#843: v.digit broken on new WinGrass release
Reporter: cnielsen | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: Vector | Version: unspecified
Keywords: wingrass,v.digit | Platform: MSWindows XP
Cpu: x86-64 |
Vector digitizing windows open properly, both in the tcltk and the new
wxpython menu item.
However after a feature is digitized, as I right-click to finish the
feature, the window closes and the following error message shows up in the
"Output" window or "Command output" tab depending on the GUI
v.digit map=test2@user1
ERROR: F_open is not supported on Windows
Building topology for vector map <test2>...
Registering primitives...
2 primitives registered
18 vertices registered
Building areas...
0 areas built
0 isles built
Attaching islands...
Attaching centroids...
Ticket URL: <http://trac.osgeo.org/grass/ticket/843>
