[GRASS-dev] [GRASS GIS] #86: d.rast.edit: new script needs docs ported from old C module
Reporter: hamish | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: Docs | Version: unspecified
Keywords: |
this was doc issue # 406 on the old Gforge tracker. Moving it here
there's a fancy new Tcl d.rast.edit module in CVS, but its
scripts/d.rast.edit/description.html file is mostly empty.
The relevant bits need to be "ported" from the old C version, in
display/d.rast.edit/description.html. Lots
of that will be irrelevant, so a straight copy is no good.
e.g. explain what the aspect option is used for.
thanks,
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/86&gt;
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
      Type: task | Status: new
Resolution: | Keywords:
Changes (by hamish):
  * type: defect => task
Ticket URL: <http://trac.osgeo.org/grass/ticket/86#comment:1&gt;
#86: d.rast.edit.tcl: doesn't start from wxPython without aspect map
Component: Tcl | Version: 6.4.0 RCs
  Platform: Unspecified | Cpu: Unspecified
  * component: Docs => Tcl
  * summary: d.rast.edit: new script needs docs ported from old C module
              => d.rast.edit.tcl: doesn't start from wxPython
              without aspect map
  * platform: => Unspecified
  * version: unspecified => 6.4.0 RCs
  * type: task => defect
  * cpu: => Unspecified
Comment:
help page edits done in r36170 etc.
grass7 wxpython version of d.rast.edit needs to be checked for
compatibility.
from the wxpython gui in 6.4.0rc3 WinGrass, trying to launch
d.rast.edit.tcl gives an error:
Error in startup script
no such variable
(read trace on "env(GIS_OPT_ASPECT)")
invoked from within "set aspect $env(GIS_OPT_ASPECT)"
(file "C:/OSGeo4W/.../etc/d.rast.edit.tcl line 15)
[OK]
aspect= should be optional.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/86#comment:2&gt;
Reporter: hamish | Owner: grass-dev@…
Priority: major | Milestone: 6.4.3
Component: Tcl/Tk | Version: 6.4.0 RCs
Keywords: d.rast.edit, wingrass | Platform: MSWindows XP
      Cpu: Unspecified |
  * keywords: => d.rast.edit, wingrass
  * platform: Unspecified => MSWindows XP
  * milestone: 6.4.0 => 6.4.3
Comment:
in the 6.4.2rc3 standalone wingrass installer Raster -> Change cat values
and labels -> Interactively edit cat values (launches Glynn's tcl/tk
d.rast.edit tool) still gives the same "aspect map" error. if you give it
an aspect map then it starts up ok.
it works ok for me on linux.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/86#comment:3&gt;
Component: wxGUI | Version: 6.4.0 RCs
      Cpu: Unspecified |
  * component: Tcl/Tk => wxGUI
Ticket URL: <https://trac.osgeo.org/grass/ticket/86#comment:4&gt;
      Cpu: Unspecified |
Comment(by hamish):
requirement to have an aspect map for wingrass avoided in devbr6 with
r56745.
traceback and crash due to gcmd.py's `env = copy.deepcopy(self.env)`
returning None side-stepped in devbr6 with r56751. I'm not sure if that
actually makes a difference to the actually-needed search path since it's
sys.path not os's $PATH, but it seems to work and doesn't make the
PYTHONPATH list longer each time you run something, so even if it's
useless it's not too polluting.
I notice when the module is done (on linux) the wxGUI module wrapper never
returns, you have to close it with the windows's upper-right "X" button
since the close button remains shaded out. Also error messages (such as
map already exists and no --o given) end up in the terminal not the wxGUI
output window.
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/86#comment:5&gt;
Priority: major | Milestone: 6.4.4
      Cpu: Unspecified |
  * milestone: 6.4.3 => 6.4.4
Comment:
mandatory aspect map fix and wingrass PATH env work-around backported to
6.4svn in r56784.
the d.rast.edit.tcl module gui still never gets the message that the child
process has returned (both Windows and Linux), stays with greyed out
buttons until you "X" its window, and the no --overwrite error message
still ends up in the cmd.exe terminal window, but neither is critical for
6.4.3 so bumping down the road.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/86#comment:6&gt;
      Cpu: Unspecified |
Comment(by hamish):
for the record: aspect maps + d.rast.edit.tcl work on WinGrass now, so the
aspect map workaround isn't just ignoring a bigger problem. (it may well
be ignoring some other problem, but seeing that tcl from wx on wingrass is
pretty rare, I'll worry about that problem when it arrives)
Ticket URL: <https://trac.osgeo.org/grass/ticket/86#comment:7&gt;
      Cpu: Unspecified |
Comment(by wenzeslaus):
The original description does not match the summary. It is not clear what
the ticket is about. If it is not bothering anybody, I suggest to close it
as fixed or wontfix, whatever is appropriate.
Create a new ticket if needed.
Ticket URL: <http://trac.osgeo.org/grass/ticket/86#comment:8&gt;
