#837: Memory leaks in r.example
Reporter: sprice | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: default | Version: svn-releasebranch64
Keywords: | Platform: MacOSX
Cpu: Unspecified |
In r.example, there are many small memory leaks in basic functions. Not
only is it bad to have this many leaks in the example module, the leaks
probably persist through many other modules. Here is the location of leaks
in a run of r.example, altered only to print "Done!" & pause before exit.
It seems to mostly be a single leak in find_file(), but there is another
leak in G_gisinit().
(in text GRASS)
GRASS 6.4.0svn (semisup):~ > r.example --o input=landcover
output=landcover.test
r.example(18500) malloc: protecting edges
r.example(18500) malloc: recording malloc stacks to disk using standard
recorder
r.example(18500) malloc: enabling scribbling to detect mods to free blocks
r.example(18500) malloc: stack logs being written into /tmp/stack-
logs.18500.r.example.TQfsBA.index
Done!
^C
sh(18567) malloc: protecting edges
sh(18567) malloc: recording malloc stacks to disk using standard recorder
sh(18567) malloc: enabling scribbling to detect mods to free blocks
sh(18567) malloc: process 18500 no longer exists, stack logs deleted from
/tmp/stack-logs.18500.r.example.TQfsBA.index
sh(18567) malloc: stack logs being written into /tmp/stack-
logs.18567.sh.JvnnBY.index
g.gisenv(18568) malloc: protecting edges
g.gisenv(18568) malloc: recording malloc stacks to disk using standard
recorder
g.gisenv(18568) malloc: enabling scribbling to detect mods to free blocks
g.gisenv(18568) malloc: stack logs being written into /tmp/stack-
logs.18568.g.gisenv.yqOvWQ.index
g.gisenv(18568) malloc: stack logs deleted from /tmp/stack-
g.gisenv(18570) malloc: protecting edges
g.gisenv(18570) malloc: recording malloc stacks to disk using standard
recorder
g.gisenv(18570) malloc: enabling scribbling to detect mods to free blocks
g.gisenv(18570) malloc: stack logs being written into /tmp/stack-
logs.18570.g.gisenv.5s2NuI.index
g.gisenv(18570) malloc: stack logs deleted from /tmp/stack-
g.gisenv(18571) malloc: protecting edges
g.gisenv(18571) malloc: recording malloc stacks to disk using standard
recorder
g.gisenv(18571) malloc: enabling scribbling to detect mods to free blocks
g.gisenv(18571) malloc: stack logs being written into /tmp/stack-
logs.18571.g.gisenv.6FNlZi.index
g.gisenv(18571) malloc: stack logs deleted from /tmp/stack-
sh(18567) malloc: stack logs deleted from /tmp/stack-
(outside of GRASS)
seth:r.example sprice$ leaks r.example
Process 18500: 1701 nodes malloced for 466 KB
Process 18500: 1622 leaks for 25968 total leaked bytes.
Leak: 0x100100040 size=32 zone: DefaultMallocZone_0x100083000 string
'/Users/sprice/grass/semisup'
Call stack: [thread 0x7fff70224be0]: | 0x4 | start | main |
G__gisinit | G_location_path | G__location_path | G__malloc | malloc |
malloc_zone_malloc
Leak: 0x100100380 size=16 zone: DefaultMallocZone_0x100083000 string
'sprice'
get_map_row | get_null_value_row | find_file1 | find_file | G_store |
G__malloc | malloc | malloc_zone_malloc
Leak: 0x1001003c0 size=16 zone: DefaultMallocZone_0x100083000 string
'sprice'
G_raster_map_type | find_file | G_store | G__malloc | malloc |
malloc_zone_malloc
Leak: 0x1001003d0 size=16 zone: DefaultMallocZone_0x100083000 string
'sprice'
G_open_cell_old | G__open_cell_old | find_file | G_store | G__malloc |
Leak: 0x1001003e0 size=16 zone: DefaultMallocZone_0x100083000 string
'sprice'
G_open_cell_old | G__open_cell_old | G_raster_map_type | find_file |
G_store | G__malloc | malloc | malloc_zone_malloc
Leak: 0x1001003f0 size=16 zone: DefaultMallocZone_0x100083000 string
'sprice'
G_open_cell_old | G__open_cell_old | G_get_gdal_link | find_file | G_store
Leak: 0x100100400 size=16 zone: DefaultMallocZone_0x100083000 string
'sprice'
G_open_cell_old | G__open_cell_old | G_get_gdal_link | G_raster_map_type |
find_file | G_store | G__malloc | malloc | malloc_zone_malloc
Leak: 0x100100480 size=16 zone: DefaultMallocZone_0x100083000 string
'sprice'
Leak: 0x100100490 size=16 zone: DefaultMallocZone_0x100083000 string
'sprice'
Leak: 0x100100510 size=16 zone: DefaultMallocZone_0x100083000 string
'sprice'
Leak: 0x100100520 size=16 zone: DefaultMallocZone_0x100083000 string
'sprice'
Leak: 0x100106ba0 size=16 zone: DefaultMallocZone_0x100083000 string
'sprice'
Leak: 0x100106bb0 size=16 zone: DefaultMallocZone_0x100083000 string
'sprice'
Leak: 0x100106bc0 size=16 zone: DefaultMallocZone_0x100083000 string
'sprice'
Leak: 0x1001076e0 size=16 zone: DefaultMallocZone_0x100083000 string
'sprice'
close_new | G_write_range | G_raster_map_type | find_file | G_store |
Leak: 0x100107830 size=16 zone: DefaultMallocZone_0x100083000 string
'sprice'
close_new | G__write_cats | G_raster_map_is_fp | find_file | G_store |
Ticket URL: <http://trac.osgeo.org/grass/ticket/837>
