[GRASS-dev] [GRASS GIS] #937: cairo driver: d.legend colors all broken
Reporter: hamish | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: major | Milestone: 7.0.0
Component: Display | Version: svn-trunk
Keywords: cairo, d.legend | Platform: Linux
      Cpu: x86-64 |
in grass7 d.legend is pretty broken if you use the Cairo driver. The color
table seems out of sync or corrupted.
If you use the PNG driver it's fine.
Hamish
ps- with the PNG driver I notice the bottom right corner pixel of the
legend is wrong. Line-end wants to be closed?
Ticket URL: <https://trac.osgeo.org/grass/ticket/937&gt;
Resolution: | Keywords: cairo, d.legend
  Platform: Linux | Cpu: x86-64
Comment (by glynn):
Replying to [ticket:937 hamish]:
color table seems out of sync or corrupted.
I can't reproduce this.
The path is closed, but the PNG driver's line-drawing code doesn't draw
the last pixel. It's a boundary condition caused by trying to draw lines
exactly along the boundaries between pixels, rather than through their
centres. d.legend really needs either a 0.5 pixel offset for the lines, or
drawing successively smaller filled rectangles rather than stroking
outlines and hoping that they align exactly with the contents.
Ticket URL: <https://trac.osgeo.org/grass/ticket/937#comment:1&gt;
Comment (by hamish):
trunk/
export GRASS_WIDTH=640
export GRASS_HEIGHT=480
export GRASS_RENDER_IMMEDIATE=cairo
export GRASS_PNG_MAPPED=TRUE
export GRASS_PNG_READ=TRUE
#spearfish
d.erase
wximgview $GRASS_PNGFILE percent=50 &
d.legend roads
(smooth legends are just as bad)
bmptopnm complains:
bmptopnm: Unrecognized bits per pixel in BMP file header: 32
so I had to use xwd+wximgview for the attached screenshot.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/937#comment:2&gt;
G7> r.colors.out roads
1 175 98 252
2 227 173 57
3 100 2 115
4 81 219 128
5 57 207 247
nv 255 255 255
default 255 255 255
Ticket URL: <https://trac.osgeo.org/grass/ticket/937#comment:3&gt;
Comment (by glynn):
Replying to [comment:2 hamish]:
> trunk/
Works for me.
But looking at the image, I'm guessing that it's an alignment problem. The
header is 54 bytes, which isn't a multiple of 4. The documentation for
cairo_image_surface_create_for_data() says:
> This pointer must be suitably aligned for any kind of variable, (for
example, a pointer returned by malloc).
It wouldn't surprise me if an unaligned frame buffer behaves incorrectly
on x86-64.
Try r41029; this pads the header to 64 bytes in everything which
reads/writes these files (PNG driver, cairo driver, ximgview, wximgview,
wxpyimgview). The offset to the data is stored in the header (to allow for
variable-length fields and the addition of new fields), so the files
should still be legal (not that most software can handle them anyhow).
Ticket URL: <https://trac.osgeo.org/grass/ticket/937#comment:4&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: cairo, d.legend
Changes (by hamish):
  * status: new => closed
  * resolution: => fixed
Comment:
Replying to [comment:4 glynn]:
> problem. The header is 54 bytes, which isn't a multiple of 4.
> The documentation for cairo_image_surface_create_for_data() says:
> > (for example, a pointer returned by malloc).
> incorrectly on x86-64.
> wximgview, wxpyimgview). The offset to the data is stored in the
> header (to allow for variable-length fields and the addition of
> new fields), so the files should still be legal (not that most
bingo. that fixed it.
`qiv` still opens the .bmp as a scrambled 640x64 mess, but I guess that's
due to it not liking the 32bitness of it.
just out of curiosity, how do the .bmp, .ppm, and SGi's .rgb differ, in
that IIUC they are all just raw binary dumps of width height r1g1b1 r2g2b2
r3g3b3 ...
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/937#comment:5&gt;
Comment (by glynn):
Replying to [comment:5 hamish]:
r3g3b3 ...
PPM has a variable length header (where the header length is determined by
parsing), followed by 24-bpp RGB data. BMP has a variable-length header
(where the length is stored in the header) followed by data in a variety
of possible formats. RGB has a fixed-size (512 byte) header followed by
data in a variety of possible formats.
PPM was ruled out because it doesn't support 32-bpp data. BMP was the next
candidate due to having the documentation immediately to hand. Any format
which supports raw 32-bpp RGBA data (with suitable alignment) would work.
Ticket URL: <https://trac.osgeo.org/grass/ticket/937#comment:6&gt;
ok one last question for the png,cairo driver help pages- what's the role
of PGM? I just lumped it in with PPM. Is it there to cover the alpha
channel, is it an automatic change over if only greyscale data is found,
or is it a force-greyscale option?
thanks,
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/937#comment:7&gt;
Comment (by glynn):
Replying to [comment:7 hamish]:
role of PGM? I just lumped it in with PPM. Is it there to cover the alpha
PGM is used for the alpha channel.
Ticket URL: <https://trac.osgeo.org/grass/ticket/937#comment:8&gt;
64-bit compatibility backported to devbr65 r41068.
Ticket URL: <https://trac.osgeo.org/grass/ticket/937#comment:9&gt;
