#955: v.digit background errors
Reporter: clerici | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: default | Version: 6.4.0 RCs
Keywords: | Platform: Linux
Cpu: Unspecified |
The d.vect command in the Background panel of v.digit gives an error
regarding topology rebuilding[[BR]]
1) I inserted roads_copy (a copy of roads in Spearfish) in the GIS
Manager[[BR]]
2) I entered v.digit by the r.digit/v.digit button.[[BR]]
3) The v.digit GUI was correctly opened and the display was ok.[[BR]]
4) In the background panel the command 'd.vect map=roads_copy@esercizi
color=0:0:0 ..........' is displayed by default.[[BR]]
5) I moved a node in roads_copy.[[BR]]
6) Clicking the Redraw button the following error message was reported in
the Output window(Fig.1.)[[BR]]
Entering v.digit through: Vector>Develop map>Digitize the Background panel
is empty.[[BR]]
I added the command 'd.vect map=roads_copy disp=cat' and I moved a node.
In redrawing, the cat values were not displayed and I had the same error
as in Fig.1.[[BR]]
I entered at the GRASS prompt the command: v.digit map=roads_copy
map=roads_copy bgcmd='d.vect map=roads_copy disp=cat'. Moving a node and
redrawing, the cat values were correctly displayed and two WARNING were
reported in the terminal (Fig.2).
The error is the same with GRASS6.3, 6.4 and 6.5.
Ticket URL: <http://trac.osgeo.org/grass/ticket/955>
