[GRASS-dev] [GRASS GIS] #839: wxGUI: About GRASS menu item broken
Reporter: hamish | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: major | Milestone: 6.5.0
Component: wxGUI | Version: svn-develbranch6
Keywords: | Platform: Linux
      Cpu: x86-64 |
Hi
in the 6.5 wxGUI if I do `Help -> About GRASS GIS` I get this error in the
layer manager output tab:
   File "/usr/src/grass/svn/grass65/dist.x86_64
-unknown-linux-gnu/etc/wxpython/wxgui.py", line 554, in
OnAboutGRASS
win = AboutWindow(self)
-unknown-linux-gnu/etc/wxpython/gui_modules/help.py", line
406, in __init__
transwin = self.PageTranslators()
601, in PageTranslators
label = name))
   File "/usr/lib/python2.5/site-
packages/wx-2.8-gtk2-unicode/wx/_controls.py", line 1136, in
__init__
_controls_.StaticText_swiginit(self,_controls_.new_StaticTex
t(*args, **kwargs))
UnicodeDecodeError
'ascii' codec can't decode byte 0xc3 in position 1: ordinal
not in range(128)
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/839&gt;
Resolution: | Keywords:
  Platform: Linux | Cpu: x86-64
Comment (by cmbarton):
It looks like this could be fixed in the most up-to-date svn version of
6.5. When I look at line 601 it is different that the line reported in
this error.
Michael
Ticket URL: <https://trac.osgeo.org/grass/ticket/839#comment:1&gt;
Comment (by hamish):
nope, still broken today. Now it says line 550, 409, 604, 1136
respectively.
Ticket URL: <https://trac.osgeo.org/grass/ticket/839#comment:2&gt;
I found the location but have no idea why you are getting an error.
I also found out that on the Mac these new files translator.cvs and
contributor.cvs are not getting moved to $GISBASE/etc to be found by About
GRASS. I moved them manually to test and still got no error. There is
nothing odd about the code.
Has anyone else had an error with About GRASS?
Michael
Ticket URL: <https://trac.osgeo.org/grass/ticket/839#comment:3&gt;
Comment (by marisn):
Replying to [comment:2 hamish]:
respectively.
Could this be locale-dependent issue? Michael is using en_US locale and
thus all unicode/anycode text == ascii, which may not be true for other
locales. Just guessing without reading code.
Ticket URL: <https://trac.osgeo.org/grass/ticket/839#comment:4&gt;
Ah. Sorry. Pasted reply without testing.
Michael:
export LC_ALL=de_DE
export LANG=de_DE
g.gui gui=wxpython
Ticket URL: <https://trac.osgeo.org/grass/ticket/839#comment:5&gt;
Replying to [comment:4 marisn]:
> locale and thus all unicode/anycode text == ascii, which may not
> be true for other locales. Just guessing without reading code.
perhaps, but I don't think so. I'm pretty sure the workstation I was
testing on before is set up as LANG=C, and on a second machine here I'm a
little surprised to see it is actually set to en_NZ instead of C or en_US.
(usually it's just less trouble that way, and dealing with the spelling
differences isn't a big deal, I just resolve myself to spelling poorly in
both contexts :wink:
On this second machine it works -- same debian version, only difference
AFAIK is 32bit P4 instead of 64bit AMD. shrug. does it fail for anyone
else? ubuntu users?
I also found that the 2 .csv files were missing, but the translators and
contributers tabs are missing unless I drag the window wider. also the
translators tab is open upon launch, but the info one should be. also I
find scrolling with the mouse wheel down the gpl and authors list that the
text is ''highly'' jumpy. is "contributers" redundant; shouldn't we just
take care to merge that into Authors? (?)
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/839#comment:6&gt;
t(*args, **kwargs))
UnicodeDecodeError
not in range(128)
Ok maybe I can expand on Maris's theory. What if the translators.csv file
has unicode symbols in it, but my LANG=C monolanguage install is too
ignorant to deal with that?
I see non-ascii chars in the names of the Vietnamese and Czech
translators. I bet if I anglify those it'll work.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/839#comment:7&gt;
  Reporter: hamish | Owner: martinl
      Type: defect | Status: assigned
Changes (by martinl):
* cc: grass-dev@lists.osgeo.org (added)
  * owner: grass-dev@lists.osgeo.org => martinl
  * status: new => assigned
Comment:
Replying to [comment:7 hamish]:
> t(*args, **kwargs))
> UnicodeDecodeError
> not in range(128)
file has unicode symbols in it, but my LANG=C monolanguage install is too
Right, hopefully fixed in r40034.
Martin
Ticket URL: <https://trac.osgeo.org/grass/ticket/839#comment:8&gt;
Martin:
nice, it now launches.
still todo:
  - the stuttering effect is still quite bad for all scrolling pages,
leaving garbage in its wake for the new .csv tabs only. see attached
screenshot
  - you'll notice in that screenshot that the Translators tab is missing.
if the widget used to make the tabs doesn't have <- arrows -> to move onto
extra tabs, the only thing I can think of is to make the default window
size a bit wider. On this one machine it has to be 600px wide for all tabs
to display. I think on the other machine I tried it on the number was
about 640px. I guess it depends on local font size.
  - the version screen should come up first when you open the window, not
the translators list.
thanks,
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/839#comment:9&gt;
Comment (by martinl):
Replying to [comment:9 hamish]:
> still todo:
screenshot
It's seems to be a wxPython bug.
done in r40056.
should be done automatically, in r40057 is called {{{SetSelection}}}
explicitly.
Martin
Ticket URL: <http://trac.osgeo.org/grass/ticket/839#comment:10&gt;
Replying to [comment:10 martinl]:
ok, will ignore.
> > is missing.
> done in r40056.
now it's obvious; thanks.
> > the window, not the translators list.
> {{{SetSelection}}} explicitly.
now works for me, thanks.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/839#comment:11&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords:
  * status: assigned => closed
  * resolution: => fixed
Ticket URL: <https://trac.osgeo.org/grass/ticket/839#comment:12&gt;
