[GRASS-dev] [GRASS GIS] #911: v.parallel: user interface change in 6.x line
Reporter: msieczka | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: blocker | Milestone: 6.4.0
Component: Vector | Version: svn-develbranch6
Keywords: | Platform: All
      Cpu: All |
There is a user interface change to v.parallel in GRASS 6.x. The option
`distance' does not accept negative offsets anymore, and introduces a new
`side' option to distinguish left/right, instead.
Before v.parallel2, v.parallel used to accept negative numbers for dist.
Now it fails:
$ v.parallel in=lines out=lines_par dist=-1
ERROR: value <-1> out of range for parameter <distance>
        Legal range: 0-100000000
I guess such a change to user interface within a stable release line is
not allowed.
Ticket URL: <http://trac.osgeo.org/grass/ticket/911&gt;
Resolution: | Keywords: v.parallel
  Platform: All | Cpu: All
Changes (by hamish):
  * keywords: => v.parallel
Comment:
fixed in devbr6 with r41042. please test.
module is still rather buggy, & it gets differently worse after
v.build.polylines. (test map: railroads@spearfish)
- see v.buffer bug report, it's the same lib fn causing problems AFAIK.
I didn't figure out how to get angle= to work. maybe I need minordistance
for that? (docs needed)
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/911#comment:1&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: v.parallel
  * status: new => closed
  * resolution: => fixed
Comment:
backported to relbr64 with r41064.
Ticket URL: <https://trac.osgeo.org/grass/ticket/911#comment:2&gt;
