.org/grass/ticket/811#comment:2&gt;
Comment (by hamish):
"MSYS UNIX Console" menu item worksforme with r40456 build on 32bit XP -
it opens a rxvt term as it should.
Ticket URL: <https://trac.osgeo.org/grass/ticket/811#comment:3&gt;
Comment (by hellik):
Replying to [comment:3 hamish]:
for the record:
there are some hints for this issue for Win64 in
http://trac.osgeo.org/grass/wiki/CompileOnWindows#InstalltheenvironmentforcompilationMingW
so the actual WinGrass-Installer is built with an updated msys in the
osgeo4w-building environment.
see also
http://lists.osgeo.org/pipermail/osgeo4w-dev/2010-January/000760.html
Helmut
Ticket URL: <https://trac.osgeo.org/grass/ticket/811#comment:4&gt;
Comment (by neteler):
Is this still an issue with latest winGRASS from
http://josef.fsv.cvut.cz/wingrass/grass64/ ?
Ticket URL: <http://trac.osgeo.org/grass/ticket/811#comment:5&gt;
Reporter: JonBall | Owner: grass-dev@…
Keywords: MSYS, wingrass | Platform: MSWindows Vista
      Cpu: x86-64 |
Comment(by hellik):
Replying to [comment:5 neteler]:
still valid?
Helmut
Ticket URL: <https://trac.osgeo.org/grass/ticket/811#comment:6&gt;
      Type: defect | Status: closed
Component: Default | Version: svn-releasebranch64
Resolution: fixed | Keywords: MSYS, wingrass
Changes (by neteler):
  * status: new => closed
  * resolution: => fixed
Comment:
No reply, so we assume that it has been fixed. Closing.
Ticket URL: <http://trac.osgeo.org/grass/ticket/811#comment:7&gt;
Comment(by hamish):
I don't think it's related, but just in case- see also the bug report
#1184 about zombie processes cluttering up the ctrl-alt-del task list.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/811#comment:8&gt;
Comment(by martinl):
Replying to [comment:7 neteler]:
not really, osgeo4w's msys is just replaced by another msys, see
[wiki:CompileOnWindows#InstalltheenvironmentforcompilationMingW compile on
windows]
Ticket URL: <http://trac.osgeo.org/grass/ticket/811#comment:9&gt;
