GDAL
February 13, 2010, 1:16am
1
#927: Crash on starting GRASS 6.4 on a Mac OS Snow Leopard
Reporter: dormerod | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: default | Version: unspecified
Keywords: | Platform: Unspecified
Cpu: Unspecified |
Process: GRASS [899]
Path: /Applications/GRASS-6.4.app/Contents/MacOS/GRASS
Identifier: org.osgeo.grass6_4
Version: ??? (???)
Code Type: X86-64 (Native)
Parent Process: launchd [540]
Interval Since Last Report: 344833 sec
Crashes Since Last Report: 14
Per-App Interval Since Last Report: 0 sec
Per-App Crashes Since Last Report: 6
Date/Time: 2010-02-13 12:08:57.463 +1100
OS Version: Mac OS X 10.5.8 (9L31a)
Report Version: 6
Anonymous UUID: BF4568E8-8939-43A6-B44C-6D5F2CACA2E2
Exception Type: EXC_BREAKPOINT (SIGTRAP)
Exception Codes: 0x0000000000000002, 0x0000000000000000
Crashed Thread: 0
Dyld Error Message:
unknown required load command 0x80000022
Ticket URL: <http://trac.osgeo.org/grass/ticket/927> ;
GRASS GIS <http://grass.osgeo.org >
GDAL
February 13, 2010, 1:44am
2
Resolution: | Keywords:
Platform: Unspecified | Cpu: Unspecified
Comment (by kyngchaos):
Did you build from source or install a binary?
If you are using the binary from kyngchaos (me), make sure you install the
correct version for your system - the Snow Leopard (10.6) version will not
run on Leopard (10.5).
Ticket URL: <http://trac.osgeo.org/grass/ticket/927#comment:1> ;
GDAL
September 7, 2011, 3:08am
3
Reporter: dormerod | Owner: grass-dev@…
Type: defect | Status: closed
Component: Default | Version: unspecified
Resolution: invalid | Keywords:
Changes (by kyngchaos):
* status: new => closed
* resolution: => invalid
Comment:
Closing from lack of feedback. System version mismatch still supposed
cause.
Ticket URL: <http://trac.osgeo.org/grass/ticket/927#comment:2> ;
