#9: wxgrass: startup window does't sort locations/mapsets alphabetically
Reporter: neteler | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.3.0
Component: Python | Version: unspecified
Keywords: |
The list of locations/mapsets in the wxgrass GUI is not sorted
alphabetically. A fix is needed in
gui/wxpython/gis_set.py to
* sort locations list, but keep mapsets aligned to sorted locations
(simple |wx.LB_SORT doesn't work here)
* sort mapsets list; but keep PERMANENT on top of mapsets list
Ticket URL: <http://trac.osgeo.org/grass/ticket/9>
Commonly referred to as GRASS, this is a Geographic Information System (GIS) used for geospatial data management and analysis, image processing, graphics/maps production, spatial modeling, and visualization. GRASS is currently used in academic and commercial settings around the world, as well as by many governmental agencies and environmental consulting companies.
Replying to [ticket:9 neteler]:
My locations are sorted fine. In fact, the sorting is better in wxPython
for me than in TclTk, since myLocation and MyLocation sort together rather
than have all capitalized locations first, with "alocation" following
"Zlocation".
How is your systems misbehaving specifically? Which platform and
wxPython/Python versions are you using?
This would be convenient. Currenly, PERMANENT sorts in the P's of mapsets.
Probably not too hard to fix.
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/9#comment:1>
GRASS-trac <http://grass.osgeo.org>
Replying to [comment:1 cmbarton]:
"Zlocation".
mapsets. Probably not too hard to fix.
> Michael
I fixed the mapset list (at least for my system) so that PERMANENT shows
up at the top.
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/9#comment:2>
Replying to [comment:2 cmbarton]:
wxPython for me than in TclTk, since myLocation and MyLocation sort
together rather than have all capitalized locations first, with
"alocation" following "Zlocation".
> > Michael
up at the top.
> Michael
Had some some today and hope that I fixed the sorting issue. I think it
looks OK on my Mac because I remember something about Mac directories
being automatically alpha sorted, whereas Linux ones are not.
So I've forced sorting of the location and mapset lists. Let me know if it
works. If so, this ticket can be marked as resolved.
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/9#comment:3>
Ticket URL: <http://trac.osgeo.org/grass/ticket/9#comment:4>
Ticket URL: <http://trac.osgeo.org/grass/ticket/9#comment:5>
