#856: r.proj fails in WinGRASS-6.4.0SVN-r40049-1
Reporter: malicera | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: Raster | Version: svn-releasebranch64
Keywords: r.proj fails | Platform: MSWindows Vista
Cpu: x86-32 |
I am experience the same as bug #736 or http://n2.nabble.com/r-proj-exe-
has-stopped-working-td3500149.html.
As it was already closed, could it be related to the PROJ's development?
I have just tried r.proj on WinGrass 6.4.0svn r40049 binary + XP.
I reprojected elevation.dem and elevation.10m into a lat/lon wgs84
location from Spearfish at appropriate resolution (g.region -m). No
problems.
can you provide more detail about your input map (rows,cols,etc) and
source/target projections? can you get it to fail using one of the demo
locations? (spearfish or NC)
> PROJ's development?
No idea, but I'd guess that it is a second, unrelated problem to the
previous bug.
Replying to [comment:1 hamish]:
> Hi,
problems.
> > PROJ's development?
previous bug.
> Hamish
i've tested r.proj (self-compiled WinGrass r40386) with a DEM from
EPSG:31287 to EPSG:31286, everything works.
Helmut
btw a next WinGrass-Installer (r40386) should be available soon
