[GRASS-dev] [GRASS GIS] #888: Error in i.ortho.photo
Reporter: nikosdu1980 | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: wxGUI | Version: unspecified
Keywords: i.ortho.photo | Platform: Linux
      Cpu: Unspecified |
I'm running GRASS 6.4-svn in a Linux Machine (CENT OS) and I needed to run
i.ortho.photo but I got this error:
Exception in thread Thread-8:
      File "/usr/lib64/python2.4/threading.py", line 442, in
__bootstrap
         self.run( )
      File "/usr/local/grass-5.4.0svn/etc/wxpython/gui_modules/g
cmd.py", line 528, in run
         stderr=subprocess.PIPE)
     File "/usr/lib64/python2.4/subprocess.py", line 550, in
__init__
          errread, errwrite)
     File "/usr/lib64/python2.4/subprocess.py", line 993, in
_execute_child
          raise child_exception
TypeError: execv( ) arg 2 must contain only strings
     File "/usr/local/grass-6.4svn/etc/wxpython/wxgui.py",
line 1019, in 0nXTerm
p= gcmd.Command(cmdlist)
     File "/usr/local/grass-6.4.0svn/etc/wxpython/gui_modules/g
cmd.py", line 345, in __init__
Debug.msg (3, "Command( ): cmd='%s', wait=%s, returncode=%d,
alive=%s" % \
TypeError
sequence item 2: exepected string, list found
Ticket URL: <http://trac.osgeo.org/grass/ticket/888&gt;
Resolution: | Keywords: i.ortho.photo
  Platform: Linux | Cpu: Unspecified
Comment (by hamish):
Try turning off debug messages;
but that fails from the wx command console because it tries to parse the
second "=" in {{{ g.gisenv set="DEBUG=0" }}}
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/888#comment:1&gt;
Comment (by nikosdu1980):
By doing:
If if insert i.ortho.photo in command line, it opens the i.ortho.photo
menu
But If I choose in GUI menu it gives the following error:
Exception in thread Thread-9:
__bootstrap
      self.run()
    File "/usr/local/grass6.4.0svn/etc/wxpython/gui_modules/g
    File "usr/lib64/python2.4/subprocess.py", line 550, in
__init__
      errread, errwrite)
    File "usr/lib64/python2.4/subprocess.py", line 993, in
_execute_child
TypeError: execv() arg 2 must contain only strings
   File "/usr/local/grass-6.4.0svn/etc/wxpython/wxgui.py",
line 1019, in 0xTerm
p=gcmd.Command(cmdlist)
Debug.msg (3, "Command(): cmd='%s', wait=%s, returncode=%d,
alive=%s" % \
TypeError
sequence item 2:expected string, list found
And opens a blank xmonitor
Ticket URL: <http://trac.osgeo.org/grass/ticket/888#comment:2&gt;
AFAICT in gui/wxpython/gui_modules/gcmd.py the "wait" variable should be
True/False, but that should print out ok as a %s string.
I've got no idea how that could be turning itself into a list.
  * note at this point in the code it has already failed, this is in the
error handling logic)
  * see also ticket #693; the XTerm stuff has not all been backported from
6.5. I'm not able to test 6.4 right now, but in the very latest 6.5svn it
works for me.
workaround: from the command prompt do:
d.mon x0
i.ortho.photo
Hamish
ps- put { { { ... } } } (with no spaces in between) around formatted text
to show it verbatim.
Ticket URL: <http://trac.osgeo.org/grass/ticket/888#comment:3&gt;
With {{{ d.mon x0 }}} command I got a windows saying "Command 'd.mon'
not yet implemented so there is no way I can test that.
If I insert i.ortho.photo in command windows it works (I as far as I can
see). How can I change menudata.xml in order to avoid this error?
Ticket URL: <http://trac.osgeo.org/grass/ticket/888#comment:4&gt;
Hamish:
Nikos:
> With d.mon x0 command I got a windows saying
> "Command 'd.mon' not yet implemented
Sorry to be confusing, I meant the terminal command prompt, not the GUI
one.
(the xterm, gnome-terminal, etc. at the GRASS> prompt)
(the xterm, gnome-terminal, etc. GRASS> prompt, right?)
somehow in the wxPython code the "wait" variable is becoming a list on
your system. That doesn't happen for me and I don't see any obvious reason
for it in the code. A more expert wxPy'er than myself would need to tell
you why and how to fix it.
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/888#comment:5&gt;
Old description:
run i.ortho.photo but I got this error:
__bootstrap
        self.run( )
__init__
         errread, errwrite)
_execute_child
alive=%s" % \
TypeError
New description:
__bootstrap
         self.run( )
__init__
          errread, errwrite)
_execute_child
alive=%s" % \
TypeError
(fix code quoting)
Ticket URL: <http://trac.osgeo.org/grass/ticket/888#comment:6&gt;
Comment (by glynn):
Replying to [comment:5 hamish]:
OnXTerm() is seriously broken, and should be re-written or removed.
E.g.:
         # run the command
         command = ' '.join(command)
and:
                cmdlist = [xtermwrapper, '-e "%s"' % grassrun, command]
Hint: xterm's "-e" switch doesn't take an argument. It indicates that all
remaining arguments are the program and its arguments (i.e. the next
argument after -e is the program, the one after that is argv[1], etc).
This also applies to the grass-xterm-wrapper and grass-run scripts: they
take individual arguments, not a "command string".
Ticket URL: <http://trac.osgeo.org/grass/ticket/888#comment:7&gt;
It has been re-written in 6.5svn, but this has not been backported to 6.4
yet (see comment:3).
see also
  r39924
  r39928
  r40019
  r40021
  r40619
if there are no objections I'll do the backport later today.
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/888#comment:8&gt;
see also #693, this bug is really a derivative of that one.
Ticket URL: <http://trac.osgeo.org/grass/ticket/888#comment:9&gt;
