#909: FTBFS: r.mapcalc in trunk
Reporter: hamish | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: new
Component: Compiling | Version: svn-trunk
Keywords: r.mapcalc | Platform: Linux
Cpu: x86-64 |
latest trunk:
"make -j8" on debian/stable, 64bit quad-core
<stdout>:1555: warning: 'yyunput' defined but not used
<stdout>:1598: warning: 'input' defined but not used
gcc -L/usr/local/src/grass/svn/trunk/dist.x86_64-unknown-linux-gnu/lib
-L/usr/local/src/grass/svn/trunk/dist.x86_64-unknown-linux-gnu/lib -Wl,
--export-dynamic -Wl,-rpath-link,/usr/local/src/grass/svn/trunk/dist.
x86_64-unknown-linux-gnu/lib -o /usr/local/src/grass/svn/trunk/dist.
x86_64-unknown-linux-gnu/bin/r.mapcalc OBJ.x86_64-unknown-linux-
gnu/check.o OBJ.x86_64-unknown-linux-gnu/column_shift.o OBJ.x86_64-
unknown-linux-gnu/evaluate.o OBJ.x86_64-unknown-linux-gnu/expression.o
OBJ.x86_64-unknown-linux-gnu/function.o OBJ.x86_64-unknown-linux-
gnu/main.o OBJ.x86_64-unknown-linux-gnu/map.o OBJ.x86_64-unknown-linux-
gnu/mapcalc.tab.o OBJ.x86_64-unknown-linux-gnu/mapcalc.yy.o OBJ.x86_64-
unknown-linux-gnu/xabs.o OBJ.x86_64-unknown-linux-gnu/xacos.o OBJ.x86_64-
unknown-linux-gnu/xadd.o OBJ.x86_64-unknown-linux-gnu/xand.o OBJ.x86_64-
unknown-linux-gnu/xand2.o OBJ.x86_64-unknown-linux-gnu/xasin.o OBJ.x86_64-
unknown-linux-gnu/xatan.o OBJ.x86_64-unknown-linux-gnu/xbitand.o OBJ.
x86_64-unknown-linux-gnu/xbitnot.o OBJ.x86_64-unknown-linux-gnu/xbitor.o
OBJ.x86_64-unknown-linux-gnu/xbitxor.o OBJ.x86_64-unknown-linux-
gnu/xcoor.o OBJ.x86_64-unknown-linux-gnu/xcos.o OBJ.x86_64-unknown-linux-
gnu/xdiv.o OBJ.x86_64-unknown-linux-gnu/xdouble.o OBJ.x86_64-unknown-
linux-gnu/xeq.o OBJ.x86_64-unknown-linux-gnu/xeval.o OBJ.x86_64-unknown-
linux-gnu/xexp.o OBJ.x86_64-unknown-linux-gnu/xfloat.o OBJ.x86_64-unknown-
linux-gnu/xge.o OBJ.x86_64-unknown-linux-gnu/xgraph.o OBJ.x86_64-unknown-
linux-gnu/xgt.o OBJ.x86_64-unknown-linux-gnu/xif.o OBJ.x86_64-unknown-
linux-gnu/xint.o OBJ.x86_64-unknown-linux-gnu/xisnull.o OBJ.x86_64-
unknown-linux-gnu/xle.o OBJ.x86_64-unknown-linux-gnu/xlog.o OBJ.x86_64-
unknown-linux-gnu/xlt.o OBJ.x86_64-unknown-linux-gnu/xmax.o OBJ.x86_64-
unknown-linux-gnu/xmedian.o OBJ.x86_64-unknown-linux-gnu/xmin.o OBJ.
x86_64-unknown-linux-gnu/xmod.o OBJ.x86_64-unknown-linux-gnu/xmode.o OBJ.
x86_64-unknown-linux-gnu/xmul.o OBJ.x86_64-unknown-linux-gnu/xne.o OBJ.
x86_64-unknown-linux-gnu/xneg.o OBJ.x86_64-unknown-linux-gnu/xnot.o OBJ.
x86_64-unknown-linux-gnu/xnull.o OBJ.x86_64-unknown-linux-gnu/xor.o OBJ.
x86_64-unknown-linux-gnu/xor2.o OBJ.x86_64-unknown-linux-gnu/xpow.o OBJ.
x86_64-unknown-linux-gnu/xrand.o OBJ.x86_64-unknown-linux-gnu/xres.o OBJ.
x86_64-unknown-linux-gnu/xround.o OBJ.x86_64-unknown-linux-gnu/xrowcol.o
OBJ.x86_64-unknown-linux-gnu/xshiftl.o OBJ.x86_64-unknown-linux-
gnu/xshiftr.o OBJ.x86_64-unknown-linux-gnu/xshiftru.o OBJ.x86_64-unknown-
linux-gnu/xsin.o OBJ.x86_64-unknown-linux-gnu/xsqrt.o OBJ.x86_64-unknown-
linux-gnu/xsub.o OBJ.x86_64-unknown-linux-gnu/xtan.o -lgrass_gis
-lgrass_raster -lgrass_btree -lreadline -lhistory -lpthread -lm
/usr/local/src/grass/svn/trunk/raster/r.mapcalc/mapcalc.tab.c:1442:
undefined reference to `yylex'
OBJ.x86_64-unknown-linux-gnu/mapcalc.tab.o: In function `parse_string':
/usr/local/src/grass/svn/trunk/raster/r.mapcalc/mapcalc.y:270: undefined
reference to `initialize_scanner_string'
OBJ.x86_64-unknown-linux-gnu/mapcalc.tab.o: In function `parse_stream':
/usr/local/src/grass/svn/trunk/raster/r.mapcalc/mapcalc.y:278: undefined
reference to `initialize_scanner_stream'
collect2: ld returned 1 exit status
make[3]: *** [/usr/local/src/grass/svn/trunk/dist.x86_64-unknown-linux-
gnu/bin/r.mapcalc] Error 1
make[3]: *** Waiting for unfinished jobs....
make[3]: Leaving directory
`/usr/local/src/grass/svn/trunk/raster/r.mapcalc'
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/909>
