[GRASS-dev] [GRASS GIS] #877: wxGUI: Location wizard bug when creating LatLong location
Reporter: neteler | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: blocker | Milestone: 6.4.0
Component: wxGUI | Version: svn-releasebranch64
Keywords: location wizard | Platform: MSWindows Vista
      Cpu: Unspecified |
* Launch winGRASS
  * On the right-hand side select Location Wizard under Define new location
  * Leave the GIS Data Directory field as is but choose a descriptive name
for the Project Location
  * Continue to the next page
  * Choose Select Coordinate System parameters from a list and continue
  * Type in ll for the Projection Code (or scroll down the page to find
Lat/Lon)
  * Keep "Datum with associated ellipsoid"
  * Continue to the next page: bug appears "You must enter a value for
Central Meridian" although values are inserted
See attached screenshot.
Ticket URL: <http://trac.osgeo.org/grass/ticket/877&gt;
Resolution: | Keywords: location wizard
  Platform: MSWindows Vista | Cpu: Unspecified
Comment (by cmbarton):
I just tried this and it works fine for me. No error if I duplicate your
steps. You are doing this in 6.4 release branch right?
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/877#comment:1&gt;
Comment (by neteler):
Yes, I used the winGRASS package from the GRASS web site. The same was
also confirmed by at least two other people (see mailing list). How can I
debug this?
Ticket URL: <http://trac.osgeo.org/grass/ticket/877#comment:2&gt;
Is it happening on Linux too, or only on Windows? It's not happening on
the Mac.
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/877#comment:3&gt;
It is a Windows-only bug.
Ticket URL: <http://trac.osgeo.org/grass/ticket/877#comment:4&gt;
Resolution: | Keywords: location wizard, wingrass
Changes (by hamish):
  * keywords: location wizard => location wizard, wingrass
Ticket URL: <http://trac.osgeo.org/grass/ticket/877#comment:5&gt;
OK. I'll take a look at the code with that in mind. I won't be able to
test, but maybe I can see something
Ticket URL: <http://trac.osgeo.org/grass/ticket/877#comment:6&gt;
Comment (by mmetz):
Attached patch works for me under Linux and Windows XP. The logic for this
fix is that a default value was set and then got lost, therefore the error
message, so it sets the default value again for all parameters that are
not editable. Doesn't really make sense to me but works, and maybe it
points into the right direction for a better fix.
Markus M
Ticket URL: <http://trac.osgeo.org/grass/ticket/877#comment:7&gt;
  Reporter: neteler | Owner: martinl
      Type: defect | Status: assigned
Changes (by martinl):
* cc: grass-dev@lists.osgeo.org (added)
  * owner: grass-dev@lists.osgeo.org => martinl
  * status: new => assigned
Comment:
Replying to [comment:7 mmetz]:
this fix is that a default value was set and then got lost, therefore the
error message, so it sets the default value again for all parameters that
are not editable. Doesn't really make sense to me but works, and maybe it
right, committed in r40524. I am going to rewrite this part in devbr6 and
trunk, so not backported. Martin
Ticket URL: <http://trac.osgeo.org/grass/ticket/877#comment:8&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: location wizard, wingrass
  * status: assigned => closed
  * resolution: => fixed
Ticket URL: <http://trac.osgeo.org/grass/ticket/877#comment:9&gt;
      Type: defect | Status: reopened
Changes (by lponti):
  * status: closed => reopened
  * resolution: fixed =>
Comment:
I am re-opening this because a similar problem happens with recent
WinGRASS-6.4.SVN-r40650-1-Setup.exe (26-Jan-2010 03:47) on Windows 7.
First report was on Windows Vista: please, see
http://n2.nabble.com/Location-Wizard-Problem-tp4281871p4460300.html
Text input boxes for Central Parallel and Central Meridian are grayed, and
show 0.0 preset answer with no way to modify it (you can put cursor in the
text box and highlight 0.0 but there is no way to enter text).
Luigi
Ticket URL: <http://trac.osgeo.org/grass/ticket/877#comment:10&gt;
I think that the greyed out fields are correct (what to you want to change
there?). But do you get the bug "You must enter a value for Central
Meridian" although values are inserted?
Luigi: I tried it on a Japanese XP and it worked. Do you use the English
or Italian version?
Ticket URL: <http://trac.osgeo.org/grass/ticket/877#comment:11&gt;
Comment (by hamish):
0.0,0.0 is correct. you want 0 lat, 0 lon to be somewhere south of Ghana.
Maybe for lat/lon we should hide those.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/877#comment:12&gt;
Comment (by lponti):
Sorry for my ignorance, Hamish. That behavior (not being able to change
greyed fields) has been reported as a problem on the mailing list (see
link in my previous comment) so I thought it was a problem:
> When I try to enter a Central Parallel or Central Meridian, nothing
> changes occur in the entry boxes. I can highlight the default zero
> values, but I am unable to change them.
However, I don't get the "You must enter a value for Central Meridian"
bug, and the location gets created OK. Again I am on Win7 and no spaces in
installation path -- maybe it is related to the latter?
I think I am using an Italian version: there is a mix of Italian and
English language.
I apologize again for an incomplete report,
Luigi
Ticket URL: <http://trac.osgeo.org/grass/ticket/877#comment:13&gt;
Replying to [comment:13 lponti]:
To my knowledge the original issue was then you could not proceed on
*some* platforms/computers. The fields are currently intentionally greyed
out since it is not the definition of a custom projection (that's in
another wizard section AFAIK).
So - everything fine on your's and my computer.
English language.
[unrelated: because the translation isn't finished, support welcome]
Ticket URL: <http://trac.osgeo.org/grass/ticket/877#comment:14&gt;
  * status: reopened => closed
Comment:
no reason to keep this one open AFAIK.
Ticket URL: <https://trac.osgeo.org/grass/ticket/877#comment:15&gt;
