#917: v.digit map creation weirdness on wingrass
Reporter: hamish | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: Vector | Version: svn-releasebranch64
Keywords: wingrass | Platform: MSWindows XP
Cpu: x86-32 |
in the latest wingrass nightly build (r40876), but also seen before, when
I make a new map with v.digit when I go to close the map everything sings
along but then I get this error message at the end of the output:
Region restored to original extent.
Building topology for vector map <(null)>...
Registering Primatives...
Unable to read vector map
It's the same if I call v.digit (tcl) from the wxGUI menu, the gis.m menu,
or "v.digit -n test' directly from the msys prompt with no module GUI.
It's enough to start up with -n and exit intimately.
even weirder, when called from the gis.m menu/tcltk module GUI when the
attribute From window should open I get an empty sqlite DOS box opening on
top of everything and the tall&thin Form window stays all grey and
unusable.
(apparently at some point I switched the mapset to use sqlite as the
backend)
but I see the same (null) in the output even if I switch db.connect back
to use dbf.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/917>
