#862: winGRASS path detection fails in Japanese locale (¥ instead of \ is used
for c:\ etc)
Reporter: neteler | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: new
Priority: blocker | Milestone: 6.4.0
Component: default | Version: svn-releasebranch64
Keywords: | Platform: MSWindows XP
Cpu: All |
There is a failure in interpreting the GRASS paths in Japanese locale:
C:¥Program Files¥GRASS-6-SVN>g.gui help
'g.gui' は、内部コマンドまたは外部コマンド、
操作可能なプログラムまたはバッチ ファイルとして認識されていません。
(Rough Translation: "g.gui internal or external command,
Not recognized as an operable program or batch file.")
If I change directly into the GRASS binary path, it works:
C:¥Program Files¥GRASS-6-SVN>cd bin
C:¥Program Files¥GRASS-6-SVN¥bin>g.gui help
Description:
Launches a GRASS graphical user interface (GUI) session.
The paths look like this:
C:¥Program Files¥GRASS-6-SVN¥bin>path
PATH=C:¥PROGRA‾1¥GRASS-6-SVN¥tcl-
tk¥bin;C:¥PROGRA‾1¥GRASS-6-SVN¥sqlite¥bin;C:¥PR
OGRA‾1¥GRASS-6-SVN¥gpsbabel;C:¥PROGRA‾1¥GRASS-6-SVN¥extrabin;C:¥PROGRA‾1¥GRASS-6
-SVN¥extralib;C:¥PROGRA‾1¥GRASS-6-SVN¥msys¥bin;C:¥Program
Files¥ruby¥bin;C:¥Prog
ram
Files¥ThinkPad¥Utilities;C:¥WINDOWS¥system32;C:¥WINDOWS;C:¥WINDOWS¥System32¥
Wbem;C:¥Program Files¥IBM ThinkVantage¥Client Security
Solution;C:¥ms4w¥Apache¥c
gi-bin;C:¥Program Files¥MySQL¥MySQL Server 5.1¥bin
The same will apply to Chinese, Korean, various Indian etc. locales.
for c:\ etc)
Priority: normal | Milestone: 6.4.0
Resolution: | Keywords:
Platform: MSWindows XP | Cpu: All
Changes (by neteler):
* priority: blocker => normal
* type: defect => enhancement
Comment:
OK, my bad. The point is that when starting GRASS in cmd.exe, the terminal
does NOT become a GRASS shell (see prompt below). Not surprisingly nothing
works.
Changing into enhancement: grass64.bat should print into the terminal that
it is GUI-only and not a GRASS shell and that for a GRASS shell the user
should use a different menu entry. This would reduce the (potential)
confusion...
But I am not sure where this message (better worded) should go.
