[GRASS-dev] [GRASS GIS] #855: d.text: rotate needs to rotate the background box too
Reporter: hamish | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: Display | Version: svn-releasebranch64
Keywords: d.text | Platform: All
      Cpu: All |
as pointed out by Rich Shepard on the users mailing list, d.vect fails to
also rotate the background color-box along with the text.
there is already rendering code in d.labels to do this, it just needs to
be incorporated into the d.text code.
Also, if you had set the background color to "none" it was still getting
drawn but using the same color as the text. I've just fixed that in 6.5svn
(r40214). Previously the test for drawing background was just if the
bgcolor= option was used at all.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/855&gt;
  Priority: normal | Milestone: 6.5.0
Component: Display | Version: svn-develbranch6
Resolution: | Keywords: d.text
  Platform: All | Cpu: All
Changes (by hamish):
  * version: svn-releasebranch64 => svn-develbranch6
  * milestone: 6.4.0 => 6.5.0
Comment:
bgcolor= does not exist for 6.4, it's new for 6.5+
Ticket URL: <https://trac.osgeo.org/grass/ticket/855#comment:1&gt;
Reporter: hamish | Owner: grass-dev@…
      Cpu: All |
Comment(by nikos):
Will this eventually end up in the 64th release?
Ticket URL: <https://trac.osgeo.org/grass/ticket/855#comment:2&gt;
      Cpu: All |
Comment(by hamish):
Replying to [comment:2 nikos]:
before considering backporting options from the development branches to
the stable branches, first it has to be working properly in the
development version. so far it isn't.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/855#comment:3&gt;
Priority: normal | Milestone: 6.4.4
      Cpu: All |
  * milestone: 6.5.0 => 6.4.4
Old description:
6.5svn (r40214). Previously the test for drawing background was just if
the bgcolor= option was used at all.
Hamish
New description:
as pointed out by Rich Shepard on the users mailing list, d.text fails to
Hamish
Comment:
background box of d.text still not rotating..
Ticket URL: <https://trac.osgeo.org/grass/ticket/855#comment:4&gt;
