#928: 6.4: all shell scripts broken from command line + tcl; wx addon scripts
broken
Reporter: hamish | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: new
Priority: blocker | Milestone: 6.4.0
Component: default | Version: svn-releasebranch64
Keywords: addons | Platform: Linux
Cpu: x86-64 |
6.4 only: (latest svn)
running scripts held in $GRASS_ADDON_PATH from the terminal prompt, with
GRASS_GUI=wxpython never returns.
see this mailing list thread for more from Kim:
http://thread.gmane.org/gmane.comp.gis.grass.devel/37887/focus=38143
worse, with GRASS_GUI=tcltk *all* script modules fail with "`sh:
$GRASS_WISH: command not found`", both official and addon.
When running the addon module from the real terminal prompt with
GRASS_GUI=wxpython you get the following error once for every time you
press the [Stop] button.
G64:addons > which r.out.gmt
/usr/local/src/grass/addons/r.out.gmt
File "/usr/local/src/grass/svn/releasebranch_6_4/dist.x86_64-unknown-
linux-gnu/etc/wxpython/gui_modules/goutput.py", line 486, in OnCmdAbort
self.cmdThread.abort()
linux-gnu/etc/wxpython/gui_modules/goutput.py", line 108, in abort
self.requestCmd.abort()
AttributeError: 'CmdThread' object has no attribute 'requestCmd'
If run from the wxGUI Cmd> prompt with "r.out.gmt --ui", when you click
the window dressing "X" to close the window you get it again in the main
Layer Manager output tab, except this time with an additional popup error
message:
__Error in command execution r.out.[snip]__
Execution failed: 'r.out.gmt'
Details:
Error:
If I restart GRASS in tcltk mode and try "r.out.gmt" from the real
terminal prompt something even weirder happens:
G64:~ > r.out.gmt
sh: $GRASS_WISH: command not found
G64:~ > r.out.gmt --ui
G64:~ > $GRASS_WISH
[wish window opens, then I manually "X" it closed]
% G64:~ >
so $GRASS_WISH is being quoted there once too many times...
I get the same thing if I run "r.out.gmt --ui" from the lower frame in the
Output window.
(can we label that tcl command prompt frame somehow? it is impossible to
guess that typing something there does anything. perhaps sacrifice one of
the 3 input lines for a "Command:" label?)
in 6.5 it all works fine AFAICT.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/928>
