[GRASS-dev] [GRASS GIS] #820: r.in.wms doesn't work in WinGRASS installer distribution
Reporter: ddalimonte | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: Packaging | Version: svn-releasebranch64
Keywords: | Platform: MSWindows XP
      Cpu: Unspecified |
The MSys environment included with WinGRASS (WinGRASS-6.4.0svn-
r39740-2-Setup.exe) does not include the bc command used by the r.in.wms
script. This causes the module to fail when trying to import maps from a
WMS service.
GRASS 6.4.0svn (AoCWMS):C:/GRASS/msys/home/Dan > r.in.wms output=roads_15m
mapserver=http://atlas.gc.ca/cgi-bin/atlaswms_en? \
layers=roads_15m format=png maxcols=1024 maxrows=1024 method=bilinear
which: wget: unknown command
which: bc: unknown command
ERROR: 'bc' is required, please install it first
Ticket URL: <https://trac.osgeo.org/grass/ticket/820&gt;
Resolution: | Keywords: r.in.wms
  Platform: MSWindows XP | Cpu: Unspecified
Changes (by martinl):
  * keywords: => r.in.wms
Ticket URL: <https://trac.osgeo.org/grass/ticket/820#comment:1&gt;
Comment (by hellik):
Replying to [ticket:820 ddalimonte]:
WMS service.
output=roads_15m \
bc can be included in the WinGrass-Installer. i've adapted
http://trac.osgeo.org/grass/wiki/CompileOnWindows#Pre-builtBinaries with
bc.
Ticket URL: <https://trac.osgeo.org/grass/ticket/820#comment:2&gt;
Replying to [comment:2 hellik]:
bc.
a quick test in my osgeo4w-tree added by bc:
r.in.wms output=roads_15m mapserver=http://atlas.gc.ca/cgi-
bin/atlaswms_en? layers=roads_15m format=png maxcols=1024 maxrows=1024
method=bilinear
Calculating tiles
c:/osgeo4w/apps/grass/grass-6.4.0svn/etc/r.in.wms/wms.reques
t: /osgeo4w/apps/grass/grass-6.4.0svn/scripts/r.tileset: No
such file or directory
ERROR: r.tileset failure
ERROR: wms.request failure
bc is found. but now r.tileset is not found because of a wrong path to the
script
Ticket URL: <https://trac.osgeo.org/grass/ticket/820#comment:3&gt;
Replying to [comment:3 hellik]:
bc.
method=bilinear
> Calculating tiles
the script
r.tileset is there:
C:\OSGeo4W\apps\grass\grass-6.4.0svn\scripts\r.tileset
Ticket URL: <https://trac.osgeo.org/grass/ticket/820#comment:4&gt;
Replying to [comment:4 hellik]:
> r.tileset is there:
at
http://trac.osgeo.org/grass/browser/grass/branches/releasebranch_6_4/scripts/r.tileset/r.tileset#L1
   #!/bin/bash
this should be
   #!/bin/sh
Ticket URL: <https://trac.osgeo.org/grass/ticket/820#comment:5&gt;
bc.
bc needs readline, this can also be added
Ticket URL: <https://trac.osgeo.org/grass/ticket/820#comment:6&gt;
Replying to [comment:6 hellik]:
bc.
a quick test after adding bc and readline to the osgeo4w-track with the
example from the r.in.wms-manual
g.region -p
projection: 1 (UTM)
zone: 10
datum: nad83
ellipsoid: grs80
north: 1.2
south: 0
west: 0
east: 1.2
nsres: 1.2
ewres: 1.2
rows: 1
cols: 1
cells: 1
after starting r.in.wms g.proj.exe is crashing and the following messages:
r.in.wms output=terraserver-drg
mapserver=http://terraserver.microsoft.com/ogcmap6.ashx layers=DRG region=
drg-resolution format=jpeg srs=EPSG:26910
Calculating tiles
c:/osgeo4w/apps/grass/grass-6.4.0svn/scripts/r.tileset:
[0]=SOURCE_PROJ: command not found
[1]=1: command not found
[2]=DEST_PROJ: command not found
[3]=SOURCE_TO_DEST: command not found
[0]=DEST_PROJ: command not found
[1]=SOURCE_PROJ: command not found
[2]=1: command not found
[3]=DEST_TO_SOURCE: command not found
(standard_in) 2: parse error
Rel. 4.7.1, 23 September 2009
<cs2cs.exe>:
projection initialization failure
cause: Unknown error
program abnormally terminated
ERROR: Problem running cs2cs. <Using from definition: >
Ticket URL: <https://trac.osgeo.org/grass/ticket/820#comment:7&gt;
Comment (by hamish):
* If it matters I can probably replace bc with the more common awk to do
the math.
  * No, it really does need to be #!/bin/bash. Variable arrays[n] are not
present in plain old sh, and if you try without bash you get errors like
you see in the previous post.
  * wget can be replaced by curl if it is installed; there's a flag. But
really we/msys should ship a copy of wget in our windows package. (fwiw
Mac ships curl not wget)
  * r.in.wms for 6.4 is a problematic dead end. The new Python rewrite for
grass 7 is where the future is. (using new GDAL/OGR drivers if possible)
  * I half expect more problems to show up as the shell script version of
this module has a number of issues, even on Linux.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/820#comment:8&gt;
Replying to [comment:7 hellik]:
with debug
r.in.wms layers=global_mosaic mapserver=http://wms.jpl.nasa.gov/wms.cgi
output=wms_global_mosaic
c:/OSGeo4W/apps/grass/grass-6.4.0svn/scripts/r.in.wms: eval:
line 1: unexpected EOF while looking for matching `''
line 2: syntax error: unexpected end of file
Calculating tiles
<cs2cs.exe>:
Ticket URL: <https://trac.osgeo.org/grass/ticket/820#comment:9&gt;
Replying to [comment:8 hamish]:
do the math.
installing and shipping bc and readline in the wingrass-installer is no
problem
ah ok. what's about bash in msys, is beyond my knowledge at the moment
osgeo4w ships curl
for grass 7 is where the future is. (using new GDAL/OGR drivers if
possible)
ok
> Hamish
Helmut
Ticket URL: <https://trac.osgeo.org/grass/ticket/820#comment:10&gt;
Replying to [comment:10 hellik]:
not present in plain old sh, and if you try without bash you get errors
like you see in the previous post.
in http://sourceforge.net/projects/mingw/files/ there is bash for msys.
i've changed back to #!/bin/bash in r.tileset-script, bash seems to be
recognized because there's no message like "r.tileset: No such file or
directory".
But at all there is again:
Calculating tiles
<cs2cs.exe>:
Ticket URL: <https://trac.osgeo.org/grass/ticket/820#comment:11&gt;
But really we/msys should ship a copy of wget in our windows package.
(fwiw Mac ships curl not wget)
> osgeo4w ships curl
wget can be download as pre-built-binary from the gnuwin32-website and
integrated in the windows-package
Helmut
Ticket URL: <https://trac.osgeo.org/grass/ticket/820#comment:12&gt;
Comment (by neteler):
Replying to [comment:12 hellik]:
Why should we then ship wget if osgeo4w already ships curl?
Since curl is there is looks more reasonable to get that used at this
point. Apparently the test fails:
# check if we have wget or curl
if [ ! -x "`which wget`" ] ; then
     if [ ! -x "`which curl`" ] ; then
         g.message -e "Either 'wget' or 'curl' is required, please install
one first"
         exit 1
     else
         g.message -v "Using CURL for downloading data."
         USE_CURL=1
     fi
else
     g.message -v "Using WGET for downloading data."
     USE_WGET=1
fi
Perhaps the which magic is non-functional with Msys?
Helmut: could you take out the test in the script and just set
USE_CURL=1
to see what happens then?
Ticket URL: <https://trac.osgeo.org/grass/ticket/820#comment:13&gt;
Replying to [comment:13 neteler]:
flag. But really we/msys should ship a copy of wget in our windows
package. (fwiw Mac ships curl not wget)
install one first"
> exit 1
> else
> USE_CURL=1
> fi
> else
> USE_WGET=1
> fi
> USE_CURL=1
> Markus
i've unset the curl/wget-check and set USE_CURL=1. bash, bc is in the
osgeo4w/msys-stack:
again the same error:
r.in.wms output=elevation_meters mapserver=http://wms.jpl.nasa.gov/wms.cgi
layers=us_ned styles=real -o
Calculating tiles
<cs2cs.exe>:
Ticket URL: <https://trac.osgeo.org/grass/ticket/820#comment:14&gt;
Comment (by cmbarton):
I should also note that awk/gawk doesn't seem to come with msys either.
Other scripts fail in wingrass due to this lack.
Michael
Ticket URL: <https://trac.osgeo.org/grass/ticket/820#comment:15&gt;
Replying to [comment:15 cmbarton]:
> Michael
I've just had a look into the packaging files for the current win-
installer, based on the osgeo4w-msys-stack. awk/gawk is there.
so both should also be in the current WinGrass-Installer.
Helmut
Ticket URL: <https://trac.osgeo.org/grass/ticket/820#comment:16&gt;
I don't have a Windows platform computer and so cannot test directly. I've
just seen scripts fail with the error that awk (or gawk) doesn't exist
with recent winGRASS installations (i.e., not the osgeo4w version of
GRASS).
Michael
Ticket URL: <https://trac.osgeo.org/grass/ticket/820#comment:17&gt;
Please report the current state here.
Ticket URL: <http://trac.osgeo.org/grass/ticket/820#comment:18&gt;
Ticket URL: <http://trac.osgeo.org/grass/ticket/820#comment:19&gt;
