#89: d.legend: option to get info from stdin instead of raster
Reporter: hamish | Owner: grass-dev@lists.osgeo.org
Priority: minor | Milestone: 6.4.0
Component: default | Version: unspecified
Keywords: |
this was code wish # 391 over on the old gforge tracker. moving it here. http://wald.intevation.org/tracker/index.php?func=detail&aid=391&group_id=21&atid=188
Hamish
It would be nice if d.legend could look for "map=-" and if so take legend
cat and color info from stdin. That way vector maps and custom legends
could be made without resorting to tricks like making a dummy raster file
to hold
that info. [see v.colors addon script]
If data is fed from stdin (signaled by map=-) create categorical legend
using that data. Data format: "cat|label|color"
Keywords: |
Hamish
to hold
The basic idea is reasonable enough, but:
1. The map= option shouldn't be (ab)used for that purpose. There
should be separate options instead. Apart from anything else, you
either have to change map->gisprompt to allow something which isn't a
map (which means that you don't get the map browser in the GUI), or
you leave map->gisprompt alone but then can't use that feature from
the GUI.
2. Using stdin is generally a bad idea. It doesn't work with the GUI.
The module needs to copy the data to a temporary file so that d.save,
d.redraw etc work.
