[GRASS-dev] [GRASS GIS] #953: module help information in machine-readable format
Reporter: cmbarton | Owner: grass-dev@lists.osgeo.org
Priority: normal | Milestone: 6.5.0
Component: default | Version: unspecified
Keywords: help, metadata | Platform: All
      Cpu: All |
The information returned from running "<module> help" would be useful for
a variety of interface=related tasks like auto-completion and automatic
menu building. Unfortunately, it is completely localized, making it
impossible to parse in a reliable fashion within scripts and computer
code.
I'm requesting the addition of a parameter to G_usage() which would
replace the human-readable section descriptions with markers which can be
relied upon to never occur in normal help text, e.g. "{{{KEYWORDS}}}\n",
then add a (e.g.) --help-data option. It would be helpful to also include
an unlocalized version of the keys for each of the description sections
(e.g., Description, Flags, Usage in an English localization).
Ticket URL: <http://trac.osgeo.org/grass/ticket/953&gt;
Resolution: | Keywords: help, metadata
  Platform: All | Cpu: All
Comment (by hamish):
unset LANG # (etc)
g.module --interface-description
   | piped to python XML parser
Ticket URL: <https://trac.osgeo.org/grass/ticket/953#comment:1&gt;
  Reporter: cmbarton | Owner: glynn
Changes (by glynn):
* cc: grass-dev@lists.osgeo.org (added)
Ticket URL: <https://trac.osgeo.org/grass/ticket/953#comment:3&gt;
Comment (by glynn):
Replying to [ticket:953 cmbarton]:
for a variety of interface=related tasks like auto-completion and
automatic menu building. Unfortunately, it is completely localized, making
it impossible to parse in a reliable fashion within scripts and computer
code.
The --help output isn't appropriate for this. Use --interface-description
instead.
I've added --help-text, which delimits the main sections of the --help
output with machine-readable markers, and also writes to stdout rather
than stderr.
Code should not attempt to parse the output further; if you want more
specific information, use the --interface-description output.
Ticket URL: <https://trac.osgeo.org/grass/ticket/953#comment:4&gt;
Component: Default | Version: unspecified
      Cpu: All |
Comment(by hamish):
can we consider the wish completed?
Ticket URL: <https://trac.osgeo.org/grass/ticket/953#comment:5&gt;
      Cpu: All |
Comment(by cmbarton):
Replying to [comment:5 hamish]:
Probably.
Ticket URL: <https://trac.osgeo.org/grass/ticket/953#comment:6&gt;
      Type: enhancement | Status: closed
Resolution: fixed | Keywords: help, metadata
Changes (by cmbarton):
  * status: new => closed
  * resolution: => fixed
Ticket URL: <https://trac.osgeo.org/grass/ticket/953#comment:7&gt;
