[GRASS-dev] [GRASS GIS] #83: r.param.scale - plan curvature doesn't work
Reporter: guano | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: default | Version: unspecified
Keywords: |
Maps of plan curvature calculated using r.param.scale results in a map
with a very very very narrow distribution (histogram attached), therefore
we can't see any of the features.
Ticket URL: <http://trac.osgeo.org/grass/ticket/83&gt;
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
  Reporter: guano | Owner: guano
      Type: defect | Status: assigned
  Priority: major | Milestone: 6.3.0
Component: default | Version: svn-trunk
Resolution: | Keywords: r.param.scale
Changes (by martinl):
* cc: grass-dev@lists.osgeo.org (added)
Ticket URL: <http://trac.osgeo.org/grass/ticket/83#comment:2&gt;
Changes (by neteler):
  * milestone: 6.3.0 => 6.4.0
Ticket URL: <http://trac.osgeo.org/grass/ticket/83#comment:3&gt;
Comment (by neteler):
# Spearfish
g.region rast=elevation.10m -p
r.param.scale elevation.10m out=planc param=planc
r.univar planc
total null and non-null cells: 2654802
total null cells: 0
Of the non-null cells:
n: 2654802
minimum: -56.0318
maximum: 63.5533
range: 119.585
mean: 0.000136618
mean of absolute values: 0.0203089
standard deviation: 0.0846529
variance: 0.00716612
variation coefficient: 61963.3 %
sum: 362.6935644354
looks like equally distributed to me. The question is: is the color coding
bad or is the result wrong? This could be tested with synthetic curves
(see source:grass/trunk/testsuite/raster/rhemisphere.sh)
Ticket URL: <http://trac.osgeo.org/grass/ticket/83#comment:4&gt;
Commonly referred to as GRASS, this is a Geographic Information System (GIS) used for geospatial data management and analysis, image processing, graphics/maps production, spatial modeling, and visualization. GRASS is currently used in academic and commercial settings around the world, as well as by many governmental agencies and environmental consulting companies. GRASS is official project of the Open Source Geospatial Foundation.
can the end part "Commonly referred to as GRASS..." be removed from the
bug report emails? It doesn't seem to fill any service, and think of the
wasted bytes..
Hamish
      ____________________________________________________________________________________
Be a better friend, newshound, and
know-it-all with Yahoo! Mobile. Try it now. http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
2008/4/28 Hamish <hamish_b@yahoo.com>:
wasted bytes..
should done now.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
  Platform: Unspecified | Cpu: Unspecified
Changes (by hamish):
  * platform: => Unspecified
  * cpu: => Unspecified
Comment:
adding skewness and kurtosis to r.univar would help in diagnosing this
bug. see http://article.gmane.org/gmane.comp.gis.grass.devel/31686/
Ticket URL: <https://trac.osgeo.org/grass/ticket/83#comment:5&gt;
Component: Default | Version: svn-trunk
Keywords: r.param.scale | Platform: Unspecified
      Cpu: Unspecified |
Comment(by helena):
I just tried it out - it is just bad color coding - changing to curvature
color table works. This can be either fixed in the code or just suggest in
the manual to set the color table to curvature. I think this can be
closed.
Ticket URL: <https://trac.osgeo.org/grass/ticket/83#comment:6&gt;
Priority: major | Milestone: 6.4.4
Component: Raster | Version: svn-trunk
      Cpu: Unspecified |
  * component: Default => Raster
  * milestone: 6.4.0 => 6.4.4
Ticket URL: <https://trac.osgeo.org/grass/ticket/83#comment:7&gt;
      Cpu: Unspecified |
Comment(by neteler):
Replying to [comment:6 helena]:
curvature color table works. This can be either fixed in the code
Curvature color code may be taken from here:
http://trac.osgeo.org/grass/browser/grass/branches/releasebranch_6_4/raster/r.slope.aspect/main.c#L1177
Ticket URL: <https://trac.osgeo.org/grass/ticket/83#comment:8&gt;
