#914: Add multi-channel "import" to r.external (as in r.in.gdal)
Reporter: neteler | Owner: grass-dev@lists.osgeo.org
Priority: normal | Milestone: 6.5.0
Component: Raster | Version: svn-trunk
Keywords: | Platform: All
Cpu: All |
Currently, r.external "imports" only the first channel, not all
available channels as r.in.gdal does:
Resolution: | Keywords:
Platform: All | Cpu: All
Comment (by neteler):
Replying to [comment:1 glynn]:
> Replying to [ticket:914 neteler]:
> > The behaviour of r.in.gdal is more user-friendly, could r.external be
improved?
> Try the attached patch (untested).
As always, it works out of the box Also tested with appropriate
modifications in 6.4.
Comment (by glynn):
Replying to [comment:2 neteler]:
be improved?
