[GRASS-dev] [GRASS GIS] #910: wxgui: fails with make -j
Reporter: hamish | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Component: Compiling | Version: svn-trunk
Keywords: wxgui, Makefile | Platform: Linux
      Cpu: x86-64 |
latest trunk on debian/stable with "make -j 8" on a amd64 quad-core.
gui/wxpython/ fails with:
make[2]: Entering directory `/usr/local/src/grass/svn/trunk/gui'
make -C icons || echo /usr/local/src/grass/svn/trunk/gui/icons >>
/usr/local/src/grass/svn/trunk/error.log
make -C images || echo /usr/local/src/grass/svn/trunk/gui/images >>
make -C scripts || echo /usr/local/src/grass/svn/trunk/gui/scripts >>
make -C xml || echo /usr/local/src/grass/svn/trunk/gui/xml >>
make -C wxpython || echo /usr/local/src/grass/svn/trunk/gui/wxpython >>
make[3]: Entering directory `/usr/local/src/grass/svn/trunk/gui/images'
make /usr/local/src/grass/svn/trunk/dist.x86_64-unknown-linux-
gnu/etc/gui/images/startup_banner.png
make[3]: Entering directory `/usr/local/src/grass/svn/trunk/gui/xml'
/usr/bin/install -c -m 644 grass-interface.dtd
/usr/local/src/grass/svn/trunk/dist.x86_64-unknown-linux-gnu/etc/grass-
interface.dtd
make[3]: Leaving directory `/usr/local/src/grass/svn/trunk/gui/xml'
make[3]: Entering directory `/usr/local/src/grass/svn/trunk/gui/icons'
mkdir -p /usr/local/src/grass/svn/trunk/dist.x86_64-unknown-linux-
gnu/etc/gui/icons
gnu/etc/gui/icons/grass
gnu/etc/gui/icons/grass/vdigit
gnu/etc/gui/icons/silk
make[4]: Entering directory `/usr/local/src/grass/svn/trunk/gui/images'
gnu/etc/gui/images
gnu/etc/gui/icons/grass2
/usr/bin/install -c -m 644 startup_banner.png
make[3]: Entering directory `/usr/local/src/grass/svn/trunk/gui/wxpython'
gnu/etc/wxpython
make[4]: Leaving directory `/usr/local/src/grass/svn/trunk/gui/images'
make[3]: Leaving directory `/usr/local/src/grass/svn/trunk/gui/images'
make[3]: Entering directory `/usr/local/src/grass/svn/trunk/gui/scripts'
/usr/bin/install -c g.change.gui.py /usr/local/src/grass/svn/trunk/dist.
x86_64-unknown-linux-gnu/etc/gui/scripts/g.change.gui.py
/usr/bin/install -c v.type_wrapper.py
gnu/etc/gui/scripts/v.type_wrapper.py
make[3]: Leaving directory `/usr/local/src/grass/svn/trunk/gui/scripts'
GISBASE="/usr/local/src/grass/svn/trunk/dist.x86_64-unknown-linux-gnu" \
         python gui_modules/menudata.py > menustrings.py
   File "gui_modules/menudata.py", line 208, in <module>
     data = Data()
   File "gui_modules/menudata.py", line 45, in __init__
     self.tree = etree.parse(filename)
   File "/usr/lib/python2.5/xml/etree/ElementTree.py", line 862, in parse
     tree.parse(source, parser)
   File "/usr/lib/python2.5/xml/etree/ElementTree.py", line 579, in parse
     source = open(source, "rb")
IOError: [Errno 2] No such file or directory:
'/usr/local/src/grass/svn/trunk/dist.x86_64-unknown-linux-
gnu/etc/wxpython/xml/menudata.xml'
make[3]: *** [menustrings.py] Error 1
make[3]: Leaving directory `/usr/local/src/grass/svn/trunk/gui/wxpython'
... suspected Makefile dep mis-order..
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/910&gt;
Resolution: | Keywords: wxgui, Makefile
  Platform: Linux | Cpu: x86-64
Comment (by glynn):
Replying to [ticket:910 hamish]:
menudata.py uses the installed menudata.xml, not the source file, so that
should be the pre-requisite for menustrings.py.
Fixed in r40832.
Ticket URL: <https://trac.osgeo.org/grass/ticket/910#comment:1&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: wxgui, Makefile
Changes (by hamish):
  * status: new => closed
  * resolution: => fixed
Comment:
thanks, tested ok.
not applied to 6.5 or 6.4 because for me those build ok without it.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/910#comment:2&gt;
