[GRASS-dev] [GRASS GIS] #935: wxGUI no longer starts automatically when GRASS 7 starts
Reporter: cmbarton | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: major | Milestone: 7.0.0
Component: default | Version: svn-trunk
Keywords: start GUI wxpython | Platform: Unspecified
      Cpu: Unspecified |
This is a bug that has been introduced since 11 February, and probably
even more recently.
When GRASS 7 is started, the GUI no longer starts automatically,
regardless of the setting in the rc file ($HOME/.grass7/rc). No error
messages are generated. Starting manually works fine (g.gui wxpython).
I also noticed that GRASS 7 (or at least GRASS_ADDON_PATH) no longer
recognizes paths with spaces in them. I don't know if this is related or
not.
I'm experiencing this on a Mac with OS X 10.6. No change in the OS over
this interval.
Michael
Ticket URL: <https://trac.osgeo.org/grass/ticket/935&gt;
Resolution: | Keywords: start GUI wxpython
  Platform: Unspecified | Cpu: Unspecified
Comment (by hamish):
what does g.gisenv say about GRASS_GUI? If that is set to "text", you
won't get a GUI..
(don't try to edit ~/.grass7/rc while grass is running; we should probably
rename that to "init.conf" or something now, as it doesn't contain run-
commands as such)
works for me with trunk r40862.
> longer recognizes paths with spaces in them.
more info please.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/935#comment:1&gt;
Comment (by cmbarton):
in g.gisenv, GRASS_GUI is set to wxpython. I've checked in rc, it is set
to wxpython. I've run g.gui -u wxpython. Everything is set OK and runs OK.
It is just that wxpython does not launch automatically. Something in a
script somewhere is not getting done. I've looked at grass.sh, init.sh,
and functions.sh, reverting recent changes and testing. No luck.
Michael
Ticket URL: <https://trac.osgeo.org/grass/ticket/935#comment:2&gt;
  Reporter: cmbarton | Owner: grass-dev@…
      Type: defect | Status: closed
Component: Default | Version: svn-trunk
Resolution: fixed | Keywords: start GUI wxpython
Changes (by cmbarton):
  * status: new => closed
  * resolution: => fixed
Comment:
Somewhere along the line, this was fixed. Closing.
Ticket URL: <http://trac.osgeo.org/grass/ticket/935#comment:3&gt;
