#869: Compile libs with -fexception
Reporter: rblazek | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: closed
Priority: normal | Milestone: 6.5.0
Component: Compiling | Version: unspecified
Resolution: worksforme | Keywords:
Platform: Unspecified | Cpu: All
Comment (by glynn):
Replying to [comment:2 rblazek]:
> Well, I expected something like that, but I must say, that I did not
expect, that you want "to make life harder for anyone trying to use the
GRASS libraries". I always thought that you are just ignoring them.
As it appears not have been obvious, the comment wasn't entirely serious.
Although it's not without some basis.
> I think that this ticket should be closed as wontfix, not worksforme.
I spent some time thinking about this, and concluded that "worksforme" is
correct. The libraries work for their intended purpose, i.e. GRASS
modules. "wontfix" implies that there's something to fix.
> Can you discover more about how you want to disable use of GRASS
libraries, it could save us wasting time.
It's not that I'm actually planning to disable anything, just that making
any changes which make their intended uses harder for the benefit of
unintended use would occur over my dead body (well, my departure). Ditto
for foregoing changes which would make intended use easier (e.g. recent
changes to 7.0 mean that functions such as Rast_open_* and
Rast_{get,put}_row now generate a fatal error, so callers don't have to
deal with this themselves).
In that regard, -fexceptions doesn't benefit GRASS itself in any way,
would require various configure checks to ensure that the compiler
actually supports that flag, increases memory usage (according to the gcc
docs), and may not actually help you at all (because unwinding the stack
isn't going to magically revert any incomplete modifications, so there's
no guarantee that the next call to a library function won't just segfault;
and that's not a bug; once G_fatal_error() has been called, all bets are
off).
Ticket URL: <http://trac.osgeo.org/grass/ticket/869#comment:6>
