[GRASS-dev] [GRASS GIS] #879: Add a "change language" option in GRASS GUI
Reporter: antoniorocha | Owner: grass-dev@lists.osgeo.org
Priority: normal | Milestone: 6.4.0
Component: wxGUI | Version: unspecified
Keywords: | Platform: Unspecified
      Cpu: Unspecified |
Instead of changing GRASS language in init.bat files (or other), the user
would change its language without quitting GRASS session.
Hamish comment was:
I would suggest to put it in Config->GRASS working environment->
I suppose it would have to be a g.gisenv GRASS variable not an
environment variable to work system-wide. But then we've have to
add some G_getenv() -> setenv() magic in G_parser() and the start
of wxgui.py?
Ticket URL: <http://trac.osgeo.org/grass/ticket/879&gt;
Resolution: | Keywords:
  Platform: Unspecified | Cpu: Unspecified
Comment (by glynn):
Replying to [ticket:879 antoniorocha]:
user would change its language without quitting GRASS session.
Is there some reason why GRASS shouldn't just use the same locale settings
as every other application?
Currently, this doesn't work on Windows, as localisation relies upon the
LANG/LC_* environment variables being set, and Windows doesn't set those,
so init.bat needs the fix proposed [http://lists.osgeo.org/pipermail/
grass-dev/2010-January/048065.html here] or something similar.
This should probably be closed as "invalid" once someone opens a bug
report for LANG not being set on Windows.
Ticket URL: <http://trac.osgeo.org/grass/ticket/879#comment:1&gt;
Comment (by marisn):
Replying to [comment:1 glynn]:
settings as every other application?
Ability to switch application language instead of changing whole work
environment language is a nice feature. I use it quite often for QGIS and
KDE applications (bug reports, testing l18n regressions etc.). Not
everyone is capable of changing system-wide locale settings (read -
restricted user rights on shared computers) also "export LANG" is not an
lamer friendly way how to do this.
Ticket URL: <http://trac.osgeo.org/grass/ticket/879#comment:2&gt;
Comment (by neteler):
Yes: If I am visiting for example Japan/China/Brasil/... I am not
necessarily
able to understand the local language, i.e. use the localized menus of the
PC
provided to me.
If it is better to have a separate bug report for this, let's do it. But
it won't change
the need for a solution.
Ticket URL: <http://trac.osgeo.org/grass/ticket/879#comment:3&gt;
Reporter: antoniorocha | Owner: grass-dev@…
      Cpu: Unspecified |
Comment(by neteler):
See also http://trac.osgeo.org/qgis/ticket/3634
"GRASS language is taken from system, not from QGIS settings"
Ticket URL: <http://trac.osgeo.org/grass/ticket/879#comment:4&gt;
Priority: major | Milestone: 6.4.3
Component: Translations | Version: svn-releasebranch64
Keywords: wxGUI, i18n | Platform: All
      Cpu: All |
Changes (by hamish):
  * component: wxGUI => Translations
  * priority: normal => major
  * platform: Unspecified => All
  * version: unspecified => svn-releasebranch64
  * milestone: 6.4.0 => 6.4.3
  * keywords: => wxGUI, i18n
  * cpu: Unspecified => All
Ticket URL: <https://trac.osgeo.org/grass/ticket/879#comment:5&gt;
Reporter: antoniorocha | Owner: lucadelu
      Cpu: All |
* cc: grass-dev@… (added)
Ticket URL: <https://trac.osgeo.org/grass/ticket/879#comment:7&gt;
      Cpu: All |
When adding the "LANGUAGE" variable, too, it works nicely.
Ticket URL: <http://trac.osgeo.org/grass/ticket/879#comment:8&gt;
      Cpu: All |
Comment(by lucadelu):
Committed as r49670 with "LANGUAGE" variable added.
TODO: replace locales in combobox, reduce list to only installed locales
Ticket URL: <http://trac.osgeo.org/grass/ticket/879#comment:9&gt;
      Cpu: All |
Replying to [comment:9 lucadelu]:
some improvement of this commit was done by MartinL in r49910, someone has
an idea how to reduce list to only installed locales?
Ticket URL: <http://trac.osgeo.org/grass/ticket/879#comment:10&gt;
      Cpu: All |
Comment(by martinl):
Please try recent version...
Ticket URL: <http://trac.osgeo.org/grass/ticket/879#comment:11&gt;
      Cpu: All |
Changes (by martinl):
* cc: martinl (added)
Ticket URL: <http://trac.osgeo.org/grass/ticket/879#comment:12&gt;
Priority: major | Milestone: 6.4.4
      Cpu: All |
  * milestone: 6.4.3 => 6.4.4
Comment:
Update: changing language settings from wxGUI should work in 6.4.3. It
still requires GRASS restart even in GRASS 7. Moving milestone to 6.4.4.
Ticket URL: <http://trac.osgeo.org/grass/ticket/879#comment:13&gt;
      Cpu: All |
Comment(by marisn):
Replying to [comment:13 martinl]:
It could be possible to try to reset active WXGUI instance language
instantly, still it's not possible to change parent process environment
and thus anything not inheriting environment from WXGUI AFTER language
change will still be in previous language. Save, restart cycle ensures
that GRASS gets the new language and probably locale too, from the start
and thus whole GRASS session has correct LANG and other parameters (CLI,
all WXGUI instances etc.). Hope that clears a bit.
Ticket URL: <http://trac.osgeo.org/grass/ticket/879#comment:14&gt;
      Type: enhancement | Status: closed
  Priority: major | Milestone: 7.0.0
Resolution: fixed | Keywords: wxGUI, i18n
  Platform: All | Cpu: All
Changes (by marisn):
  * status: new => closed
  * resolution: => fixed
  * milestone: 6.4.4 => 7.0.0
Comment:
Language switching is working in 7. As GRASS 6 should be feature frozen,
moving milestone and closing as implemented. Issues with its
implementation in GRASS 7 should be tracked in separate tickets.
Ticket URL: <http://trac.osgeo.org/grass/ticket/879#comment:15&gt;
