#916: GRASS 7: make install fails with --prefix
Reporter: neteler | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: new
Component: default | Version: svn-trunk
Keywords: | Platform: Linux
Cpu: Unspecified |
When using
./configure --prefix=/some/path
compiling and then running
make install
a series of bugs appear which indicate that the --prefix path
was not properly propagated. The problem might be that the
Makefile no longer has an "install" target (guessing).
Resolution: | Keywords:
Platform: Linux | Cpu: Unspecified
Comment (by hamish):
ah,
Casey Vandenberg wrote:
I was trying to install grass7.0 through svn so I could do some testing
and see some of the future development. I had no errors after typing in
make, but when I make install I get the following:
root@silver:/usr/local/src/grass_trunk# make install
echo /usr/local/src/grass_trunk/bin.x86_64-unknown-linux-gnu/grass70
make[1]: Entering directory `/usr/local/src/grass_trunk' test -d
/usr/local/grass-7.0.svn || mkdir -p -m 755 /usr/local/grass-7.0.svn
test -d || mkdir -p -m 755
sed -e "s#^GISBASE.*#GISBASE=/usr/local/grass-7.0.svn#"
/usr/local/src/grass_trunk/bin.x86_64-unknown-linux-gnu/grass70.sh >
/grass70.sh
sed -e 's#^gisbase = ".*"#gisbase = "/usr/local/grass-7.0.svn"#'
/usr/local/src/grass_trunk/bin.x86_64-unknown-linux-gnu/grass70 > /grass70
chmod a+x /grass70
tar cBCf /usr/local/src/grass_trunk/dist.x86_64-unknown-linux-gnu - . |
tar xBCf /usr/local/grass-7.0.svn - 2>/dev/null sed
's#'/usr/local/src/grass_trunk/dist.x86_64-unknown-linux-
gnu'#'/usr/local/grass-7.0.svn'#g' /usr/local/src/grass_trunk/dist.x86_64-
unknown-linux-gnu/etc/fontcap > /usr/local/grass-7.0.svn/etc/fontcap
/usr/bin/install -c config.status /usr/local/grass-7.0.svn/config.status
chmod -R a+rX /usr/local/grass-7.0.svn 2>/dev/null
tar cBf - gem/skeleton | tar xBCf /usr/local/grass-7.0.svn/etc -
2>/dev/null
/usr/bin/install -c gem/gem70 2>/dev/null
make[1]: [real-install] Error 1 (ignored)
make[1]: Leaving directory `/usr/local/src/grass_trunk'
Comment (by glynn):
Replying to [ticket:916 neteler]:
The "install" target is in Install.make, which is "include"d from the top-
level Makefile.
The problem is that r40491 removed the "BINDIR=${UNIX_BIN}" with the
intention of just using $(UNIX_BIN) instead, but didn't follow through.
