#867: WinGrass64-compiling: `libintl_printf' is an unrecognized format function
type'
Reporter: hellik | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: Packaging | Version: svn-releasebranch64
Keywords: | Platform: MSWindows Vista
Cpu: x86-32 |
i've compiled the Grass64-releasebranch in the osgeo4w-stack on WinVista32
(--nls enabled).
unfortunately I wasn't all the building time in front of my laptop and
couldn't catch all the messages, but I've seen in a few-modules (raster
and vector etc.; i.e. nviz, v.what, v.out.pov, v.support, v.transform,
v.to.db ) following warnings:
`libintl_printf' is an unrecognized format function type'
type'
Priority: minor | Milestone: 6.4.0
Resolution: | Keywords:
Platform: MSWindows Vista | Cpu: x86-32
Changes (by glynn):
* priority: normal => minor
Comment:
Replying to [ticket:867 hellik]:
That's why you should redirect output to a file, e.g.
make &> build.log
> but I've seen in a few-modules (raster and vector etc.; i.e. nviz,
v.what, v.out.pov, v.support, v.transform, v.to.db ) following warnings:
I count 77 distinct occurrences (each one will generate multiple warnings,
one for each occurrence of `__attribute__((format(printf,...)))` in
gisdefs.h or G3d.h.
Downgrading to "minor", as these are only warnings.
They could be silenced by re-defining __attribute__ to an empty macro (as
we do if __GNUC__ isn't defined).
We could eliminate the redirection to libintl_printf, as none of the
translations are currently using the %1$ syntax (which the MSVCRT printf()
doesn't support, hence the redirection). However, chances are we'll forget
to re-instate it if we ever need it.
type'
Reporter: hellik | Owner: grass-dev@…
Component: Compiling | Version: svn-releasebranch64
Keywords: wingrass | Platform: MSWindows Vista
Cpu: x86-32 |
Comment(by hellik):
Replying to [comment:1 glynn]:
