[GRASS-dev] [GRASS GIS] #902: nviz (tcl) fails on wingrass
  Reporter: hamish | Owner: grass-dev@lists.osgeo.org
      Type: defect | Status: new
  Priority: critical | Milestone: 6.4.0
Component: NVIZ | Version: svn-trunk
Resolution: | Keywords:
  Platform: All | Cpu: All
Comment (by glynn):
Replying to [comment:18 hamish]:
> > This doesn't allow the nviz binary to be used to run arbitrary
> > scripts, but I'm not so sure that works anyhow.
> do you mean nvwish running arbitrary Tcl scripts (no loss) or the
ability to use the script= option (which is used by d.nviz to set up the
'flight path' for animations).
I meant "nviz -f <script>", but I think I got that working with r40879. I
discovered that nviz2.2_script uses "exec nviz -f ..." in several places
(it's relying upon the "#!nviz" to which I don't expect to work).
If `argv[1]` is "-f", main() skips the G_parser() stuff and calls
Tk_Main() with the unmodified argument list. IOW, nviz behaves like wish.
If `argv[1]` isn't "-f", main() calls G_parser() on the original command
line. If G_parser() returns successfully (--help etc all cause G_parser()
to call exit()), it then calls Tk_Main() with a fabricated command line:
"nviz -f .../nviz2.2_script" with no further arguments. IOW, nviz behaves
like a GRASS module; all command-line processing is done by G_parser()
before Tcl/Tk gets involved.
Ticket URL: <https://trac.osgeo.org/grass/ticket/902#comment:20&gt;
Comment (by glynn):
Replying to [comment:19 hamish]:
> With the latest nightly WinGrass 6.4.0svn build (r40876), I get this
error message if 'nviz --ui' is called from the msys command line,
elev=elevation.dem@PERM, and the '-v' verbose flag is ticked (one -, not
two).
> the popup window error is:
unknown or ambiguous visual name "elevation=elevation@PERMANENT":
Tk uses -v itself (it's an abbreviation for -visual). This specific issue
can be worked around by using "--" in the nviz script, i.e.
-exec "$GISBASE/etc/nviz2.2/nviz" -f
"$GISBASE/etc/nviz2.2/scripts/nviz2.2_script" ${1+"$@"}
+exec "$GISBASE/etc/nviz2.2/nviz" -f
"$GISBASE/etc/nviz2.2/scripts/nviz2.2_script" -- ${1+"$@"}
But I'm more inclined to suggest back-porting r40879. I think that's bound
to be the most robust solution.
Ticket URL: <https://trac.osgeo.org/grass/ticket/902#comment:21&gt;
Comment (by hamish):
Following the conservative path of least change I've committed the "--"
solution to the 6.4 branch. For wider testing I'd like to backported
r40879 to the 6.5 branch, but I got stuck in the merge conflicts. I had to
comment out Vars.make as it doesn't exist and getCat.c was failing because
it couldn't find V2_area_att() and V2_line_att(). I'm not sure where those
are supposed to come from.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/902#comment:22&gt;
Comment (by glynn):
Replying to [comment:22 hamish]:
r40879 doesn't touch those files.
I've found using "svn merge" between branches is more trouble than it's
worth. It's easier to use e.g.:
cd /path/to/7.0.svn
svn diff -c 40879 > nviz.patch
cd ../6.5
patch -p0 < ../7.0.svn/nviz.patch
This still produces some failures, but it doesn't try to merge unrelated
changes.
I'm test-compiling a manual back-port at the moment; I'll attach the patch
one I've verified that it compiles.
Ticket URL: <https://trac.osgeo.org/grass/ticket/902#comment:23&gt;
Comment (by glynn):
Replying to [comment:23 glynn]:
patch one I've verified that it compiles.
Verified, attached.
Ticket URL: <https://trac.osgeo.org/grass/ticket/902#comment:24&gt;
patch applied to 6.5svn in r40930.
Ticket URL: <https://trac.osgeo.org/grass/ticket/902#comment:25&gt;
Comment (by hellik):
Replying to [comment:24 glynn]:
> Verified, attached.
still valid this report? I've tested nviz by self-compiled latest grass64-
and grass65-svn in the osgeo4w-stack on WinVista, nviz is starting and
working.
Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/902#comment:26&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords:
Changes (by hamish):
  * status: new => closed
  * resolution: => fixed
Comment:
closing report as everything is pretty much working now. Purposefully
ignoring any remaining single-dash -v flag issues, if they still exist, as
corner cases.
Ticket URL: <https://trac.osgeo.org/grass/ticket/902#comment:27&gt;
