[GRASS-dev] [GRASS GIS] #957: v.voronoi has extra lines in output
Reporter: helena | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: normal | Milestone: 6.4.1
Component: Vector | Version: 6.4.0 RCs
Keywords: | Platform: All
      Cpu: All |
at least since 6.3 v.voronoi produces extra lines in the polygon output,
this example run with elev_lid792_randpts
has just one, but I have seen worse results:[[BR]]
http://skagit.meas.ncsu.edu/~helena/grasswork/voronoibug_poly.png
When converted to raster using v.to.rast, the result has holes (nulls),
indicating that some polygons do not have values assigned[[BR]]
http://skagit.meas.ncsu.edu/~helena/grasswork/voronoibug_rast.png
[[BR]]
These examples were done with grass65, but I get the same from 64[[BR]]
Helena
Ticket URL: <http://trac.osgeo.org/grass/ticket/957&gt;
Reporter: helena | Owner: grass-dev@…
Component: Vector | Version: svn-develbranch6
      Cpu: All |
Changes (by deboyy):
  * version: 6.4.0 RCs => svn-develbranch6
Comment:
I perform voronoi map of 118 sample areas.
> Before perform voronoi for every area set region with the related vector
> map. But one of the area strange result occured. I check my data and
> couldn't found any fault or difference to other areas. Is there any bug
in
> the code?
Ticket URL: <http://trac.osgeo.org/grass/ticket/957#comment:1&gt;
      Cpu: All |
Comment(by mlennert):
ping
I can reproduce this bug with 6.4. Any ideas ?
Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/957#comment:2&gt;
      Cpu: All |
Comment(by deboyy):
Replying to [comment:2 mlennert]:
> ping
> Moritz
Dear Moritz,
I attach same areas new shp file with little changes (trees dbh>12 cm).
May be it can help to solve problem. I suspect points z coordinate and
minimum distance between points.
Yalçın
Ticket URL: <http://trac.osgeo.org/grass/ticket/957#comment:3&gt;
      Cpu: All |
Comment(by deboyy):
This new file (agaccpgr34.zip) v.voronoi couldn't produce any problem for
me.
Yalçın
Ticket URL: <http://trac.osgeo.org/grass/ticket/957#comment:4&gt;
Priority: major | Milestone: 6.4.1
      Cpu: All |
Changes (by hamish):
  * priority: normal => major
Ticket URL: <https://trac.osgeo.org/grass/ticket/957#comment:5&gt;
Priority: major | Milestone: 6.4.2
      Cpu: All |
Changes (by mlennert):
  * milestone: 6.4.1 => 6.4.2
Comment:
More info on this bug. Using the following data (in file xyz.csv):
x;y;z
0;1;0
1;1;0.8415
2;2;0.9093
3;1;0.1411
4;4;-0.7568
5;3;-0.9589
6;4;-0.2794
and the following commands
v.in.ascii in=xyz.csv out=xyz fs=';' skip=1 x=1 y=2 col="x int, y int, z
double precision" --o
g.region vect=xyz
v.voronoi xyz out=xyz_voronoi
I get screenshot bug_voronoi1.png. This seems to show some issue with
points at the edges as there are two points located in the same polygon in
the bottom left (1 & 2) and top right (6 & 7).
Then I try with a larger region:
g.region n=5 s=0 w=-1 e=7
v.voronoi xyz out=xyz_voronoi2
and I get screenshot bug_voronoi2.png which now seems completely wrong.
I've tried this in 6.4.1 and fairly recent versions of 6.5 and trunk (a
few days old). The same problem appears in all versions.
Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/957#comment:6&gt;
      Cpu: All |
Comment(by mmetz):
Please try trunk r48378. This fixes the extra lines.
The holes reported by Helena are a different problem, a floating point
precision error somewhere. Snapping the result, e.g.
v.voronoi in=elev_lid792_randpts out=elev_lid792_randpts_voronoi
v.clean in=elev_lid792_randpts_voronoi
out=elev_lid792_randpts_voronoi_snap tool=snap thresh=0.0000001
type=boundary
solves some but not all errors.
Markus M
Ticket URL: <http://trac.osgeo.org/grass/ticket/957#comment:7&gt;
      Cpu: All |
Replying to [comment:7 mmetz]:
type=boundary
> Markus M
For me this solves both my bugs and the one reported by Helena (when going
through the extra snap step), i.e. no more extra lines and no holes (after
snapping).
However, the following:
g.region vect=precip_30ynormals
v.voronoi in=precip_30ynormals out=precip_voronoi
still gives me a polygon containing two points (39 and 82 - see
bug_voronoi3.png)
Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/957#comment:8&gt;
      Cpu: All |
Comment(by mmetz):
Replying to [comment:8 mlennert]:
bug_voronoi3.png)
The output is correct, no duplicate centroids. I guess in the screenshot
you have overlaid precip_30ynormals and not the centroids of
precip_voronoi.
The reason why point 82 (and point 112) is missing is that even though
g.region vect=precip_30ynormals does set the region extents exactly to the
vector extents, the extents are stored with insufficient precision in
WIND:
region north: 306221.83019368
vector north: 306221.830193683563
region south: 27606.895351356
vector south: 27606.895351000000
region east: 917004.82916485
vector east: 917004.829164845869
region west: 151768.56824561
vector west: 151768.568245610630
which in this case causes two points to be excluded.
Markus M
Ticket URL: <http://trac.osgeo.org/grass/ticket/957#comment:9&gt;
      Cpu: All |
Replying to [comment:9 mmetz]:
bug_voronoi3.png)
precip_voronoi.
Yes, sorry for not being clear.
WIND:
Yes, that was it.
g.region vect=precip_30ynormals res=1 -a
does the trick for me.
Should the precision in the WIND file be increased ? Or the value of
GRASS_EPSILON to take into account the lesser precision in WIND ?
Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/957#comment:10&gt;
      Cpu: All |
Comment(by hamish):
> the extents are stored with insufficient precision in WIND:
I would suggest that since this is in the 5 nanometer range, and WIND is
seemingly stored to `%.14g` (or does that happen when reading the vector's
&window?), that we verify that `printf(%.15g)` is used when writing the
WIND file and then if needed use GRASS_EPSILON to test.
I would suggest ignoring such corner cases in the code, keep using fast >=
tests, and recommend in the docs that `g.region vect=` should be used with
the `-a and res=` options in most cases.
I'm not sure where the %.14g is coming from, as lib/gis/wind_format.c
writes using %.15g.
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/957#comment:11&gt;
Keywords: v.voronoi | Platform: All
      Cpu: All |
  * keywords: => v.voronoi
Ticket URL: <http://trac.osgeo.org/grass/ticket/957#comment:12&gt;
      Cpu: All |
Comment(by mmetz):
Replying to [comment:10 mlennert]:
WIND:
> Yes, that was it.
I tried adjusting the bounds with GRASS_EPSILON in g.region, to no avail.
IMHO, this is a more fundamental question. For real projections with units
= meter or feet, the current precision is more than enough for raster
operations. All vector operations use double precision for coordinates,
and here problems start.
1) The reduced precision in the WIND file can cause vector features to
fall outside the current region even after g.region vect=myvect.
2) Even if g.region vect=myvect would store the bounds with full
precision, from a raster perspective (rows and cols), the vector points
falling exactly on the eastern and southern border are outside, not inside
the current region. This is because the row index for a region with nrows
ranges from 0 to nrows - 1, and (region.north - region.south) / nsres =
nrows, but nrows > nrows - 1. A vector point exactly on the southern
border would thus be in row number nrows, one row outside the current
region. Same for columns and eastern border.
Therefore it may be a good idea to do the adjustment that g.region
currently does in
https://trac.osgeo.org/grass/browser/grass/trunk/general/g.region/main.c#L549
and following lines not only for window.north == window.south etc. but
always, to make sure that all vector features are really inside the
current region? See also ticket #123.
Markus M
Ticket URL: <http://trac.osgeo.org/grass/ticket/957#comment:13&gt;
      Cpu: All |
Comment(by mmetz):
Replying to [comment:11 hamish]:
>= tests, and recommend in the docs that `g.region vect=` should be used
with the `-a and res=` options in most cases.
writes using %.15g.
Not for real projections, at least not for nc_spm_08 with projection: 99
(Lambert Conformal Conic) because full %.15g precision is only used when
projection == -1, otherwise %.8f is used. See
https://trac.osgeo.org/grass/browser/grass/trunk/lib/gis/wind_format.c#L33
Markus M
Ticket URL: <http://trac.osgeo.org/grass/ticket/957#comment:14&gt;
      Cpu: All |
Comment(by hamish):
> > lib/gis/wind_format.c writes using %.15g.
Replying to [comment:14 mmetz]:
> projection: 99 (Lambert Conformal Conic) because full %.15g
> precision is only used when projection == -1, otherwise %.8f is
> used. See
ah, right.. so it's %.8f not %.14g. FWIW I added that -1 for "full"
precision* in r37725 as some modules were lying to G_format_*() about not
being lat/lon (when they really were) to get decimal output instead of
D:M:S, with rather unfortunate results.
[*] (%.15g doesn't quite show full IEEE double, but the max without
partial-noise bits)
assuming that projected coords are either in feet or meters, I'm happy
enough with 10 nanometer precision. GPS and projection math will take a
very long time to catch up with that. Even %.15g won't match what's in the
vector's bbox, and again I wonder out loud if this is worth worrying
about, or if it should just be declared a feature in the v.voronoi help
page.
see also #123.
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/957#comment:15&gt;
      Cpu: All |
Comment(by mmetz):
Replying to [comment:15 hamish]:
Even %.15g won't match what's in the vector's bbox, and again I wonder out
loud if this is worth worrying about, or if it should just be declared a
feature in the v.voronoi help page.
> see also #123.
See comment:13 for a suggestion to avoid entries in a number of manuals
like "g.region vect=myvect is not enough, you must adjust the region with
g.region -a or g.region n=n+x s=s-x e=e+x w=w-x"
Markus M
Ticket URL: <http://trac.osgeo.org/grass/ticket/957#comment:16&gt;
      Cpu: All |
Comment(by hamish):
Replying to [comment:16 mmetz]:
(thanks, I'd missed that)
> > g.region currently does in trunk/general/g.region/main.c#L549
> > etc. but always, to make sure that all vector features are
> > really inside the current region?
By "always" you mean just when used with vect=, right? :slight_smile:
The idea to round out by 1/2 a grid cell in each direction seems ok at
first, but I speculate about what the problems might be:
  - as res= is typically not set with vect=, what happens if original res
is quite large but vector bbox is very small? you get a big region as a
result when you wanted one orders of magnitude smaller.
  - what if you have a series of vector points broken up by region (lidar
1km x 1km chunk files) and want to patch their bboxes together? would you
be better/worse/no worse than now?
perhaps it is better to expand by some other proportional amount? like the
lesser of 1/2 a grid cell, or +/- (n-s)*1e-n ? (where n=6..15), or +/-
GRASS_EPSILON and change the WIND file (and thus all other G_format_*())
to record to useless/impracticable/wasteful precision?
or hardcode the +/- 0.00000001 with a note that it should match the
precision in format_double()?
open to suggestions,
Hamish
ps- it is wonderful that this longstanding v.voronoi bug is near to being
fixed!
Ticket URL: <http://trac.osgeo.org/grass/ticket/957#comment:17&gt;
      Cpu: All |
Comment(by mmetz):
Replying to [comment:17 hamish]:
Sure :- no absolute always implied here.
Right, but that affects also the current behaviour of g.region
The combination of g.region vect=myvect; v.in.region out=myvect_region can
exclude features in the current behaviour (%.8f precision). In this case
you could use the output of v.info -e plus v.in.ascii to get bboxes and
then patch them together (v.info could also get a new output option box
which writes the box to a vector).
the lesser of 1/2 a grid cell, or +/- (n-s)*1e-n ? (where n=6..15), or
+/- GRASS_EPSILON and change the WIND file (and thus all other
G_format_*()) to record to useless/impracticable/wasteful precision?
Does it harm to record .15g precision in the WIND file? Internally, it's
always stored as double AFAICT.The only harm I can see is
implying/suggesting a precision that is not justified by geospatial data.
(Unless someone does spatial analysis on electron microscope scans with
meters as unit, i.e. non-geo but spatial data).
That one, hardcoding a fixed value matching the minimum precision in the
WIND file, makes most sense to me. GRASS_EPSILON has no effect with %.8f
since it's 1e-15.
> Hamish
being fixed!
Ticket URL: <http://trac.osgeo.org/grass/ticket/957#comment:18&gt;
      Cpu: All |
Comment(by mmetz):
type=boundary
going through the extra snap step), i.e. no more extra lines and no holes
(after snapping).
Proper cleaning (a bit more than snapping) is now built into v.voronoi,
trunk r48382. The result from v.voronoi in=elev_lid792_randpts
out=elev_lid792_randpts_voronoi is now 100% ok.
Markus M
Ticket URL: <http://trac.osgeo.org/grass/ticket/957#comment:19&gt;
