[GRASS-dev] [GRASS GIS] #87: GIS.m: Fancy Map Display statusbar coords in Lat/Lon
Reporter: hamish | Owner: grass-dev@lists.osgeo.org
Priority: minor | Milestone: 6.4.0
Component: Tcl | Version: unspecified
Keywords: |
This was code request # 401 over at the old Gforge bug tracker. Moving it
here.
http://wald.intevation.org/tracker/index.php?func=detail&aid=401&group_id=21&atid=188
I would love for Lat/Lon locations to format the Map Display statusbar x,y
string into 45°59.9999'S 170°59.9999'W.
Hamish:
>>> set mapunits [MapCanvas::get_mapunits]
>>> if { [string first "degree" $mapunits ] >= 0 } {
>>> set outfmt_coords {%.6f}
>>> } else {
>>> set outfmt_coords {%.3f}
Michael:
> > This is a procedure I didn't know about. Did you write it? Seems
> > handy. I might write something similar in wxgrass.
H:
>> Yes, I wrote it to stabilize the x,y coords in the bottom right corner
>> of the GIS.m Map Display window. I would love for Lat/Lon locations
>> to munge the string into 45°59.9999'S 170°59.9999'W.
M:
> Why can't this just be built into your get_mapunits procedure? I can add
it
> to the statusbar easily enough.
because that calls g.proj to get the units. You only need to do that once
at init to set a global variable. You really don't want to be calling a
module twice every time the mouse moves 1 pixel.
Python/SWIG:
# test the string made by (eg "degrees")
python_grass6.G_database_unit_name(int plural) # ie 0 or 1
> BUT is there a way to get the degree symbol that works on all platforms?
Does this show a degree symbol on the Mac?
$ echo "puts \xB0; exit" | wish
here is some non-functional demo Tcl code:
init {
    global is_ll
    if {string first "degree" $mapunits ] >= 0 } {
       set is_ll 1
    } else {
       set is_ll 0
    if { is_ll } {
        # failsafe, will try for fancy fmt later
    } else {
bind $can($mon) <Motion> {
   global mon
   global is_ll
   set scrxmov %x
   set scrymov %y
   if { is_ll } {
      set eastcoord [fmt_latlon [eval MapCanvas::scrx2mape $mon %x] 0]
      set northcoord [fmt_latlon [eval MapCanvas::scry2mapn $mon %y] 1]
   } else {
      set eastcoord [format $outfmt_coords [eval MapCanvas::scrx2mape $mon
%x] ]
      set northcoord [format $outfmt_coords [eval MapCanvas::scry2mapn $mon
%y] ]
   set coords($mon) "$eastcoord $northcoord"
proc fmt_latlon { num, is_latitude } {
      global is_ll
      # units are degrees
      # _d means integer, _f means float
      set deg_d [expr num - (num%1) ]
      set min_f [expr (num%1)*60 ]
      set min_d [expr min_d - (min_d%1) ]
      set sec_f [expr (min_f%1)*60 ]
      if { is_latitude } {
        if { num > 0 } {
           set hem_str "N"
        } elif { num == 0 } {
           set hem_str ""
        } else {
           set hem_str "S"
      } else {
        if { num > 0 } {
           set hem_str "E"
           set hem_str ""
        } else {
           set hem_str "W"
      set num_fmt [concat [format {%3d} deg] "\xB0" \
         [format {%02d} min_d] {'} \
         [format {%.5} sec_f] {"" } $hem_str ]
     return num_fmt
Hamish
Date: 2007-05-22
Sender: Hamish B
slight adjustment:
move that into the {is_ll} bit and if LL put $northcoord first.
Hamish
I guess if the degree symbol is not portable for display a "d " or just a
space could be used, but its not as nice.
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/87&gt;
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
      Type: task | Status: new
  Priority: major | Milestone: 6.4.0
Component: Tcl | Version: svn-develbranch6
Resolution: | Keywords:
  Platform: All | Cpu: All
Changes (by hamish):
  * priority: minor => major
  * platform: => All
  * version: unspecified => svn-develbranch6
  * type: enhancement => task
  * cpu: => All
Comment:
I'd like to see this happen for the 6.4.0 release.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/87#comment:1&gt;
Comment (by hamish):
note the wxPython GUI includes this feature, so only relevant to the
Tcl/Tk GUI.
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/87#comment:2&gt;
Resolution: | Keywords: gis.m, LL
  * keywords: => gis.m, LL
Comment:
committed to devbr6 in r37710.
TODO:
  * add a UI control to switch between DMS, DMM.MMM, and D.DDD (all there
in the code now, just modify the dms_format setting to change)
  * learn via feedback how portable &deg; symbol is.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/87#comment:3&gt;
  * priority: major => minor
Ticket URL: <https://trac.osgeo.org/grass/ticket/87#comment:4&gt;
