#838: Compile error for lib/driver
Reporter: sprice | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: default | Version: unspecified
Keywords: | Platform: Unspecified
Cpu: Unspecified |
When compiling the GRASS GIS from SVN source (& RC5), I have this bug
during compilation. I use this line for ./configure:
./configure "CFLAGS=-g -Wall -O" --with-iconv --with-freetype --with-
freetype-includes=/usr/local/include/freetype2 --with-opengl=aqua
--without-tcltk --libdir=/usr/local/lib --with-cxx
But I have this error:
cp -f /usr/local/grass/grass-6.4.svn_src_snapshot_2009_12_12/bin./grass64
/usr/local/grass/grass-6.4.svn_src_snapshot_2009_12_12/dist./grass64.tmp
/usr/bin/install -c tools/mkhtml.sh
/usr/local/grass/grass-6.4.svn_src_snapshot_2009_12_12/dist./tools/
2>/dev/null
build_html_index.sh
Generating HTML manual pages index (help system)...
Generated HTML docs in ../dist./docs/html/index.html
Following modules are missing the 'description.html' file in src code:
GRASS GIS compilation log
Started compilation: Tue Dec 15 12:41:07 MST 2009
Errors in:
/usr/local/grass/grass-6.4.svn_src_snapshot_2009_12_12/lib/driver
/usr/local/grass/grass-6.4.svn_src_snapshot_2009_12_12/lib/pngdriver
/usr/local/grass/grass-6.4.svn_src_snapshot_2009_12_12/lib/psdriver
/usr/local/grass/grass-6.4.svn_src_snapshot_2009_12_12/lib/raster
/usr/local/grass/grass-6.4.svn_src_snapshot_2009_12_12/lib/display
/usr/local/grass/grass-6.4.svn_src_snapshot_2009_12_12/display/drivers/PNG
/usr/local/grass/grass-6.4.svn_src_snapshot_2009_12_12/display/drivers/HTMLMAP
/usr/local/grass/grass-6.4.svn_src_snapshot_2009_12_12/display/drivers/PS
/usr/local/grass/grass-6.4.svn_src_snapshot_2009_12_12/display/d.ask
/usr/local/grass/grass-6.4.svn_src_snapshot_2009_12_12/display/d.barscale
/usr/local/grass/grass-6.4.svn_src_snapshot_2009_12_12/display/d.colorlist
/usr/local/grass/grass-6.4.svn_src_snapshot_2009_12_12/display/d.colors
/usr/local/grass/grass-6.4.svn_src_snapshot_2009_12_12/display/d.colortable
/usr/local/grass/grass-6.4.svn_src_snapshot_2009_12_12/display/d.erase
/usr/local/grass/grass-6.4.svn_src_snapshot_2009_12_12/display/d.extend
/usr/local/grass/grass-6.4.svn_src_snapshot_2009_12_12/display/d.extract
/usr/local/grass/grass-6.4.svn_src_snapshot_2009_12_12/display/d.font
/usr/local/grass/grass-6.4.svn_src_snapshot_2009_12_12/display/d.frame
/usr/local/grass/grass-6.4.svn_src_snapshot_2009_12_12/display/d.geodesic
/usr/local/grass/grass-6.4.svn_src_snapshot_2009_12_12/display/d.graph
/usr/local/grass/grass-6.4.svn_src_snapshot_2009_12_12/display/d.grid
/usr/local/grass/grass-6.4.svn_src_snapshot_2009_12_12/display/d.his
/usr/local/grass/grass-6.4.svn_src_snapshot_2009_12_12/display/d.histogram
/usr/local/grass/grass-6.4.svn_src_snapshot_2009_12_12/display/d.info
/usr/local/grass/grass-6.4.svn_src_snapshot_2009_12_12/display/d.legend
/usr/local/grass/grass-6.4.svn_src_snapshot_2009_12_12/display/d.linegraph
/usr/local/grass/grass-6.4.svn_src_snapshot_2009_12_12/display/d.mapgraph
/usr/local/grass/grass-6.4.svn_src_snapshot_2009_12_12/display/d.measure
/usr/local/grass/grass-6.4.svn_src_snapshot_2009_12_12/display/d.menu
/usr/local/grass/grass-6.4.svn_src_snapshot_2009_12_12/display/d.mon/cmd
/usr/local/grass/grass-6.4.svn_src_snapshot_2009_12_12/display/d.mon/pgms
/usr/local/grass/grass-6.4.svn_src_snapshot_2009_12_12/display/d.nviz
/usr/local/grass/grass-6.4.svn_src_snapshot_2009_12_12/display/d.paint.labels
/usr/local/grass/grass-6.4.svn_src_snapshot_2009_12_12/display/d.path
/usr/local/grass/grass-6.4.svn_src_snapshot_2009_12_12/display/d.profile
/usr/local/grass/grass-6.4.svn_src_snapshot_2009_12_12/display/d.rast
/usr/local/grass/grass-6.4.svn_src_snapshot_2009_12_12/display/d.rast.arrow
/usr/local/grass/grass-6.4.svn_src_snapshot_2009_12_12/display/d.rast.num
/usr/local/grass/grass-6.4.svn_src_snapshot_2009_12_12/display/d.rgb
/usr/local/grass/grass-6.4.svn_src_snapshot_2009_12_12/display/d.rhumbline
/usr/local/grass/grass-6.4.svn_src_snapshot_2009_12_12/display/d.save
/usr/local/grass/grass-6.4.svn_src_snapshot_2009_12_12/display/d.text.new
/usr/local/grass/grass-6.4.svn_src_snapshot_2009_12_12/display/d.thematic.area
/usr/local/grass/grass-6.4.svn_src_snapshot_2009_12_12/display/d.title
/usr/local/grass/grass-6.4.svn_src_snapshot_2009_12_12/display/d.vect
/usr/local/grass/grass-6.4.svn_src_snapshot_2009_12_12/display/d.vect.chart
/usr/local/grass/grass-6.4.svn_src_snapshot_2009_12_12/display/d.what.rast
/usr/local/grass/grass-6.4.svn_src_snapshot_2009_12_12/display/d.what.vect
/usr/local/grass/grass-6.4.svn_src_snapshot_2009_12_12/display/d.where
/usr/local/grass/grass-6.4.svn_src_snapshot_2009_12_12/display/d.zoom
/usr/local/grass/grass-6.4.svn_src_snapshot_2009_12_12/general/g.mapset
/usr/local/grass/grass-6.4.svn_src_snapshot_2009_12_12/imagery/i.ask
/usr/local/grass/grass-6.4.svn_src_snapshot_2009_12_12/raster/r.le/r.le.setup
/usr/local/grass/grass-6.4.svn_src_snapshot_2009_12_12/raster/r.le/r.le.trace
/usr/local/grass/grass-6.4.svn_src_snapshot_2009_12_12/raster/r.profile
/usr/local/grass/grass-6.4.svn_src_snapshot_2009_12_12/raster/wildfire/r.spread
/usr/local/grass/grass-6.4.svn_src_snapshot_2009_12_12/vector/v.label
/usr/local/grass/grass-6.4.svn_src_snapshot_2009_12_12/vector/v.label.sa
In case of errors please change into the directory with error and run
'make'.
If you get multiple errors, you need to deal with them in the order they
appear in the error log. If you get an error building a library, you will
also get errors from anything which uses the library.
Finished compilation: Tue Dec 15 12:49:22 MST 2009
make: *** [default] Error 1
seth:grass-6.4.svn_src_snapshot_2009_12_12 sprice$ cd lib/driver/
seth:driver sprice$ make
cc -dynamiclib -compatibility_version 6.4 -current_version 6.4
-install_name /usr/local/grass-6.4.0svn/lib/libgrass_driver.dylib -o
/usr/local/grass/grass-6.4.svn_src_snapshot_2009_12_12/dist./lib/libgrass_driver.6.4.0svn.dylib
-L/usr/local/grass/grass-6.4.svn_src_snapshot_2009_12_12/dist./lib
OBJ./Bitmap.o OBJ./Box.o OBJ./Client.o OBJ./Color.o OBJ./Cont.o
OBJ./Draw.o OBJ./Erase.o OBJ./Font.o OBJ./Get_location.o OBJ./Get_t_box.o
OBJ./Graph.o OBJ./Line_width.o OBJ./Move.o OBJ./Panel.o OBJ./Polydots.o
OBJ./Polyline.o OBJ./Polygon.o OBJ./Raster.o OBJ./Respond.o OBJ./Returns.o
OBJ./Set_window.o OBJ./Text.o OBJ./Text_size.o OBJ./Work.o OBJ./font2.o
OBJ./font_freetype.o OBJ./init.o OBJ./pad.o OBJ./parse_ftcap.o
OBJ./text2.o OBJ./text3.o OBJ./main.o OBJ./command.o OBJ./connect_sock.o
-lgrass_gis -lgrass_datetime -lz -lfreetype -liconv && \
(cd
/usr/local/grass/grass-6.4.svn_src_snapshot_2009_12_12/dist./lib; ln -f -s
/usr/local/grass/grass-6.4.svn_src_snapshot_2009_12_12/dist./lib/libgrass_driver.dylib)
Undefined symbols:
"_libiconv_close", referenced from:
_draw_main in text3.o
"_libiconv", referenced from:
"_libiconv_open", referenced from:
ld: symbol(s) not found
collect2: ld returned 1 exit status
make: ***
[/usr/local/grass/grass-6.4.svn_src_snapshot_2009_12_12/dist./lib/libgrass_driver.6.4.0svn.dylib]
Error 1
So the simple fix for it is to add "-L/usr/local/lib" to the cc command.
You can see from my './configure' above that I tried to force it to use
the correct library directory, but somehow this is lost when compiling the
driver. So I just copy-paste in the correct flag, and compile proceeds as
it should.
seth:driver sprice$ cc -dynamiclib -compatibility_version 6.4
-current_version 6.4 -install_name
-L/usr/local/lib && (cd
seth:driver sprice$ cd -
seth:grass-6.4.svn_src_snapshot_2009_12_12 sprice$ make
I'm filing this bug in the hopes that someone forgot to included the flag
somewhere in the make process, and we can fix that.
Ticket URL: <http://trac.osgeo.org/grass/ticket/838>
