#814: r.resamp.stats memory corruption when resampling from different
projection/zone
Reporter: pertusus | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: Raster | Version: 6.4.0 RCs
Keywords: | Platform: Linux
Cpu: x86-32 |
I would like to resample a map from a mapset to another that have a
different region using r.resamp.stats -w
In the new mapset, CRU_GRID, region is:
> g.region -p
projection: 3 (Latitude-Longitude)
zone: 0
datum: ** unknown (default: WGS84) **
ellipsoid: sphere
north: 90N
south: 90S
west: 180W
east: 180E
nsres: 0:30
ewres: 0:30
rows: 360
cols: 720
cells: 259200
In the PERMANENT mapset, the region is:
> g.region -p
projection: 99 (Lambert Azimuthal Equal Area)
zone: 0
ellipsoid: sphere
north: 4149500
south: -5044500
west: -4368500
east: 4367500
nsres: 1000
ewres: 1000
rows: 9194
cols: 8736
cells: 80318784
The map is a normal raster map in the PERMANENT mapset:
> r.info one_up_basin_194
| Layer: one_up_basin_194 Date: Wed Nov 18 18:41:41 2009
| Mapset: PERMANENT Login of Creator: dumas
| DataBase: /home/dumas/maps
| Title: ( one_up_basin_194 )
| Timestamp: none
| Type of Map: raster Number of Categories: 1
| Data Type: CELL
| Rows: 3996
| Columns: 1830
| Total Cells: 7312680
| Projection: Lambert Azimuthal Equal Area
| N: 2969500 S: -1026500 Res: 1000
| E: 2189500 W: 359500 Res: 1000
| Range of data: min = 1 max = 1
| Data Description:
| generated by r.mapcalc
| Comments:
| if(isnull(up_basin_194), 1 / 0, 1)
> r.stats -c one_up_basin_194
100%
1 866152
* 79452632
When in the CRU_GRID mapset I try to resample the map from the PERMANENT
mapset, I get an error message, and glibc detects some memory corruption:
> r.resamp.stats -w input=one_up_basin_194@PERMANENT
output=one_up_basin_194
WARNING: G_set_window(): projection/zone differs from that of currently
open raster maps
*** glibc detected *** r.resamp.stats: malloc(): memory corruption (fast):
0x081725f8 ***
======= Backtrace: =========
/lib/libc.so.6[0x658ba9]
/lib/libc.so.6(__libc_malloc+0x67)[0x659d87]
/usr/lib/libgrass_gis.so.6.4(G__malloc+0x2a)[0xeca82a]
/usr/lib/libgrass_gis.so.6.4(G__location_path+0x5c)[0xee416c]
/usr/lib/libgrass_gis.so.6.4(G__file_name+0x3f)[0xed936f]
/usr/lib/libgrass_gis.so.6.4[0xed99f2]
/usr/lib/libgrass_gis.so.6.4[0xed9aca]
/usr/lib/libgrass_gis.so.6.4(G_find_cell+0x2e)[0xed954e]
/usr/lib/libgrass_gis.so.6.4(G__check_for_auto_masking+0x4b)[0xecc72b]
/usr/lib/libgrass_gis.so.6.4(G_set_window+0x164)[0xefae44]
r.resamp.stats(main+0x10c3)[0x804a453]
/lib/libc.so.6(__libc_start_main+0xdc)[0x603e9c]
r.resamp.stats(w_var+0xa5)[0x80492d1]
======= Memory map: ========
00176000-00177000 r-xp 00176000 00:00 0 [vdso]
0019b000-0019f000 r-xp 00000000 08:01 1368258
/usr/lib/libgrass_stats.so.6.4.0RC5
0019f000-001a0000 rwxp 00003000 08:01 1368258
003b1000-003cb000 r-xp 00000000 08:01 834029 /lib/ld-2.5.so
003cb000-003cc000 r-xp 00019000 08:01 834029 /lib/ld-2.5.so
003cc000-003cd000 rwxp 0001a000 08:01 834029 /lib/ld-2.5.so
00539000-0054b000 r-xp 00000000 08:01 1367055 /usr/lib/libz.so.1.2.3
0054b000-0054c000 rwxp 00011000 08:01 1367055 /usr/lib/libz.so.1.2.3
005ee000-0072d000 r-xp 00000000 08:01 834042 /lib/libc-2.5.so
0072d000-0072f000 r-xp 0013f000 08:01 834042 /lib/libc-2.5.so
0072f000-00730000 rwxp 00141000 08:01 834042 /lib/libc-2.5.so
00730000-00733000 rwxp 00730000 00:00 0
0077a000-00782000 r-xp 00000000 08:01 1366008
/usr/lib/libgrass_datetime.so.6.4.0RC5
00782000-00783000 rwxp 00007000 08:01 1366008
009f0000-009fb000 r-xp 00000000 08:01 833980
/lib/libgcc_s-4.1.2-20080825.so.1
009fb000-009fc000 rwxp 0000a000 08:01 833980
00b4e000-00b73000 r-xp 00000000 08:01 834068 /lib/libm-2.5.so
00b73000-00b74000 r-xp 00024000 08:01 834068 /lib/libm-2.5.so
00b74000-00b75000 rwxp 00025000 08:01 834068 /lib/libm-2.5.so
00ebd000-00f10000 r-xp 00000000 08:01 1367259
/usr/lib/libgrass_gis.so.6.4.0RC5
00f10000-00f11000 rwxp 00053000 08:01 1367259
00f11000-00f18000 rwxp 00f11000 00:00 0
00f5f000-00f61000 r-xp 00000000 08:01 834062 /lib/libdl-2.5.so
00f61000-00f62000 r-xp 00001000 08:01 834062 /lib/libdl-2.5.so
00f62000-00f63000 rwxp 00002000 08:01 834062 /lib/libdl-2.5.so
08048000-0804b000 r-xp 00000000 08:01 182315
/usr/lib/grass-6.4.0RC5/bin/r.resamp.stats
0804b000-0804c000 rw-p 00002000 08:01 182315
08170000-08191000 rw-p 08170000 00:00 0 [heap]
b7c00000-b7c21000 rw-p b7c00000 00:00 0
b7c21000-b7d00000 ---p b7c21000 00:00 0
b7d2c000-b7f2c000 r--p 00000000 08:01 1373566 /usr/lib/locale/locale-
archive
b7f2c000-b7f2e000 rw-p b7f2c000 00:00 0
b7f43000-b7f44000 r--p 02b73000 08:01 1373566 /usr/lib/locale/locale-
archive
b7f44000-b7f45000 rw-p b7f44000 00:00 0
bfa49000-bfa5e000 rw-p bffea000 00:00 0 [stack]
Abandon
Ticket URL: <http://trac.osgeo.org/grass/ticket/814>
