[GRASS-dev] [GRASS GIS] #961: WinGRASS-6.4.0SVN-r40852-1 installs GRASS, but it doesn't run
Reporter: stoyan | Owner: grass-dev@lists.osgeo.org
     Type: task | Status: new
Priority: normal | Milestone: 6.4.0
Component: default | Version: 6.4.0 RCs
Keywords: GRASS, problems, start | Platform: MSWindows XP
      Cpu: Unspecified |
I downloaded WinGRASS-6.4.0-r40852-1 and installed GRASS on my laptop on
Windows XP Pro Platform, but I cannot start it. When I am trying to
execute wxPython inder Windows start menu, the window with cmd only
flashes and dissappears. When I am trying MSys Icon it says: "Echo
C\GRASS\Msys\lib is not a valid executable or operable command. The window
will close"... Press any button to continue
I installed GRASS in C:\GRASS directory.
When I tried to install it on another machine with Windows XP Professional
installed it runs OK. I have read all mailing lists, but couldn't find
such a problem so far. I don't know what should be the problem with my
operation system or my computer. Please help!
Ticket URL: <http://trac.osgeo.org/grass/ticket/961&gt;
Component: Installation | Version: 6.4.0 RCs
Resolution: | Keywords: winGRASS, problems, start
  Platform: MSWindows XP | Cpu: Unspecified
Changes (by hamish):
  * keywords: GRASS, problems, start => winGRASS, problems, start
  * component: default => Installation
Comment:
can you try the latest nightly build?
http://josef.fsv.cvut.cz/wingrass/grass64/
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/961#comment:1&gt;
Comment (by neteler):
Replying to [comment:1 hamish]:
Additionally, please check, when installing, if the files are properly
extracted or if a "skipped" appears. Please report here.
Ticket URL: <https://trac.osgeo.org/grass/ticket/961#comment:2&gt;
  Reporter: stoyan | Owner: stoyan
      Type: task | Status: assigned
* cc: grass-dev@lists.osgeo.org (added)
Ticket URL: <https://trac.osgeo.org/grass/ticket/961#comment:5&gt;
Comment (by stoyan):
Replying to neteler:
I tried to find out if all files were extracted and I think they were.
It's the same, I cannot start the program. I tried to copy c:\GRASS from
another computer, where it works to my computer. Probably it is silly, I
don't know. :slight_smile: But nothing gets better. Still doesn't work. Obviously
there is something in my OS that prevents running GRASS. Any other ideas?
Stoyan
Ticket URL: <https://trac.osgeo.org/grass/ticket/961#comment:6&gt;
Comment (by hellik):
Replying to [comment:6 stoyan]:
> Stoyan
still valid with an actual nightly build from
http://josef.fsv.cvut.cz/wingrass/grass64/?
Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/961#comment:7&gt;
Yes, it is. I still cannot run Grass from my system. It doesn't start
after install. It doesn't matter if I install the actual nightly build or
not. I think about formatting the disk and create new installation of my
system (windows XP).
Ticket URL: <http://trac.osgeo.org/grass/ticket/961#comment:8&gt;
Replying to [comment:8 stoyan]:
do you see in C:\GRASS\ following files and folders?
AUTHORS
bin
bwidget
CHANGES
COPYING
docs
driver
etc
extrabin
extralib
fonts
GPL.TXT
gpsbabel
GRASS-WebSite.url
grass64svn.bat
icons
include
lib
locale
msys
proj
Python25
REQUIREMENTS.html
scripts
sqlite
tcl-tk
tools
Uninstall-GRASS.exe
WinGRASS-README.url
can you try to install the latest installer from the nightly builds
(http://josef.fsv.cvut.cz/wingrass/grass64/) in C:\Program Files\GRASS-64-
SVN (this should be proposed by the wininstaller)?
and compare afterwards the list of above files and folders in C:\Program
Files\GRASS-64-SVN. any difference to the situation in C:\GRASS ?
Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/961#comment:9&gt;
Yes I installed the latest installer in C;\Program Files\GRASS-64-SVN and
saw all of the listed files and folders. But there is another interesting
thing. The last rows of the install window were:
"Create folder: C:\Program Files\GRASS-64-SVN\msys\home
Create folder: C:\Program Files\GRASS-64-SVN\msys\home\C\Documents and
Settings\Stoyan
Create folder: C:\Program Files\GRASS-64-SVN\msys\grass
Copy to C:\Program Fies\GRASS-64-SVN\msys\home\C:\Documents and
Settings\Stoyan
Copy failed
Completed"
I don't know why it cannot copy this and why it should be copied, but can
it be the reason for not starting?
Ticket URL: <http://trac.osgeo.org/grass/ticket/961#comment:10&gt;
Replying to [comment:10 stoyan]:
and saw all of the listed files and folders. But there is another
interesting thing. The last rows of the install window were:
these are the relevant lines in the installer script:
(http://trac.osgeo.org/grass/browser/grass/branches/releasebranch_6_4/mswindows/
GRASS-Installer.nsi#L703)
CreateDirectory $INSTALL_DIR\msys\home
Settings\Stoyan
GRASS-Installer.nsi#L704)
$INSTALL_DIR\msys\home\$USERNAME
GRASS-Installer.nsi#L770)
CreateDirectory $INSTALL_DIR\msys\grass
Settings\Stoyan
> Copy failed
> Completed"
GRASS-Installer.nsi#L801)
CopyFiles $PROFILE\.grassrc6 $INSTALL_DIR\msys\home\$USERNAME
very interesting:
"Copy to C:\Program Fies\GRASS-64-SVN\msys\home'''\C:\Documents and
Settings\Stoyan'''"
this should be
"Copy to C:\Program Fies\GRASS-64-SVN\msys\home\Stoyan"
Ticket URL: <http://trac.osgeo.org/grass/ticket/961#comment:11&gt;
Replying to [comment:11 hellik]:
> very interesting:
Settings\Stoyan'''"
> this should be
I've tested the latest nightly build on my laptop:
Create folder: C:\Program Files\GRASS-64-SVN\msys\home\syringia
Create folder: C:\Program Files\GRASS-64-SVN\msys\home\grass
Copy to C:\Program Files\GRASS64-64-SVN\msys\home\syringia
Completed
so there seems to be something with your %USERNAME%-variable in your
windows installation.
could you start a normal windows console (start menue -> run -> cmd) and
type in:
echo %USERNAME%
and paste in the result in the bug report.
Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/961#comment:12&gt;
This is the result:
Stoyan
Ticket URL: <http://trac.osgeo.org/grass/ticket/961#comment:13&gt;
Replying to [comment:13 stoyan]:
> This is the result:
> Stoyan
this is ok.
could you start a normal windows console and type in
echo %USERPROFILE%
paste in the result in the bug report?
Ticket URL: <http://trac.osgeo.org/grass/ticket/961#comment:14&gt;
The result is: C:\Documents and Settings\Stoyan
Ticket URL: <http://trac.osgeo.org/grass/ticket/961#comment:15&gt;
Replying to [comment:15 stoyan]:
also ok.
WinGrass-Installer and/or WinXp seem to mix the two variables %USERNAME%
and %USERPROFILE% during installation:
'''C:\Documents and Settings\Stoyan'''
this isn't a valid path, so the last copy-action by the installer can't
complete.
I couldn't find anything helpfull in NSIS-manuals at the moment.
Ticket URL: <http://trac.osgeo.org/grass/ticket/961#comment:16&gt;
Replying to [comment:16 hellik]:
> also ok.
complete.
I've opened a thread for this issue on the nsis-forum
(http://forums.winamp.com/showthread.php?t=317856)
Ticket URL: <http://trac.osgeo.org/grass/ticket/961#comment:17&gt;
Keywords: winGRASS, problems, start | Platform: MSWindows XP
      Cpu: Unspecified |
Comment(by hamish):
> seem to mix the two variables %USERNAME% and
any resolution?
Ticket URL: <http://trac.osgeo.org/grass/ticket/961#comment:18&gt;
      Cpu: Unspecified |
Comment(by hellik):
Replying to [comment:18 hamish]:
> any resolution?
no response from the nsis-forum.
so any additional info about the situation with recent builds of
WinGrass64-installers would be helpfull.
Helmut
Ticket URL: <https://trac.osgeo.org/grass/ticket/961#comment:19&gt;
      Cpu: Unspecified |
Comment(by hamish):
the symptom sounds like the classic missing dll problem (but which one?).
try installing the Microsoft .net Frameworks and see if it helps. see also
#1354, #1428, #1450
http://grass.osgeo.org/wiki/WinGRASS_Current_Status#XP.2F2000
> "Copy to C:\Program Fies\GRASS-64-SVN\msys\home\C:\Documents and
Settings\Stoyan"
do you still see that bad path name from the installer script?
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/961#comment:20&gt;
      Type: task | Status: closed
Resolution: duplicate | Keywords: winGRASS, problems, start
  * status: assigned => closed
  * resolution: => duplicate
Comment:
merged into bug #1428 "WinGRASS 6.4.1 fails to start after installation"
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/961#comment:21&gt;
