#903: Category color in r.grow
Reporter: clerici | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: default | Version: 6.4.0 RCs
Keywords: | Platform: Linux
Cpu: Unspecified |
The r.grow command assign to the grown cells a new category as selected by
user, but not a new color. The color is the same as one of the existing
categories.
For example, using the railroads map in Spearfish (in which the lines have
the categories 1 and 2):[[BR]]
r.grow in=railroads ou=railroads.grown1 new=3[[BR]]
produces a three categories' map with the color of category 1 assigned to
the new category 3.[[BR]]
Whith: r.grow in=railroads ou=railroads.grown2 new=4 [[BR]]
produces a three categories' map with the color of category 2 assigned to
the new category 4.
With new=5 the color assigned is again the color 1, with new=6 the color 2
is assigned, and so on.[[BR]]
Same results with GRASS6.5, 6.4, 6.3 (with GRASS6.2 I didn't obtain any
growing).
Resolution: | Keywords:
Platform: Linux | Cpu: Unspecified
Comment (by hamish):
What it does is copy the color table from the input map and applies it to
the output map.
When you use the new= option (or old=) with a value which is out of range
of the old color table, the new value will probably be undefined in the
old color table.
With GRASS 6.2 if you run "`r.colors railroads.grown1 color=random`" you
will see that it did grow, just that the out-of-range color was previously
coming out as white so you didn't see it.
With GRASS 6.3.0 and newer instead of undefined colors going to white it
repeats the color table. If you try with the "roads" raster map and
new=16, you can see the effect pretty well with d.legend.
I guess if those options are specified we could explicitly set old= to
yellow and new= to red (similar to how r.buffer does) to at least set them
to something.
Note if the input map's color table has a "default" (*) color defined in
it this be will be used for undefined values instead of empties being
filled by the cycling effect.
Comment (by clerici):
As a common user, I would simply expect a new table with a new different
color for the new category. In other words something like the
sequence:[[BR]]
r.colors railroads.grown1 color=random[[BR]]
though the best solution should be to mantain the original colors for the
old categories.[[BR]]
The option old=to_color and new=new_color seems a good alternative
option.[[BR]]
