#849: command line completion and tips do not show up
Reporter: timmie | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 6.5.0
Component: wxGUI | Version: svn-develbranch6
Resolution: | Keywords:
Platform: Unspecified | Cpu: Unspecified
Comment (by cmbarton):
Command line autocompletion and calltips work on Mac as of r40166. But
find does not. Find by description shows 'x modules found' in the status
bar but nothing else. Find by keyword produces the following error.
File "/Users/cmbarton/grass_dev/grass65_dev/dist.i386
-apple-darwin10.2.0/etc/wxpython/gui_modules/goutput.py",
line 572, in OnSearchModule
if self.__checkKey(text, data['keywords']):
AttributeError
'GMConsole' object has no attribute '_GMConsole__checkKey'
AttributeError
AttributeError
AttributeError
AttributeError
AttributeError
AttributeError
AttributeError
AttributeError
(NB: the keywords are so general that I'm not sure that keyword searches
are very helpful to most users). Also, the output window needs to trap
command as well as control as I had it before. In fact, if it traps
command, it traps both the Mac Cmd and Linux/Windows Ctrl meta keys for
copy/paste.
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/849#comment:1>
