[GRASS-dev] [GRASS GIS] #822: enhance "Save display to graphic file" in wxGUI
Reporter: neteler | Owner: grass-dev@lists.osgeo.org
Component: wxGUI | Version: svn-trunk
Keywords: | Platform: All
      Cpu: All |
In wxGUI, the "Save display to graphic file" is yet rather limited
with respect to what gis.m provided (disk symbol).
Idea: Since d.out.file already generates wxpython code, it could be
recycled in the GUI.
Glynn mentioned on the list:
d.out.file requires a monitor from which to obtain the list of
displayed maps (i.e. d.save). It doesn't have to be an X monitor.
Obviously, the GUI has this information somewhere.
Actually, it has the code as well; see Layer.Render and Map.Render in
render.py.
Ticket URL: <http://trac.osgeo.org/grass/ticket/822&gt;
Resolution: | Keywords:
  Platform: All | Cpu: All
Comment (by cmbarton):
I quit using d.out.file when the interface dropped the xmonitors for a
TclTk canvas. So I haven't followed subsequent updates to the script. What
additional functionality does it have beyond setting resolution?
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/822#comment:1&gt;
Comment (by neteler):
The d.out.file stuff was only an idea. The point of the enhancement
request is an equivalent of
this code chunk in maptool.tcl to be added to the wxGUI:
         # menu for saving display
         set savefile [menu $mapsave.sf -type normal]
         set jpgfile [menu $savefile.jpg -type normal]
         $savefile add command -label "BMP*" -command {MapToolBar::savefile
bmp 0}
         $savefile add cascade -label "JPG*" -menu $jpgfile
                 $jpgfile add command -label [G_msg "low quality (50)"] \
                         -command {MapToolBar::savefile jpg 50}
                 $jpgfile add command -label [G_msg "mid quality (75)"] \
                         -command {MapToolBar::savefile jpg 75}
                 $jpgfile add command -label [G_msg "high quality (95)"] \
                         -command {MapToolBar::savefile jpg 95}
                 $jpgfile add command -label [G_msg "very high resolution
(300% your current resolution)"] \
                         -command {MapToolBar::savefile jpg 300}
         $savefile add command -label "PPM/PNM" -command
{MapToolBar::savefile ppm 0}
         $savefile add command -label "PNG" -command {MapToolBar::savefile
png 0}
         $savefile add command -label "TIF*" -command {MapToolBar::savefile
tif 0}
         $savefile add command -label [G_msg "(* requires gdal)"] -state
disabled
Ticket URL: <http://trac.osgeo.org/grass/ticket/822#comment:2&gt;
The formats to which saving is permitted is determined by the canvas
software (wxPython in this case). It looks like we can easily save to:
bmp, pcx, pnm, and xpm; jpg doesn't work. At least this is what is usable
on my Mac. Do you want this added to 6.4, 6.5, or 7?
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/822#comment:3&gt;
Comment (by glynn):
Replying to [comment:3 cmbarton]:
Or you can convert the PPM/PGM files (from g.pnmcomp) which are displayed
in the canvas using an external package such as !ImageMagick or NetPBM. Or
you can make PIL (Python Imaging Library) an optional dependency and use
that.
But it would be better to re-run the layer commands within an appropriate
environment. This would allow you to use the cairo driver for !PostScript,
PDF or SVG output (or the PS driver for !PostScript output), rather than
being limited to bitmap formats.
Ticket URL: <http://trac.osgeo.org/grass/ticket/822#comment:4&gt;
Except that I can't develop this yet since no one has yet worked out how
to get Cairo for Mac working with GRASS.
Adding more output formats is easy at the moment, although it doesn't
offer the kind of quality that you're talking about. This is also
something to consider for a cartography module for the GUI.
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/822#comment:5&gt;
Reporter: neteler | Owner: grass-dev@…
      Cpu: All |
Comment(by hamish):
see also #977
Ticket URL: <https://trac.osgeo.org/grass/ticket/822#comment:6&gt;
Commonly referred to as GRASS, this is free Geographic Information System (GIS) software used for geospatial data management and analysis, image processing, graphics/maps production, spatial modeling, and visualization. GRASS is currently used in academic and commercial settings around the world, as well as by many governmental agencies and environmental consulting companies. GRASS is an official project of the Open Source Geospatial Foundation.
      Cpu: All |
Comment(by neteler):
In the gis.m is a functionality "Constrain map to region geometry" which
would help to
match computational region and display region in order to produce the
correct world file.
Ticket URL: <http://trac.osgeo.org/grass/ticket/822#comment:7&gt;
Keywords: d.out.file, save image, map display | Platform: All
      Cpu: All |
Changes (by wenzeslaus):
  * keywords: => d.out.file, save image, map display
Comment:
neteler, cmbarton and hamish, how current functionality and G7:d.out.file
(r59010 and r59011, announced in [http://lists.osgeo.org/pipermail/grass-
dev/2014-February/067362.html d.out.file] at grass-dev) influences your
requests here? Can you rephrase requirements? (I really don't know what
''`gis.m` (disk symbol)'' is.)
Apparently, the implementation is not the one suggested by glynn in
comment:4. And #977 is not implemented either.
By the way, who likes the word "graphic" in "Save display to graphic
file"?
Ticket URL: <https://trac.osgeo.org/grass/ticket/822#comment:8&gt;
      Cpu: All |
Replying to [comment:8 wenzeslaus]:
file"?
The word "graphic" is very confusing, better to be changed.
Ticket URL: <http://trac.osgeo.org/grass/ticket/822#comment:9&gt;
      Cpu: All |
Comment(by annakrat):
Replying to [comment:9 neteler]:
file"?
done in r59203
Ticket URL: <http://trac.osgeo.org/grass/ticket/822#comment:10&gt;
      Cpu: All |
Comment(by martinl):
Replying to [comment:10 annakrat]:
> done in r59203
Probably "Save display content to image file" would be more informative?
Ticket URL: <http://trac.osgeo.org/grass/ticket/822#comment:11&gt;
      Cpu: All |
Comment(by wenzeslaus):
Replying to [comment:11 martinl]:
> > done in r59203
The one point is that is should be short.
The other is that it should be easy to understand. "image file" is the
same as "graphic file" it does not add any information, to which kind of
file would I want to save an image and what is that image file anyway,
`.img`? So, to where is clear "file". Alternatively we can leave out the
whole to part. So, we would get "Save display" (my browser also says only
"Save page", it is clear that it will be file or files on the disk).
What to save is more difficult. It is "display", "display content",
"displayed image", "image", "map"? I'm not sure but one word should be
enough. Current "display" is pretty common word in GRASS describes
everything related to displaying maps, so it is OK here I would say. On
the other hand "display" is strange for everybody else.
"Save image" could be enough?
Ticket URL: <http://trac.osgeo.org/grass/ticket/822#comment:12&gt;
      Cpu: All |
Comment(by cmbarton):
'Save display' or 'save window' is better, at least in English.
'Save image' could be confusing (what image?) and possibly misleading
(save the GIS/image file?). What is being done is that what you see in the
display window (technically a graphic canvas) is being written to a
graphic format file of your choice.
In GRASS, most of what goes on is not a display. You can display selected
maps in a window (graphic canvas), of course. Also, this function is
called from a button on the top of that display window. so I don't think
that display is overly generic or confusing in this context. 'Save
Display' is probably the most accurate and descriptive with the fewest
words.
Ticket URL: <http://trac.osgeo.org/grass/ticket/822#comment:13&gt;
