[GRASS-dev] [GRASS GIS] #832: menu tree in help menu won't run commands
Reporter: cmbarton | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: normal | Milestone: 6.5.0
Component: wxGUI | Version: svn-develbranch6
Keywords: | Platform: All
      Cpu: All |
Double clicking a menu tree item in the the help/menu tree will not run as
written.
[[BR]]
[[BR]]
RunMenuCmd will only accept an event from selecting a menu object. It
won't run if you pass it a command. Probably a command from this interface
needs to be run through the command-line interface code rather than the
menu event handlers. [[BR]][[BR]]
Also, the static text box needs to be instantiated before its contents are
defined or it is not accessible to Mac users (I don't know about Windows).
Ticket URL: <http://trac.osgeo.org/grass/ticket/832&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords:
  Platform: All | Cpu: All
Changes (by cmbarton):
  * status: new => closed
  * resolution: => fixed
Comment:
Fixed in develbranch_6 r39922 and backported to trunk.
Ticket URL: <http://trac.osgeo.org/grass/ticket/832#comment:1&gt;
Comment (by martinl):
Replying to [comment:1 cmbarton]:
Partly reverted in r39925. Menu items are not only GRASS commands, eval()
is needed to used instead of RunCmd().
Ticket URL: <http://trac.osgeo.org/grass/ticket/832#comment:2&gt;
Comment (by cmbarton):
OK. Did you test?
Ticket URL: <http://trac.osgeo.org/grass/ticket/832#comment:3&gt;
r39928 should make this work with the rest of the menu items.
Ticket URL: <http://trac.osgeo.org/grass/ticket/832#comment:4&gt;
